C++ SDK 2026.4 — Supported ordered mouse movement input for keyboard-initiated modal transforms
Hello Maxon SDK Team,
I am developing a C++ viewport transformation plugin for Cinema 4D 2026.4, using the Cinema 4D 2026.3 SDK.
The plugin supports keyboard-initiated modal Move/Rotate/Scale operations (G/R/S), without holding down a mouse button. It needs continuous mouse movement, including when the cursor wraps across viewport boundaries.
Currently, cursor positions are sampled through GetCursorPos() during viewport cursor callbacks and periodic updates. The plugin uses SetCursorPos() when wrapping is necessary.
Under rapid mouse movement, especially while holding Shift for precision transforms, we have observed cases where cursor positions appear discontinuous after a warp. A large apparent displacement can then enter the transform calculation.
We would like to replace this polling-based approach with a properly supported event-based solution, if the Cinema 4D SDK provides one.
Could you clarify the following?
Is there a supported way for a C++ plugin to continuously receive ordered mouse movement events during a keyboard-initiated modal operation, without any mouse button held down?
Can EditorWindow::BfGetInputEvent() be used for this purpose? Does it provide the original mouse event coordinates, modifier state, and reliable ordering relative to cursor repositioning performed through SetCursorPos()?
Does calling BfGetInputEvent() remove events from the queue that Cinema 4D or other plugins would otherwise process? If so, is there a supported way to preserve or forward events not owned by our plugin?
If BfGetInputEvent() is not suitable, which API or callback mechanism would Maxon recommend for this type of keyboard-initiated continuous viewport interaction? Are there specific thread, window ownership, or lifecycle restrictions?
We are specifically looking for the supported SDK input and event ownership contract, rather than a workaround based on motion thresholds, delays, or repeated cursor repositioning.
Thank you for your guidance.
Hello @hey2495,
Getting Started
- Forum Overview: Provides a broad overview of the fundamental structure and rules of this forum, such as the purpose of the different sub-forums or the fact that we will ban users who engage in hate speech or harassment.
- Support Procedures: Provides a more in detail overview of how we provide technical support for APIs here. This topic will tell you how to ask good questions and limits of our technical support.
- Forum Features: Provides an overview of the technical features of this forum, such as Markdown markup or file uploads.
It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
About your First Question
Please excuse the delay, I will be answering your topic next week.
Ferdinand -
Hey,
please excuse the long delay. Please have a look at Support Procedures for future topics, we do not allow for multi-question topics, as they have a tendency to derail.
Yes, there are multiple ways to do this. I cannot highlight each way in all details due to the broad nature of this question and topic. Some ways are:
- Implement SceneHookData and implement
::MouseInput,::KeyboardInputetc. Scene hooks are sort of spider in the net node types which exist always exactly once in each document. They are often used to do command and control tasks. Things like render regions or the simulation system in Cinema are all backed by scene hooks. - Implement a
GeDialog, start a timer viaGeDialog::SetTimerand on each tick, poll the current input state yourself via GetInputState (the current state) orGetInputEvent(the last enqueued input event, could lie in the past). - Implement a thread or job, and poll from there on each tick.
EditorWindow::BfGetInputEvent()just likeGeDialog::GetInputEventand similar methods is a specialization of the genericcinema::GetInputEvent. It is often better to use the global functions rather than the specific ones, unless one wants to filter out all events that do not go to a specific viewport or dialog. As hinted at above, you often also want to poll for the state and not for events, as they can be consumed (the user is still holding down "X" but something has already consumed this event) and temporally offset (the user is not pressing x anymore, but the event is still last in queue).Does calling BfGetInputEvent() remove events from the queue ...
I would quite frankly have to check this, and this is probably not an easy "look it up in file foo.c on line 4555". Without checking, I would say that the InputEvent methods do not consume the events, as there is no way to signal back that you have consumed an event. The canonical way to consume events are plugin methods such as the scene hook methods discussed above, or similar methods of other plugin types. There you can then return true ore false to indicate if you want to consume an event or not.
This is exactly why we disallow multi question topics
I could write an essay alone on this because while this is a precise question it covers so much ground. In general, you should avoid polling the input state off main thread if you can. The input methods are not explicitly thread-unsafe but I would still avoid it. The reason is that the plugin type specific methods which are about inputs, such as SceneHookData::MouseInput,ObjectData::MoveHandle, orToolData::KeyboardInputusually run on the MT. I would advise the against polling inputs in heavily parallelized methods such asSceneHookData::Execute,ObjectData::GetVirtualsObjects,TagData::Execute. While it might not provoke crashes, it is for sure not good for performance. Polling for the input in your own custom thread spawned from the MT is fine.But you usually do not have to use threading, there should be a plugin interface with input methods which fits your needs. And when the plugin interface you use does not have an input polling function, e.g., you implement a tag, it means that you should not poll for inputs there and use another plugin type or rethink your whole design. You could for sure make it technically work that a tag behaves differently depending on the key(s) the user presses, but from a Maxon point of view, this would be a rogue UX.
Ferdinand - Implement SceneHookData and implement
Hi Ferdinand,Thank you for your detailed reply, and apologies for making the original post too broad. I have narrowed this down to one SDK question.
Our C++ plugin starts a modal G/R/S transform from the keyboard via SceneHook/ToolData, with no mouse button held. We currently sample
GetCursorPos()and useSetCursorPos()for viewport-edge wrapping.In a reproducible Windows 11 high-refresh-rate case, our trace shows the following sequence:
- A mouse sample at (2077, 189) triggers a warp to (68, 189).
SetCursorPossucceeds and an immediateGetCursorPosreadback confirms (68, 189).- After the viewport update, the OS cursor is observed at (2109, 197).
- The next callback reads (2192, 215), so subtracting the stored warp position yields a false (+2124, +26) motion delta.
We understand from your reply that
GetInputEvent()can return stale information, so switching to it blindly would not solve this.Is there a supported Cinema 4D C++ SDK input callback or API that can supply mouse movement during a keyboard-initiated, button-free modal interaction with documented semantics that distinguish real user motion from
SetCursorPos()-related repositioning or delayed events?If no such distinction is guaranteed by the SDK, that information would also be very helpful; we want to avoid taking ownership of Cinema 4D's window event loop.
Thank you again,
hey2495 -
Hey @hey2495,
okay, this changes things a bit. I also overlooked the
SetCursorPosin your first posting, I do not know what you are exactly doing, but setting the cursor position is a bit unusual for a plugin.When you say "G/R/S transform" I assume you are trying to implement some kind of move/scale/rotate gizmo for your tool plugin? And the main issue you currently have is that when you set the cursor, that you read (from your perspective) incorrect input information?
- As you said it yourself, I would try to switch to input states here rather than events. You gave the special condition that your events are without any button being pressed which is rather unusual for Cinema event polling. I would have to check myself having no pressed button impacts mouse pos polling.
- I would for sure use here the global input polling (cinema::GetInputState and not the specialization attached to viewports or dialogs. You talk about screen borders and using there a filtered version of the input stream (even when you viewport or dialog seemingly fills the whole screen) does not seem like a good idea.
- There is
EVMSG_ASYNCEDITORMOVE, a core message that is sent when the user moves something in the editor window. Our Cappucino mouse movement recorder tool uses this.
Is there a supported Cinema 4D C++ SDK input callback or API that can supply mouse movement during a keyboard-initiated, button-free modal interaction with documented semantics that distinguish real user motion from SetCursorPos()-related repositioning or delayed events?
Our input handling is probably about thirty years old (with improvements made along the way). The rigid modern day system boundaries you are asking for (does this and that under these conditions) do not exist. This was written in a time when devs thought using more than one character for a variable name is something offensive
When you implement a tool (be it ToolData or ToolDescriptionData), you should use its mouse and keyboard functions to track inputs. Using a scene hook (which would also have dedicated polling functions) and on top manual polling also seems not necessary (but I only have a very superficial view on your project).
When you are still stuck, I would recommend sharing a brief executable/compile-able code snippet, so that I can better understand what is going wrong for you. And with executable I mean for example a minimal SceneHook impl that shows your problem. There are so many things that could go wrong for such a delicate issue as yours. But my key idea would be that you might operate on stale data when polling for events instead of states.
This could mean a lot, but a plugin which does runtime monkey patching is not allowed. Maybe I am misunderstanding you here, but at face value, 'taking ownership of Cinema 4D's window event loop' is absolutely off limits and we will ban any plugin ID and their owners who would attempt to do such openly malicious actions.
