    Getting some weird console output from GeDialog.Timer()
    python2026
    3 Posts 2 Posters 416 Views 1 Watching
    • B Offline
      blkmsk
      Hello there^^
      I wanted to implement the GeDialoge.Timer() in one of my scripts and realized that it creates some
      output in the console and I dont know where its coming from or how to prevent it.
      When I run this example script:
      from c4d import gui
      _dlg = None
      class TimerTestDialog(gui.GeDialog):
          ID_STATUS = 1000
          ID_BTN = 1001
          def __init__(self):
              super().__init__()
              self._ticks = 0
          def CreateLayout(self):
              self.SetTitle("Timer Test")
              self.AddStaticText(self.ID_STATUS, c4d.BFH_LEFT, name="Starting…")
              self.AddButton(self.ID_BTN, c4d.BFH_LEFT, name="Close Dialoge")
              self.SetTimer(1000)
          def Command(self, wid, msg):
              if wid == self.ID_BTN:
                  self.Close()
              return False
          def Timer(self, msg):
              self._ticks += 1
              self.SetString(self.ID_STATUS, f"Ticks: {self._ticks}")
          global _dlg
          _dlg = TimerTestDialog()
          _dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=260, defaulth=80)
      I get the following console output:
      (null)(null)(null)(null)(null)(null)(null)骥pf(null)骥pf(null)(null)骥pf(null)(null)骥pf
      Has anyone else experienced this before?
      Thanks in advance for any help or hints!
      Ben
      • DunhouD Online
        Dunhou
        Timer should return None:
            def Timer(self, msg: BaseContainer) -> None:
                If you subscribe to timer events using :meth:`SetTimer` (x), this function is called every x'th millisecond.
                :type msg: BaseContainer
                :param msg: The raw timer message.
                pass
        https://boghma.com
        https://github.com/DunHouGo
        • B Offline
          blkmsk
          Thank you @Dunhou ! That solved it!
