    res file, formatting, line ending, or encoding ?
    windowsc++python
    11 Posts 3 Posters 1.3k Views 2 Watching
      mogh
      Dear Developers,
      does anybody know what res files need to be (on Win 11, vs-Code)
      I was banging my head on the res files of my copied Tpylookatcamera (SDK Tag Plugin example R13) Python plugin and could not figure out why my copied version does not find the variable IDs but the "original" could.
      After several days editing my version I tried to edit the original Version (just a different name string for testing) an boom it also stopped working.
      So as far as i understand the res files seem to have a different encoding, line ending , ... or whatever vs-code does to the files ?
      Any idea or am I on the wrong track?
      I am learning to code on R20 but coding for R2025 so shame on me it might also be a R20 thing but its odd anyway.
      Thank you
      cheers
      S 1 Reply Last reply Reply Quote 0
      • S Offline
        spedler @mogh
        @mogh I think it's unlikely to be anything VS Code does. Millions of people use it and I've never heard of a problem caused by whatever line endings it adds.
        Much more likely is an error in the resource files. Earlier versions of Cinema were incredibly sensitive to mistakes in the resource and the stock response is to show that message. Misleadingly, it says the error is in the .res file but it could actually be in the matching .h. or .str files.
        The most common errors I find are:
        • the name of an element in the .res file doesn't match with any in the .h or.str files, so if you change one you need to change the others
        • there's a formatting error in the .res file - a missed semi-colon, comma, or mismatching parentheses or curly braces
        • the 'CONTAINER' or 'NAME' strings at the start of the .res file don't match the 'STRINGTABLE' line in the .str file or the line which follows it
        There are probably other causes but these are the commonest ones (IMO). If you altered the name of an element .res file of your plugin did you change the .h and .str files to match? And if you did, did you alter the Python source code to use the new name?
        Steve
          mogh
          Thank you for the reply,
          • I learned that all the "names / files" have to be the same ... Filename, NAME, CONTAINER, STRINGTABLE
          • The semi-colon is a thing I tried in several configs, and as soon as you touch the files you need them but the strange thing is that the original SDK example has non! The error above is from a missing semicolon. (its gone now with the semicolon after the curly brackets)
          • I changed the ID name and replaced the name in all corresponding files ... still the new variable name is not "found" by c4d.
          Just as a sanity check I also tried removing a character
          PYLOOKATCAMERA_PITCH_A -> error
          PYLOOKATCAMERA_PITCH -> works
          PYLOOKATCAMERA_PITC -> error
          Res, Str, H Files
          enum
              // End of symbol definition
              _DUMMY_ELEMENT_
          CONTAINER Tpylookatcamera
          	NAME Tpylookatcamera;
              INCLUDE Texpression;
              GROUP ID_TAGPROPERTIES
          		BOOL PYLOOKATCAMERA_PITCH_A { };
          STRINGTABLE Tpylookatcamera
          	Tpylookatcamera         "Py - Look At Camera";
              PYLOOKATCAMERA_PITCH_A    "Change Pitch Rotation";
          #ifndef _Tpylookatcamera_H_
          #define _Tpylookatcamera_H_
              enum
                  PYLOOKATCAMERA_PITCH_A     = 1000
          #endif
          snippet:
          self.InitAttr(node, bool, c4d.PYLOOKATCAMERA_PITCH_A)
          node[c4d.PYLOOKATCAMERA_PITCH_A] = True
          Error:
          AttributeError: 'module' object has no attribute 'PYLOOKATCAMERA_PITCH_A'
          • S Offline
            spedler @mogh
            @mogh Ah, this is the old symbol cache bug/feature. I'd forgotten about that. With Cinema not running, go into the prefs folder - you can get the location by running Cinema, opening the Preferences dialog, and click 'Open Preferences Folder...'.
            In that folder you'll see a file called 'symbolcache', probably with today's date. Delete that file, then run/restart Cinema and all should now work with your revised resource files.
            AFAIK this was only a problem with Python plugins, not C++. I've tested this in R19, not R20, but my guess is that it's the same in R20.
            (Edit - yes, same in R20.)
            Steve
              mogh
              @spedler Thank you for your time you put into this,
              I managed to get the "original" running with a different ID Name after deleting (.../prefs/symbolcache )
              My own copy with Filename, NAME, CONTAINER, STRINGTABLE, ID Name still bugs out.
              I am probably blind 😕
              mogh
              enum
                  _DUMMY_ELEMENT_
              #ifndef _curvaturetools_H_
              #define _curvaturetools_H_
                  enum
                      CTBOOL      = 2001
              #endif
              CONTAINER curvaturetools
              	NAME curvaturetools;
              		BOOL CTBOOL { };
              STRINGTABLE curvaturetools
              	curvaturetools     "Py - Look At Camera";
                  CTBOOL       "Change Pitch Rotation";
              • S Offline
                spedler @mogh
                @mogh If you are using the same code but just different resource files, did you remember to change the resource name in the RegisterTagPlugin() function?
                Steve
                  mogh
                  No the SDK Example has no
                  res (Optional[c4d.plugins.GeResource]) – The optional resource.
                  for RegisterTagPlugin ...
                      c4d.plugins.RegisterTagPlugin(id=PLUGIN_ID,
                                                    str="Py - LookAtCamera",
                                                    info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE,
                                                    g=LookAtCamera,
                                                    description="Tpylookatcamera",
                                                    icon=bmp)
                  • S Offline
                    spedler
                    What I meant was, if your resource files are now named curvaturetools.res/h/str then RegisterTagPlugin() must contain the ‘description’ parameter to be “curvaturetools” not “Tpylookatcamera”.
                    Steve
                      mogh
                      Thats it !
                      Thank you @spedler
                      • S Offline
                        spedler
                        Excellent. Glad you got it working okay.
                        Steve
                          Thanks for helping out @spedler!
