    How to store "cached" data in the document from the scenehook?
    c++
    17 Posts 2 Posters 3.9k Views 2 Watching
      ferdinand @Havremunken
      Hey @Havremunken,
      first of all, questions are never annoying to us. You are right, I incorrectly used there an outdated signature of NodeData::GetBranchInfo. I removed my pseudo code example from above, as I decided today, that I will just write a code example for branching for the SDK (the Asset Container thing from below which has the custom branch net.maxonexample.branch.assetcontainer with a cube and a sphere object stored in it).
      Just posting here so that you do not think we overlooked you, I will post the example on Monday, as I still have to make sure the example works properly in all aspects. For now I will sail of into the weekend 🙂
        Havremunken
        Thank you so much, Ferdinand, I look forward to that! And enjoy the well-deserved weekend in the mean time! 🙂
          Hey @Havremunken,
          I have posted the code example which will be shipped with an upcoming C++ SDK here. The example does not do 100% what you are trying to do, the node type implementing the custom branch is for example an object and not a scene hook, as I had to keep common applicability a bit in mind.
          But it realizes a node which inernalizes other scene elements in a custom branch of itself, and should get you at least going. When you still need help with your specific case, please ask questions in this thread. When you have generic branching questions tied to the example, please use the other thread.
            Havremunken
            "Thank you" seems poor and inadequate for that fantastic example, but I don't have the English vocabulary to go beyond that!
            I have read through the example once, and I think I understand it. Since this has been a real Monday (tm), I'm going to let this simmer in the brain for a day or two, and then use the techniques you demonstrate to add GetBranchInfo etc. to my scene hook. Both the example and the video were great at explaining the steps needed to get "extra" information into the document, and are much appreciated!
            So while it does not express the full extent of my gratitude, once again - thank you!
              Havremunken
              Hi Ferdinand,
              I have worked on fitting your example into my project. As you know, there are two major differences that I needed to account for; first, I am doing this in a Scene Hook, and second, I am not keeping Cinema 4D primitives in my BranchInfo, I am keeping URLs and their contents. So I had to adapt.
              First I implemented GetBranchInfo in my scene hook. It is more or less a copy of yours.
              maxon::Result<Bool> GetBranchInfo(const GeListNode* node, const maxon::ValueReceiver<const BranchInfo&>& info, GETBRANCHINFO flags) const override
              	iferr_scope;
              	yield_scope;
              	NodeData::GetBranchInfo (node, info, flags) yield_return;
              	if (!(flags & GETBRANCHINFO::ONLYWITHCHILDREN) || _assetHead->GetFirst())
              		info (
              			BranchInfo{
              				MAXON_REMOVE_CONST (this)->_assetHead,
              				"clever.unique.name.changed.to.protect.the.innocent"_s,
              				ID_MORPHINETABLE_URLCACHE_ASSETNODE,
              				BRANCHINFOFLAGS::NONE
              			}) yield_return;
              	return true;
              This will come into play a little later.
              In my scenehook I also implemented the Read, Write and CopyTo (I understand how these go together, but will CopyTo ever really be used in a scene hook? I placed a breakpoint in the function and it didn't get called yet).
              First of all; Since I need something to store my data in, I decided on creating a NodeData subclass like this - the simplest implementation I could imagine getting away with:
              class UrlCacheAssetData : public NodeData
              	INSTANCEOF (UrlCacheAssetData, NodeData)
              private:
              	maxon::String _url;
              	maxon::String _data;
              	static NodeData* Alloc()
              		return NewObjClear (UrlCacheAssetData);
              	static Bool RegisterAssetDataPlugin()
              		return RegisterNodePlugin (ID_MORPHINETABLE_URLCACHE_ASSETNODE, "UrlCacheAssetDataPlugin"_s,
              		                           PLUGINFLAG_SMALLNODE, UrlCacheAssetData::Alloc, nullptr, 0, nullptr);
              	void SetData(String url, String data)
              		_url = url;
              		_data = data;
              	String GetUrl() const
              		return _url;
              	String GetData() const
              		return _data;
              So when the user enters a new URL into my plugin, I have added code to add a new asset as such:
              auto node = AllocSmallListNode (ID_MORPHINETABLE_URLCACHE_ASSETNODE);
              auto const assetData = node->GetNodeData<UrlCacheAssetData>();
              if (assetData != nullptr)
              	assetData->SetData (*task->url, loadedData);
              	_assetHead->InsertLast (node);
              	_currentCacheSize++;
              _assetHead is declared the same way you did in your example. _currentCacheSize is a running count of the number of asset nodes we have.
              Ok, time to save a document (with a plugin that has added at least one item in the cache). Here is my Write implementation for the scene hook:
              Bool Write(const GeListNode* node, HyperFile* hf) const override
              	if (!_assetHead || !hf)
              		return false;
              	if (!hf->WriteInt32 (_currentCacheSize))
              		return false;
              	auto current = _assetHead->GetFirst();
              	while (current)
              		auto const assetData = current->GetNodeData<UrlCacheAssetData>();
              			if (!hf->WriteString (assetData->GetUrl()))
              				return false;
              			if (!hf->WriteString (assetData->GetData()))
              				return false;
              		current = current->GetNext();
              	return SceneHookData::Write (node, hf);
              As you see, my thought is that I first write an integer saying how many url/content pairs I have, then I loop through the asset nodes and write them to the file. I couldn't think of another way to do this, as I do not have the luxury of dealing with objects that already have the WriteObject() functions implemented. I am of course expecting that my way is not the optimal way, or even correct. 🙂
              I step through it using the debugger and all seems to work the way I expect. Ok, I close the file and then try to reopen it using C4D.
              Here is my Read implementation:
              Bool Read(GeListNode* node, HyperFile* hf, Int32 level) override
              	SUPER::Read (node, hf, level);
              	iferr_scope_handler
              		return false;
              	if (!hf || !_assetHead)
              		return false;
              	_assetHead->FlushAll();
              	if (!hf->ReadInt32 (&_currentCacheSize))
              		return false;
              	for (auto i = 0; i < _currentCacheSize; i++)
              		auto newNode = AllocSmallListNode (ID_MORPHINETABLE_URLCACHE_ASSETNODE);
              		auto const assetData = newNode->GetNodeData<UrlCacheAssetData>();
              			String url;
              			if (!hf->ReadString (&url))
              				return false;
              			String data;
              			if (!hf->ReadString (&data))
              				return false;
              			assetData->SetData (url, data);
              			_assetHead->InsertLast (newNode);
              	return true;
              I step through it using the debugger and again it works as expected; I read the integer specifying the number of cache items, then loop through that amount of times to read the items. The items are read successfully, containing the expected data! Amazing!
              However, at some point after my Read method is exited, I get a crash. This crash happens while Cinema is executing my GetBranchInfo() code above, specifically the info(...) yield return part. At this point it gets a little difficult for me to look into. I understand that a value is pointing to the wrong place, with a very suspicious value (the "opposite" of a null pointer, so to speak), but I can't tell where this value is coming from.
              Exception details:
              Exception thrown at 0x00007FF8E8427C10 (c4d_base.xdl64) in Cinema 4D.exe: 0xC0000005: Access violation reading location 0xFFFFFFFFFFFFFFFF.
              This is refering to a location in delegate.h in the SDK where the following code can be seen:
              /// Forwards the call (invokes the stub function for a callable).
              MAXON_ATTRIBUTE_FORCE_INLINE RESULT operator ()(ARGS... args) const
              	StubPtrType stub = StubPtrType(_stubPtr);
              #ifdef PRIVATE_MAXON_MTABLE_PTMF
              	return (reinterpret_cast<Delegate*>(_objectPtr)->*stub)(std::forward<ARGS>(args)...);
              #else
              	return stub(_objectPtr, std::forward<ARGS>(args)...);
              #endif
              Line 761-772 in my 2024 SDK. I don't know where exactly the 0xFFF... is coming from but it is not the stub/_stubPtr and the exception happens in the line with the reinterpret_cast.
              The call stack does not tell me a lot apart from this happening while Cinema is running my GetBranchInfo:
              I realize of course that debugging this based on a forum post is hopeless - unless the 0xFFFF... value could be caused by only one very well known thing, I expect you would need my complete code for this? It changed quite a bit since last time.
              I am quite sure that there is something that is not properly initialized or something along those lines, since this happens only when I try to open a document saved with my branch info in it. Oh, and for completeness, my asset head is declared as a private instance variable in my scene hook like this:
              AutoAlloc<GeListHead> _assetHead;
              And I also borrowed from your init code and put it in the same class.
              Bool Init(GeListNode* node, Bool isCloneInit) override
              	if (!_assetHead)
              		return false;
              	_assetHead->SetParent (node);
              	return SUPER::Init (node, isCloneInit);
              If you want me to send you the code, just let me know. If you want me to change or test anything else, the same. And if I am completely off track with my asset implementation, doing something that couldn't possibly work - please don't be afraid to tell me. I'm a big boy, I can take it. 😁
              Thanks again!
                Hey, just as an FYI, I have seen your question(s) here. I will try to answer within the week but have a rather loaded plate right now. I will answer latest next week.
                ferdinandF 1 Reply Last reply Reply Quote 1
                  ferdinand @ferdinand
                  Hey @Havremunken,
                  In my scene hook I also implemented the Read, Write and CopyTo (I understand how these go together, but will CopyTo ever really be used in a scene hook? I placed a breakpoint in the function and it didn't get called yet).
                  Yes, you really must do this. NodeData::CopyTo is the plugin layer endpoint for C4DAtom::GetClone and Cinema 4D clones scenes and scene elements all the time. A good example is rendering, for everything but in editor renderings, Cinema 4D will clone the whole document which is about to be rendered. When you then do not implement NodeData::CopyTo your scene hook in the cloned scene will not have its internal data, e.g., the GeListHead that holds the assets will be nullptr. And while it is true that scene hooks are unlikely to be cloned directly due to to their singleton-like nature, there is no guarantee that not some backend system does clone scene hooks for some technical reason. You having set a breakpoint does not mean much, as it is literally impossible to test all the scenarios where Cinema 4D wants to draw a copy of your node. This can then all lead to access violations and more.
                  Ok, time to save a document ...
                  In your code, I do not see you serializing your custom branch and the manual allocation (and serializing) of child nodes is not so good:
                      // Big NO-NO, never manually allocate nodes in deserialization. Technically possible but should
                      // be avoided.
                        String url;
                          return false;
                        String data;
                          return false;
                        // not good, `newNode` has a different GeMarker (think of it as the UUID of the node) than the
                        // node in the original scene. you might also miss data which Cinema 4D has written into that
                        // original node.
                    return true;
                  You must really must do what I show in my example, this will automatically serialize all the data stored in the branch. As I write in my example C4DAtom::ReadObject and WriteObject should be taken with grain of salt. 'Object' is meant here in the sense of 'element'. You can write every type of C4DAtom with this, e.g., also our custom GeListHead and all its children.
                      // Call the base implementation, more formality than necessity in our case.
                      SUPER::Read(node, hf, level);
                      if (!_assetHead->ReadObject(hf, true)) // Deserialize the data of our custom branch.
                        return false;
                      return true;
                      SUPER::Write(node, hf);
                      if (!_assetHead->WriteObject(hf)) // Serialize the data of our custom branch.
                        return false;
                      return true;
                  When you have then specialized data in the nodes in your branch (UrlCacheAssetData in your case), you can do three things:
                  1. BAD: Store the extra data with the scene hook as you do in your code where you write the strings into the hyper file chunk of the scene hook. While this technically works and can be done intentionally for performance reasons, storing data from children in their parent is not so good, as the tends to become very complicated very quickly.
                  2. BETTER: Store the data in the hyper file chunk of each node which owns the data, i.e., overwrite UrlCacheAssetData::Read, ::Write, and ::CopyTo.
                  3. GOOD: When you only want to store atomic data which can be expressed in a data container and you own the node implementation, I would just store it there, as you then do not have to do all the serialization dance in UrlCacheAssetData. E.g., this:
                  // PSEUDO CODE, not compiled or tested, take with a grain of salt.
                  // A node whose implementation we own, i.e., we own the address space of its data container and can
                  // write everywhere we want to.
                  BaseList2D* asset = BaseList2D::Alloc(ID_MORPHINETABLE_URLCACHE_ASSETNODE);
                  // Just write the data into the node.
                  BaseContainer* data = asset->GetDataInstance();
                  data->SetString(ID_MORPHINETABLE_URL, "www.google.com"_s);
                  data->SetString(ID_MORPHINETABLE_DATA, "Bob's your uncle."_s);
                  // Insert the node into the branch of your scene hook. Its data will now be stored with the scene.
                  // You can of course also go the inverse route to read data or modify the data by getting the node
                  // and then getting its data container again.
                  // We technically can also do the same for nodes where we do not own the implementation. Here we just
                  // store the data in a custom container under a custom plugin ID.
                  // We do not own the cube impl.
                  BaseList2D* cube = BaseList2D::Alloc(Ocube);
                  // A custom plugin ID we registered to store alien data in a collision free manner in Ocube.
                  const Int32 pid = 123456789;
                  // Create a container (with #pid as its ID) and just write some data into it, the IDs do not matter here.
                  BaseContainer bc (pid);
                  bc.SetString(0, "www.google.com"_s);
                  bc.SetString(1, "Bob's your uncle."_s);
                  // Get the data container of the node.
                  BaseContainer* data = cube->GetDataInstance();
                  // Write the data making sure we do not overwrite native data.
                  // There is no native data at all.
                  GeData nativeData;
                  if (data.FindIndex(pid, nativeData) == NOTOK)
                    data.SetContainer(pid, bc);
                  // There is already data and it is of type #BaseContainer, and it is a container marked with the
                  // id #pid, so it is one of our containers, we can safely overwrite things.
                  else if (nativeData.GetType() == DA_CONTAINER && nativeData.GetContainer().GetId() == pid)
                  // There is already native data at #pid and it is not ours, we are screwed. This is not impossible
                  // to happen as some nodes dynamically write data into their data container (just as we did above
                  // for #ID_MORPHINETABLE_URLCACHE_ASSETNODE), but it is quite unlikely to happen in the range of
                  // plugin IDs.
                  else
                    CrashAndPretendItWasNotOurFault();
                  Finally, 0xFFFFFFFFFFFFFFFF does have a special meaning. It is the end of the 64 bit address space and operating systems/debuggers usually use this address when an access violations occurs. I.e., you have pointer p which points to some point in memory (and is therefore not the nullptr) which holds a FooThing. We then try to call p->Bar() (i.e., FooThing::Bar). But the FooThing at p is long deleted, the memory at p with the size of FooThing is either empty or does nor match the layout of FooThing. An access violation happens, the fireworks begin. TLDR: 0xFFFFFFFFFFFFFFFF is an alias for a corrupted/dangling pointer.
                  In your case probably something with the irregular instantiated ID_MORPHINETABLE_URLCACHE_ASSETNODE node from your NodeData::Free is going wrong. Or something else, I cannot really tell without the full source code. When you decide to share your code, please ideally share your project, not just some .h/.cpp files. You can share code confidentially via [email protected].
                    Havremunken
                    Hi @ferdinand,
                    First, thanks once more! I loved the more general example you made, but since it showed how to store full "Cinema 4D objects" into the branch and not my simplistic data needs (just two strings), I had to make some assumptions about how to do things. Once more you showed me they were bad assumptions to make. 🙂
                    About the CopyTo, I do get the reasons, and I had actually implemented it, but it was also implemented based on the bad assumptions, so I am rewriting it as well. And as for the 0xFFF.. thing I realised of course that this "magic" value of all bits set was not happening by accident, I just could not tell how it happened. But since this happened as another consequence of my poor assumptions about how to implement data storage in a branch, I'll ignore it for now. If it is still there after the code is fixed, then perhaps it is relevant to look at again.
                    Your new code example above does shed a lot more light and give me an expanded understanding of how this should work, but like the story where you always go 50% of the remaining distance to the goal, I feel like I am SO close but never getting all the way there. I am sure there are only details missing however. 🙂
                    I updated my Read and Write as you instructed, and I abandoned creating all the UrlCacheAssetData nodes manually (I don't want to be a bad citizen after all). So I aim for your point number 3 to store my two strings per node. While it would be fun to do like in the second half of your example and store it in a cube, I used the first part to create the BaseList2D, get the data instance, and then set the strings. I am still registering ID_MORPHINETABLE_URLCACHE_ASSETNODE using RegisterNodePlugin - as an experiment I tried not registering it at all, but then BaseList2D::Alloc(ID_MORPHINETABLE_URLCACHE_ASSETNODE) returned a nullptr which I guess is to be expected. When it is registered I get a real object (e.g. not nullptr), and I also get a not-nullptr when I do asset->GetDataInstance(). However, when I then do data->SetString(ID_MORPHINETABLE_URL, task->url); Cinema 4D completely freezes. The only thing I can really do at that point is to Shift-F5 to stop the Visual Studio debugging session. Edit: This happens when I set the data, i.e. when the user changes the URL parameter in my plugin and the scene hook has loaded the URL contents. So this happens before the whole GetBranchInfo / Read / Write process.
                    Could this be because RegisterNodePlugin is the wrong registration method for my asset container? And since in this case I only really need the BaseContainer of the thing to store the two things, how elaborate does the UrlCacheAssetData class really need to be? What you are allocating in your (untested and uncompiled) example is just a BaseList2D, but do I need to make a subclass of that in order to give it the ID_MORPHINETABLE_URLCACHE_ASSETNODE id so I can identify it in my branch for reading and writing? Edit: When I step through in the debugger, the BaseList2D::Alloc() does not invoke my UrlCachetAssetData::Alloc static function as I suspected, which is why I am wondering what role the UrlCacheAssetData class REALLY plays in this scenario beyond registering "something" with the ID_MORPHINETABLE_URLCACHE_ASSETNODE node.
                    I am of course also open to the SetString freeze happening for an entirely different reason, but since I don't know how much my UrlCacheAssetData (inheriting from NodeData) implementation matters when we are creating a BaseList2D with its' ID like you are showing, it seems likely that this is another thing I screwed up.
                    I will happily pack up the project again if this is impossible to solve without seeing full source. Is my project subdirectory enough, or would you like the whole sdk directory to be able to reproduce 100% what I am seeing?
                    Thanks again, and have a great weekend when the time comes!
                      Hey,
                      Great to hear, when you go with route 3, the 'good' approach, remember that IDs below 1000 are reserved for Cinema 4D, so ID_MORPHINETABLE_URL could be a symbol vor the integer values 1000, 1002, 10003, or 100004, etc., but not 500 or 999.
                        Havremunken
                        Hi Ferdinand,
                        Yes, I remember reading about that, so the IDs for this container data is 5060 and 5061 (I work in IP telephony as my day job so this is surely no coincidence), but I even tried to move them to 50060 and 50061 and the freeze still happens.
                        I will pack up the project shortly and email it in. 🙂
