    Forcing GetDDescription() refresh in ToolData plugin (EventAdd not working)
    c++
    3 Posts 2 Posters 716 Views 1 Watching
    • Viktor VelickoV Offline
      Viktor Velicko
      I’m writing a ToolData plugin with the C++ SDK.
      I see that GetDDescription() is automatically called when:
      the tool is first activated (before InitTool()),the user interacts with the Attribute Manager (e.g. clicks on a choice control),and when parameters change.
      That works fine.
      But I also need to refresh the Attribute Manager description when my tool state changes during runtime (for example inside MouseInput(), or after some internal state update).
      I tried calling : EventAdd(EVENT_FORCEREDRAW);
      …but this does not cause GetDDescription() to be called again for my tool.
      So my questions are:
      What is the correct way to force GetDDescription() to run again for a ToolData plugin?
      Is there a specific event or API call I should use to tell the Attribute Manager to rebuild the description?
      Any best practices for dynamically updating tool descriptions at runtime?
      Thanks!
        Hey @Viktor-Velicko I'm busy this week and I will be able to have a deeper look at it only next week.
        With that's said here are few hints (at least what I would try first).
        • Send COREMSG_CINEMA_FORCE_AM_UPDATE.
        • Call GeUpdateUI.
        • It may not be possible at all to do during a drag operation (but I will ask about it only once the two previous solutions are confirmed to not work, which I do not have the time to test right now).
        Maxime
          Viktor Velicko
          Thank you, Maxim.
          No further testing is needed—this works very well.
          I’m calling it from the ToolData::MouseInput() callback at the end, which is sufficient. The panel updates nicely after the mouse event finishes (on mouse up).
          SendCoreMessage(COREMSG_CINEMA, BaseContainer(COREMSG_CINEMA_FORCE_AM_UPDATE));
          GeUpdateUI();
          You can close this thread.
          Thanks!
          V.
