    Render to picture viewer from plugin crash
    windowspython2025
    2 Posts 2 Posters 779 Views 1 Watching
    • P Offline
      popandchop
      Hey guys,
      This is probably a very simple question and i suspect to do with threading. I have a little workflow tool i'm working on and have this Render to Picture Viewer button.
      The code behind this button is as simple as this
      if id == BTN_SceneRenderPictureViewer:
                  self.PrintStatusMessage('Rendering to Picture Viewer.')
                  self.Close()
                  c4d.StopAllThreads()
                  time.sleep(0.1)  # Wait a bit to ensure the dialog is closed before rendering
                  c4d.CallCommand(12099)
      However this causes Cinema to crash. I've tried recreating the Render to Picture viewer function but this was seems much simpler so would be great for it work - any help appreaciated πŸ™‚
      Thanks alot,
      Will
        ferdinand @popandchop
        Hello @popandchop,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
        About your First Question
        The question is impossible to answer in this form, we would need something concrete (a plugin and a scene which crashes for you) or a time stamp of a submitted crash report.
        What you do there is this code snippet looks a bit unusual. I assume from the screen shot that you are inside a GeDialog, the code looks a bit like this could be GeDialog.Command or Message. Please read the Threading Manual, invoking an event, e.g., a command, is forbidden off-main thread. But in a dialog you are usually on the main thread (but you should still check with c4d,.threading.GeIsMainThread()). What is also rather odd, is what you call there:
            self.Close()             # This will shut down the dialog, think of it as a return statement.
            c4d.StopAllThreads()     # This is generally the biggest nuke you can drop on Cinema 4D and should
                                     # be avoided. But in this context (a dialog that has been closed) this
                                     # seems extra dangerous. Why are you doing this?
            time.sleep(0.1)          # This makes things even worse, as it increases the chance that the dialog
                                     # has been destroyed before the last line of this function has been
                                     # executed. If I had to guess, this is probably crashing here.
        I assume you hve a modal dialog and that you run into issues with opening the picture viewer due to that? Either make your dialog non-modal (in GeDialog.Open) and then first send the command and then close the dialog or keep using a modal dialog and detach the code from the instance of the dialog.
        class MyModalDialog (c4d.gui.GeDialog):
            BTN_SceneRenderPictureViewer: int = 1000
            def Command(self, cid: int, msg: c4d.BaseContainer) -> bool:
                if cid == MyModalDialog.BTN_SceneRenderPictureViewer:
                    MyModalDialog.CloseAndAction(self, 12099)
            @staticmethod
            def CloseAndAction(dlg: "MyModalDialog", cid: int) -> None:
                """Closes the passed dialog and executes a command.
                Args:
                    dlg (MyModalDialog): The dialog instance to close.
                    cid (int): The command ID to execute after closing the dialog.
                if not dlg or not c4d.threading.GeIsMainThread():
                dlg.Close()
                c4d.CallCommand(cid)
            dlg = MyModalDialog()
            dlg.Open(c4d.DLG_TYPE_MODAL, defaultw=400, defaulth=300, title="My Modal Dialog")
