    Request for programmatic Rename and Delete functionality for SubTool Folders
    Scheduled Pinned Locked Moved ZBrush SDK
    windows
    4 Posts 2 Posters 571 Views
    • K Offline
      kewlsheet
      I am currently developing a plugin that requires automated management of SubTool folders. While I can successfully create and manipulate folder contents, I have identified a critical limitation in both the ZScript and Python APIs: there are no native commands to rename or delete existing SubTool folders.
      Could you please consider exposing Rename and Delete functions for SubTool folders in the next API update? Having programmatic control over these actions would significantly improve the workflow for organizational plugins and pipeline automation.
      Thank you for your time and for your continued work on the ZBrush API.
      • K Offline
        kewlsheet
        Following my request for SubTool folder management, I would like to suggest two additional features to improve pipeline automation:
        Masking Data Access: Please provide read/write access to SubTool masking data.
        Layer Manipulation: Please add API support for managing SubTool layers.
        Thank you for your consideration.
        • K Offline
          kewlsheet
          i'll appreciate an answer.
          D 1 Reply Last reply Reply Quote 0
          • D Offline
            davide @kewlsheet
            Getting Started
            It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
            About your Question
            We have noted your feedback and we are aware of some of the shortcomings of the current API. Subtool and folder management are high on the list of the use cases we plan to cover in a future API update. At the moment though, we don't have a set date for releasing a new version of the API.
            Please, let us know if you identify more areas of improvement.
            Regards,
            Davide
