    Shader bitmap rendering with MemoryFileStruct
    c++
    4 Posts 2 Posters 885 Views 1 Watching
    • WickedPW Offline
      WickedP
      Hi Folks,
      Terribly sorry, hoping not to take up anyone's time too much. But I can't see the forest through the trees on this one, and hoping someone can easily fix me!
      I have a document, housed at class level. I use it to render a simple scene, and then display the resulting image as a bitmap for the user. Inside this scene is an object with an assigned material that has a bitmap shader in it's colour channel. Everything works fine if I set the shader bitmap to a file on disk. But as soon as I try to use a bitmap I've drawn myself, it either renders blank, or throws a 'missing asset' error.
      End goal here is to render the shader with a bitmap I've created in memory.
      Some pseudo code below. Note - I'm cutting all the fluff out trying to keep it simple and to the point:
      void RenderMyDoc(...)
      	// setup scene objects and shaders etc..
      	BaseBitmap *bmp = ...;
      	AutoAlloc<BaseFile> writeHandler;
      	MemoryFileStruct *mfs = ...;
      	Filename fn;
      	fn.SetMemoryWriteMode(mfs);
      	bmp->Save(fn,...);
      	/* Also tried with the following (scoped here just for clarity) */
      		fn.SetMemoryReadMode(void_p_here,void_p_sizehere);
      		writeHandler->Open(fn,...);
      		writeHandler->WriteBytes(void_p_here,void_p_sizehere);
      		// p.s. the void* and void data size all report numbers
      		/* Wondering if it was because of the empty fn path, I tried calling GenerateTexturePath() on the fn, to no avail */
      	// Add to shader
      	shader->SetParameter(BITMAPSHADER_FILENAME,GeData(fn),...);
      	// A few other things here etc..
      	// Render doc here all works, except when using my own bitmap
      	RenderDoc(...);
      If I show the bitmap using the filename in the picture viewer, it works. But not when rendered. Sometimes it presents an 'Open file' dialog, despite having WriteMode set to the memory struct. I've seen quite a few topics elsewhere with python code, but my interpretation of python into C++ just isn't working. What am I doing wrong here?
      Hoping someone can fill the gaps for me. Cheers,
      WP.
      wickedp.com
        Hey @WickedP,
        Thank you for reaching out to us. This is rather hard to answer as is. It is not that your question would be inadequate or the code example unclear, but this is also a subject I would have to try out myself to know for sure. The problem with pseudo code is that it is not executable, when you want a definitive answer, I must ask you to provide compileable code which demonstrates the issue.
        About your Issue
        Since you say that sending such image file to the Picture Viewer works, we can rule out that you made any mistakes in setting up the Filename in memory mode or properly encoding your image data.
        What is noteworthy is that Filename is a Cinema API type from the 'old' days which is today just a hollowed out shell that wraps UrlInterface. When using the memory feature of Filename you are actually using maxon::URLSCHEME_MEMORYFILESTRUCT (not to be confused with URLSCHEME_MEMORY). Internally we tend to use yet another file virtualization scheme implemented for URLs when embedding virtual files in scenes or renderings, maxon::URLSCHEME_RAMDISK.
        There could be a threading issue with your Filename (check if the issue also happens when you pass RENDERFLAGS::NODOCUMENTCLONE to your RenderDocument call).
        The most forward fix would be however to use a ram disk, as that is what is proven to work with render engines. The problem is that there are currently no public examples for creating URLSCHEME_RAMDISK urls in the public SDK (as it is sort of a semi-official thing). The only place where I used it was in the Asset API docs, but only to ensure ram disk assets are being cached, not to create new ones. But ram disk scheme urls have a convenience interface, RamDiskInterface which makes it quite straight forward to use. Find below some mock code for your use case (did not compile it due to the lack of a project for this topic).
        using namespace maxon;
        Result<void> DoRamDiskStuff()
          iferr_scope; // Error handler for this scope because we are using the Maxon API. When you want to merge
                       // this with Cinema API code, i.e., use it in a function that is not of type Result<T>,
                       // you would have to use here iferr_scope_handler to terminate errors into the return
                       // type of your function.
          // Create a new mounting point for ram disk files. Use a unique ID in reversed domain name notation
          // to avoid conflicts with other mounting points or use the other constructor to create an automatic
          // hashed mounting point (which will not be persistent over reruns).
          RamDiskRef mountingPoint = RamDiskInterface::Create("net.mycompany.ramdisk.foo"_s) iferr_return;
          Url root = mountingPoint.GetRoot() iferr_return;
          // There are now basically two ways to create ram disk files:
          //   (1) direct creation where we effectively treat the Url just like a file.
          //   (2) lazy creation where we provide a callback that will be called when the file is first accessed.
          // Our payload.
          const Char payload[] = "Hello World!";
          // Direct creation:
          // We create a file under our ram disk mounting point, it would have an URL such as
          // "ramdisk://.../file.txt". You can directly use this URL in all parameters and file
          // operations. We can also turn an Url back into a Filename using cinema::MaxonConvert.
          Url directFile = (root + "direct_file.txt"_s) iferr_return;
          // Now we write to the file, this is just standard Maxon API file I/O.
          InOutputStreamRef inout = directFile.OpenInOutputStream() iferr_return;
          inout.Write(payload) iferr_return;
          // And this would be the way to read back.
          Char buffer[SIZEOF(payload)];
          inout.Seek(0) iferr_return;
          inout.Read(buffer) iferr_return;
          // Deferred/Lazy creation:
          // This way is in a certain sense a bit easier (as stream handlers can be a bit scary when new
          // to the Maxon API). The advantage is of course that we only pay the costs when something is
          // actually needed. The downside is that is this can happen at an inconvenient time. Which is
          // also why I showed in the Asset API examples for how to build caches in advance. But in your
          // case where you create the URLs yourself, this makes no sense.
          // This is just this one call which we invoke on our ram disk mounting point. We provide a callback
          // that will be called when the file is first accessed, and in this callback we create an IoMemoryRef
          // with our payload and return it.
          Url lazyFile = mountingPoint.CreateLazyFile(ToSingletonBlock("lazy_file.txt"_s),
            [payload] () -> Result<IoMemoryRef>
              iferr_scope;
              DiagnosticOutput("Lazy content creation triggered.");
              IoMemoryRef mem = IoMemoryRef::Create() iferr_return;
              mem.WriteBytes(0, payload) iferr_return;
              return mem;
            }) iferr_return;
          // Reading back would work the same here.
          return OK;
        In your specific case, I do not know if BaseBitmap::Save will work directly on a Filename that wraps a ram disk url (via Filename file = cinema::MaxonConvert(myRamDiskUrl, MAXONCONVERTMODE::WRITE);), but you can try and it should work. When push comes to shove you can always write data directly as you showed yourself.
        • WickedPW Offline
          WickedP
          Thanks @ferdinand,
          Yeah apologies about the old containers. I was reading a fair bit of older material, was what the searches came up with so just went with them for familiarity. I was hoping it was something simple like a flag I hadn't set, or a line of code I'd missed. I had tried with the doc-no-clone flag as well, but that didn't work either. I have a gut feeling it's something else causing the problem.
          If you like, this one can be marked as 'solved' (or whatever the flag is so you don't need to come back!). With the above and what I have here, I'll figure something out.
          WP.
          wickedp.com
            Hey,
            there is no shame in using the 'old' stuff since it is part of our API (and it will stay like that). I just point it out whenever a user is dealing with one of the hollowed out types.
            My guess would be that there is a threading issue or threading safety mechanism in the way. I think the memory struct stuff is internally using locks to avoid race conditions/corrupted data. When the renderer backend is doing its threading thing, this could cause issues.
            But ramdisk should work because our assets use the concept heavily (most assets are only a 'promise' which will only be truly created once accessed). You would even profit from the ramdisk caching in the temp folder of Cinema 4D.
            So, in its simplest form, this should just look like this:
              // --- Error Handling and Resource Management ----------------------------------------------------
              // Declare heap allocated resources that must be freed once the function exists either normally or
              // through an error.
              HeapRescource * myResource = nullptr;
              BaseBitmap * bmp = nullptr;
              // Catch any Maxon API error and turn them into the return type of this function and do optional
              // logging. We could also free resources here, but then we would have to do it twice, once for
              // normal exit and once for error exit.
              iferr_scope_handler
                // DiagnosticOutput("Error during RenderMyDoc: @", err);
                return;
              // finally is Maxon API syntax to execute code once a scope (not necessarily a function) is left,
              // no matter if it is left through normal execution or through an error. This way we can ensure
              // that resources are freed.
              finally
                if (myResource)
                  HeapResource::Free(myResource);
                if (bmp)
                  BaseBitmap::Free(bmp);
              // Allocate all the resources we need. When we use AutoAlloc<T>, we would not need the finally block
              // above, but not all types have an AutoAlloc allocator.
              myResource = HeapResource::Alloc();
              if (!myResource)
                return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Failed to allocate heap resource.");
              bmp = ...
              // --- Main Logic --------------------------------------------------------------------------------
              // Create our ramdisk mounting point and an URL within it. In practice, we probably would want this
              // ramdisk mounting point to be a class member or even a global singleton.
              const Url ramdiskUrl = (mountingPoint.GetRoot() + "my_virtual.psd"_s) iferr_return;
              // Call BaseBitmap::Save with the ramdisk URL converted to a Filename.
              bmp->Save(cinema::MaxonConvert(ramdiskUrl), ...);
