    File import and doc merge -> InsertAfter or c4d.PREF_INTERFACE_I_BOTTOM
    python2026
    5 Posts 3 Posters 197 Views 3 Watching
      mogh
      Dear Team,
      I am trying to import files and place them in the object tree in the right order,
      i tried to set the preferences with c4d.PREF_INTERFACE_I_BOTTOM before import but it did not change my order.
              interface_preferences = c4d.GetWorldContainer()
              previous_insert_at = interface_preferences.GetInt32(c4d.PREF_INTERFACE_INSERTAT)
              interface_preferences.SetInt32(c4d.PREF_INTERFACE_INSERTAT, c4d.PREF_INTERFACE_I_BOTTOM, )
      Is there a convenient way or do i need to move the "node" manually to the bottom on each import ...
      or more universal for me is there a way to sort root nodes in the Object manager tree ? (only found an old coffee thread ... )
      thanks in advance ...
      mogh
      • AnlvA Offline
        Anlv
            obj = c4d.BaseObject(c4d.Ocube)
            # Insert after the last root object.
            roots = doc.GetObjects()
            doc.InsertObject(obj, pred=roots[-1] if roots else None)
        Hope this helps.
        Here is another example that can directly execute the import
            path = c4d.storage.LoadDialog(
                c4d.FILESELECTTYPE_SCENES,
                "Import Scene"
            if not path:
            anchor = roots[-1] if roots else None
            old_guids = {obj.GetGUID() for obj in roots}
            flags = (
                c4d.SCENEFILTER_OBJECTS |
                c4d.SCENEFILTER_MATERIALS |
                c4d.SCENEFILTER_MERGESCENE |
                c4d.SCENEFILTER_DIALOGSALLOWED
            c4d.StopAllThreads()
            doc.StartUndo()
            try:
                doc.AddUndo(c4d.UNDOTYPE_CHANGE, doc)
                if not c4d.documents.MergeDocument(doc, path, flags, None):
                    c4d.gui.MessageDialog("Import failed.")
                # Find the newly imported root objects.
                imported = [
                    obj for obj in doc.GetObjects()
                    if obj.GetGUID() not in old_guids
                # Move them below the previous last root object.
                if anchor:
                    for obj in imported:
                        matrix = obj.GetMg()
                        doc.AddUndo(c4d.UNDOTYPE_CHANGE, obj)
                        obj.Remove()
                        obj.InsertAfter(anchor)
                        obj.SetMg(matrix)
                        anchor = obj
            finally:
                doc.EndUndo()
        Anlv
          ferdinand @Anlv
          Hey @mogh,
          let me clarify things first a bit.
          Reproduce:
          1. You have a scene A in an alien scene format such as FBX or OBJ.
          2. You have an existing native Cinema 4D scene B.
          3. You are trying to merge A into B.
          Result:
          The objects of A appear before the objects of B in the scene hierarchy of the merged scene. Even when you change the insertion order in Preferences > Interface.
          First of all, it is not very surprising that "insert at" does not work (and "paste at" does neither), because these are for individual objects within a scene, not for merging entire scenes. What you are effectively missing is a scene merge order option and this does not really have something to do with importers. This would be addressed best by a feature request in our Support Center.
          With a pinch of Python, you can solve this yourself as demonstrated by @Anlv (thanks!). Using BaseList2D.GetGUID as @Anlv did is okay, but the more native solution would be hash(obj), i.e., C4DAtom.__hash__. Scene elements are for quite a while now natively hashable, so you can for example do this:
          roots: set[int] = { hash(obj) for obj in doc.GetObjects() }
          new_roots: set[int] = roots.intersection({ hash(obj) for obj in new_doc.GetObjects() })
          And it will give you the set of all root level hashes (GeMarker IDs). I think also the transform copying @Anlv does at the end of the script should not be necessary, because these are root level objects, and therefore removing and re-adding them will not affect their transforms (as they have no parents to which their transform would be relative to). But I have not run @Anlv's full script myself, so it could be that I am overlooking something.
          AnlvA 1 Reply Last reply Reply Quote 1
          • AnlvA Offline
            Anlv @ferdinand
            @ferdinand Thanks for pointing that out. Indeed, matrix = obj.GetMg() and obj.SetMg(matrix) are not necessary; this is leftover code from when it was previously used to insert into the child or sibling level of the selected object.
            Anlv
              mogh
              Thank you all for your answers. Will test this.
