    Issue: CommandData Plugin Compilation Errors in Cinema 4D 2025.1.0 SDK
    windows2025c++
    3 Posts 3 Posters 973 Views 2 Watching
    • S Offline
      skibinvitaliy
      Hi.
      I'm new to this field, so don't judge me too harshly.
      I am trying to create a simple CommandData plugin for Cinema 4D 2025.1.3 following the SDK documentation.
      However, I am encountering multiple compilation errors, despite the fact that all example projects from the SDK compile and work correctly.
      Errors:
      Here are some of the main errors I'm facing:
      C2504: 'CommandData': base class undefined
      C2086: 'int Bool': redefinition
      C3646: 'Execute': unknown override specifier
      C2065: 'GeDialog': undeclared identifier
      C2065: 'BaseDocument': undeclared identifier
      C2096: 'Bool': A data member cannot be initialized with a parenthesized initializer
      What I Have Checked:
      All SDK example projects compile successfully.
      My project is in the same solution as the example projects.
      I'm using Visual Studio 2019 with /std:c++17, as recommended in the SDK.
      The SDK headers and libraries are correctly linked.
      CommandData should be defined in c4d_commanddata.h, but the compiler doesn't recognize it.
      Question:
      Has something changed in how CommandData plugins should be structured in Cinema 4D 2025?
      Do I need to include additional headers or modify my implementation?
      Any guidance or better tutorial would be greatly appreciated.
      TIA
      Windows 11/64, VS 2019, SDK 2025_1_0, Cinema 4D 20251.3
      S 1 Reply Last reply Reply Quote 0
      • S Offline
        spedler @skibinvitaliy
        Hi @skibinvitaliy
        There's a few things to watch out for here. First, you will need to include at the very least the file c4d.h from the framework, if this is missing that might account for the undeclared identifiers.
        Assuming you're doing that, you must either use the cinema namespace or specifically qualify function declarations etc. If you don't, the compiler won't recognise the C4D functions and objects as valid. The manual explains how to do this, it's not difficult - just an extra step to take which I keep forgetting because it's new to R2025.
        The error 'int Bool' redefinition is because what it looks like you're doing there is declaring a variable named 'Bool' to be of type 'int'. But 'Bool' cannot be a variable, it's a variable type (actually a typedef defined by the SDK) so the compiler thinks you are redefining it, which isn't allowed.
        These are all just guesses though without seeing any code, but the first thing to look at is the namespace. Catches me out every time.
        Steve
        ferdinandF 1 Reply Last reply Reply Quote 1
          ferdinand @spedler
          Hey @skibinvitaliy,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
          About your First Question
          No one is judging you here, problems are part of the game and what we are here for to help with 🙂 . But please familiarize yourself with our forum rules, such question should be accompanied by example code and the version you are migrating from, as we otherwise mostly have to guess what is going wrong.
          I am assuming you are migrating from a pre-2025 SDK, that is at least what your errors imply. With 2025 we introduced our cinema namespace. Please follow our Migrating Plugins to the 2025.0 API guide. You are likely just missing a couple of using namespace cinema; at the top of your files.
