    [Cinema 4D/Redshift] Nested Redshift Proxy Files Not Detected by Project Asset Inspector
    20252026windowslinux
    4 Posts 2 Posters 645 Views 1 Watching
    • V Offline
      vaishhg
      Dear community,
      I'm facing an issue with nested Redshift proxy files not being detected by Cinema 4D's Project Asset Inspector. When a Redshift proxy file references another Redshift proxy file (proxy-of-proxy), only the first-level proxy is detected, causing incomplete asset collection when saving projects.
      Environment:
      • Cinema 4D Version: 2025, 2026
      • Renderer: Redshift
      • Operating System: Windows, Linux
      • Python Version: 3.11 (Cinema 4D native)
      Issue Description:
      When ProxyA.rs references ProxyB.rs, the Project Asset Inspector only detects ProxyA but fails to discover ProxyB. This results in incomplete project asset collection when using "Save Project with Assets" or when programmatically querying scene dependencies.
      Steps to Reproduce:
      • Create objects in Cinema 4D and export to Redshift proxy (ProxyB.rs)
      • Create new scene, add Redshift proxy object referencing ProxyB.rs
      • Export this setup to another Redshift proxy (ProxyA.rs)
      • Create new scene with Redshift proxy object referencing ProxyA.rs
      • Open Project Asset Inspector (Window > Content Browser > Project Asset Inspector)
      • Observe that only ProxyA.rs is listed, ProxyB.rs is missing
      Expected Behavior:
      The Project Asset Inspector should recursively scan Redshift proxy files to detect nested proxy references and list all dependencies.
      Actual Behavior:
      Only first-level proxy files are detected. Nested proxies are not discovered, resulting in incomplete asset collection when moving projects between workstations.
      SDK Investigation:
      I've been exploring the Cinema 4D SDK to programmatically detect these nested dependencies. Using the SDK, I can access proxy materials and textures:
          objs = doc.GetObjects()
          for obj in objs:
              print(obj[c4d.REDSHIFT_PROXY_MATERIAL_LIST])
              print(obj[c4d.REDSHIFT_PROXY_MATERIAL_TEXTURES])
      This successfully retrieves the proxy material and texture lists, showing references like:
      ProxyOfProxyOfProxyTest.c4d:__RSC4D Default Material
      RedshiftProxyTest.c4d:__RSC4D Default Material
      Questions:
      • Is there a built-in way to make the Project Asset Inspector recursively detect nested Redshift proxy dependencies?
      • Can c4d.documents.GetAllAssetsNew() be used to discover these nested proxy files?
      • Is there an SDK approach to programmatically traverse the proxy dependency chain and ensure all nested assets are collected?
      Workaround:
      Currently manually copying nested proxy files alongside projects, but this requires knowing which nested dependencies exist beforehand.
      Has anyone implemented a solution for detecting and bundling nested Redshift proxy dependencies? Any guidance would be greatly appreciated.
      Thank you for your assistance.
        ferdinand @vaishhg
        Hello @vaishhg,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
        About your First Question
        I assume this is about Deadline? I am also not sure that I understand the question correctly. Let me recap, so that we are sure we talk about the same thing.
        You have a scene Original.c4d and you export it to the Redshift Scene format OriginalProxy.rs. Then you create a Cinema 4D scene Composition.c4d and there create one or multiple Redshift Proxy objects referencing OriginalProxy.rs. Then you export that scene as a Redshift scene as CompositionProxy.rs. You now want to access information about Original.c4d or OriginalProxy.rs when loading CompositionProxy.rs with a RS Proxy object into a Cinema 4D scene (or by extension see that information in the Asset Inspector).
        That is not possible. rs is the Redshift scene format which works across the full landscape of DCCs supported by Redshift. The Redshift format has no such concept as a generator and just discretizes all smooth/procedural geometry data.
        When you export a Cinema 4D scene to the Redshift rs format, it will among other things just walk your scene and collect all the geometry caches and save them discretely in the RS format. For Redshift it does not make any difference if it collects the cache of a Cube generator object or the cache of a Redshift Proxy generator object. In the eyes of Redshift these are both just two procedural geometry generators which must be discretized/baked for export (not entirely true, because Redshift Proxy objects are cached in the Redshift Core itself and not in Cinema 4D, but close enough).
        As soon as you save a scene in the RS format, all information is lost that something once was a generator and the parameters it held. The Redshift Core also does not know a concept such as asset data or the Asset Inspector, as that is a Cinema 4D specific concept. So, such data is not stored in the rs format either.
        So, to answer your questions: You cannot reach into the past like that. Neither directly via the Asset Inspector and its API, nor indirectly by for example traversing the scene graph of a scene. In fact, RS Proxy objects do not even have caches in the Cinema 4D world, unless you set Preview to Mesh. The actual data resides discretely in the in the Redshift Core.
        As an example, when we have this scene which holds two proxies and we run this script on it to, print the scene graph string of each object in the scene, we can see both proxies only hold discrete polygonal data:
        import mxutils
            for obj in mxutils.IterateTree(doc.GetFirstObject(), True):
                print(mxutils.GetSceneGraphString(obj))
        When we now save that scene as an RS scene file and load that in an RS Proxy object in another scene, we will see that it only contains one blob of discrete geometry.
        • V Offline
          vaishhg
          Thank you for the detailed explanation. This helps clarify the limitation.
          One follow-up question: We've observed that nested Redshift proxies render correctly at runtime — the renderer successfully resolves and renders the full proxy chain. Given this, is the limitation specifically that the Asset Inspector/SDK cannot detect nested proxy dependencies for asset collection purposes, even though the renderer can resolve them?
          If so, it would be helpful to understand how the renderer discovers these nested dependencies internally, and whether there's any way to access that same resolution logic via the SDK for asset management workflows.
          Thanks again for your support.
            ferdinand @vaishhg
            Hey @vaishhg,
            As I tried to explain there are no nested dependencies. *.rs is a full blown scene file format which can express geometry, curves, simulation data, materials and more. When you save a Cinema 4D scene as *.rs al data in it is exported to that format, including the "nested" case where a *.c4d scene is referencing a *.c4d scene.
            So when you start out with this *.c4d scene:
            Scene.c4d
                +-- Objects
                    +-- Cloner ( creates 5 instances)
                        +-- Cube Generator
                            +-- Cache
                                +-- Polygon Object
                            +-- Tags
                                +-- Material Tag (references 'Red Material')
                +-- Materials
                    +-- Red Material
            And then export it to Scene.rs, you get this (this is not an actual depiction of the file format, just a visualization of what happens, rs is not an open format).
            Scene.rs
                +-- Objects
                    +-- Cube.0 [Red Material]
                    +-- Cube.1 [Red Material]
                    +-- Cube.2 [Red Material]
                    +-- Cube.3 [Red Material]
                    +-- Cube.4 [Red Material]
                +-- Materials
                    +-- Red Material (contains Red Material definition)
            If you load that file back into Cinema 4D you get this. All data - that these are 5 separate cubes with a red material each - resides in the Redshift core only, we only see a proxy in Cinema 4D, hence the name "RS Proxy Object". It is the Redshift Core which will resolve the data in the RS file at render time.
            ReferencingScene.c4d
                +-- Objects
                    +-- RS Proxy Object.0 (loads Scene.rs)
                        +-- Cache (will be empty by default, there is literally no data in the c4d core,
                                   only when we set 'Preview' to 'Mesh' there will be a cache so that the
                                   viewport can display something)
                            +-- Polygon Object (one blob representing all 5 cubes and no material information)
                    +-- RS Proxy Object.1 (loads Scene.rs)
                        +-- Cache
                            +-- Polygon Object
            When we now export ReferencingScene.c4d to ReferencingScene.rs we get this. Because when the exporter runs, it will encounter the two RS Proxy Objects when flattening the c4d scene and do what you cannot do, grab the rs scene data from the referenced Scene.rs files and inline that into the new ReferencingScene.rs file. So we end up with 10 cubes in total, each with the red material assigned.
            ReferencingScene.rs
                +-- Objects
                    +-- Cube.0 [Red Material] (from RS Proxy Object.0)
                    +-- Cube.1 [Red Material] ...
                    +-- Cube.2 [Red Material] ...
                    +-- Cube.3 [Red Material] ...
                    +-- Cube.4 [Red Material] ...
                    +-- Cube.0 [Red Material] (from RS Proxy Object.1)
                +-- Materials
            And when we load that back into Cinema 4D we get this:
            SecondGeneration.c4d
                +-- Objects
                    +-- RS Proxy Object.0 (loads ReferencingScene.rs)
                        +-- Cache
                            +-- Polygon Object (one blob representing all 10 cubes and no material information)
            The TLDR is that the Redshift Core can read *.rs files and the Cinema API cannot, it can only write them or load them via an RS Proxy Object. And there is no 'resolving [...] the full proxy chain' as you put it. An *.rs scene file is just a discrete scene representation that contains does not know concepts such as generators or assets known to the Cinema API/Core. When export a *.c4d scene that references *.rs files all data is just flattened into a single *.rs file (again, what I showed under the *.rs formats above was just a visualization, not the actual file format).
            There is currently no way to do what you want to do, even if you would request access to the Redshift Core C++ SDK. Because the RS file format is a GPU scene file format and very deeply integrated into the core. Even the RS Core SDK does not expose functionalities to read RS files to CPU memory structures.
