    math: project point on a poly
    SDK Help
    0
    14
    972
    • H
      On 10/06/2004 at 10:07, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hi all,
      i need to find the closest point p1 in a poly
      to point p2 outside of the poly.
      It should be possible to get p1 by projecting p2 along the normal of the poly, but unfortunately i dont know how to do it! (cos im quite bad at maths)
      Is there maybe a function in the sdk that can
      project a point on a plane along the planes normal?
      thanks,
      devel
      • H
        On 11/06/2004 at 09:43, xxxxxxxx wrote:
        the solution of your problem is very difficult:
        it is ease to do this with a Plain and a Point, because a plane has infinite extension. but in your case you have to check the bounds (edges) of your poly. Another problem is that that a poly can also be nonplanar, so you have to do this with triangles, they are always planar!
        btw: I don´t know any function in the sdk that does your thing!
        • H
          On 11/06/2004 at 10:34, xxxxxxxx wrote:
          well,thanks for your answer..
          your probably right, especially about the poly vs triangle thing..
          ..didnt think of that before x-|
          what i am actually trying to do with my plugin
          is make a multispline stick to a deformable mesh..
          like when i make a spline-beard around a poly selection
          and then make some facial expression morphing with the head, the beard stays attached to the poly-selection..
          well maybe there's another solution somewhere..
          or somebody else already did it!
          thanks anyway,
          and have a good time all,
          devel
          • H
            On 11/06/2004 at 11:24, xxxxxxxx wrote:
            Don't 100% understand the question, but maybe you could use the GeRayCollider class.
            Its a class used to check if a ray has intersected a polygon, and it returns a whole great deal of information, the point of intersection, the polygons normal, etc
            The xpresso ray collider node is very useful to experiment with
            • H
              On 11/06/2004 at 12:03, xxxxxxxx wrote:
              thanks ill read it up in the manual and play around some,
              but it looks like it can only check collision between ray(line) and object and i need to check collision ray/poly..
              --edit---
              ..should have read the manual BEFORE posting...
              looks like the node can return the poly that was hit by the ray...
              so thanks again, looks like this might work! 😄
              devel
              • H
                On 11/06/2004 at 12:18, xxxxxxxx wrote:
                Yes its for object, but objects are made out of polygons right?
                Its also not that hard to check if a point is inside a polygon, there are many ways to do it.
                http://www.gametutorials.com/Tutorials/opengl/OpenGL_Pg3.htm
                I learn't all I know about polygon detection from that site
                1. Line Segment and Plane Collision
                2. Line Segment and Polygon Collision
                The source code contains a very good explaination on what is happening. Its easy to convert into c4d too, because sdk already has great vector operations 🙂
                • H
                  On 11/06/2004 at 14:00, xxxxxxxx wrote:
                  thanks, i'll check it out..
                  • H
                    what i understood is that you need something that always stays at the same place on top of a (deformable) surface, right? In my opinion you should do this with the uv-coordinates of the poly. else you are getting problems with the right position when the shape of the poly is changing! I don´t know if there is any function in the sdk that extracts you the 3d-coordinates with the input of a poly and the uv-coordinates!
                    • H
                      On 12/06/2004 at 02:07, xxxxxxxx wrote:
                      hmm, sounds like a good idea..
                      i'm not quite sure how to do it right now,
                      but im im just gonna play around with uv now, might
                      turn out to be easier than what i had in mind first..
                      thanks for the hint,
                      devel
                      • H
                        On 12/06/2004 at 02:46, xxxxxxxx wrote:
                        bad idea. This would require the object to always have accurate UV coords which is not always the case (some don´t even have any UVs assigned)
                        • H
                          On 12/06/2004 at 02:55, xxxxxxxx wrote:
                          yeah thats right,
                          but i actually need this plugin for my fully textured head (with complete uvw's), so that shouldnt be a problem..
                          on the other hand, that wouldnt make it very handy in terms of general usefulness (e.g. for other people) i guess...
                          well, so how'd you do it?
                          the problem is indeed to get the right coordinate on the poly, when the mesh has deformed..
                          greetings,
                          devel
                          • H
                            On 12/06/2004 at 03:05, xxxxxxxx wrote:
                            Well, actually I already did this ;o) I am using this for my own plugin DPInstantTree (for it now has hair support) and so I wrote such a plugin some days ago. I am triangulating the object and then calculate the initial position on the triangle (as written a tri is always planar) and stick it to this position. Actually not that complicated. Do a google search for the position in a triangle. It´s more than easy.
                            Good luck
                            • H
                              On 12/06/2004 at 03:06, xxxxxxxx wrote:
                              when deforming the barrycentric coords of the poly do change too (maybe maxx meant these coords by uv coords) so it works here too.
                              • H
                                On 12/06/2004 at 03:21, xxxxxxxx wrote:
                                alright thanks Samir,
                                gonna check it out..
                                greetings,
                                devel
