    New Condition Naming in Attribute Manager
    c++r25
    3 Posts 2 Posters 485 Views 1 Watching
    • D Offline
      d_schmidt
      Hello, I noticed there seemed to be a new 'name' feature with the Condition object.
      Is it possible to make use of it in a plugin?
      'Condition' is just the object's Name, but I can't figure out how 'distance' is set.
      Dan
        ferdinand @d_schmidt
        Hey @d_schmidt,
        Thank you for reaching out to us. That feature has existed since Pyro was introduced but at the same time it is also an internal feature, i.e., a feature of which we publish the components, but which we do not support in public usage. To realize a node which supports name additions, you must register it with the flag OBJECT_CUSTOM_NAME_ADDITION:
        RegisterObjectPlugin(ID_MY_PLUGIN, GeLoadString(IDS_MY_PLUGIN), otherFlags | OBJECT_CUSTOM_NAME_ADDITION, MyPlugin::Alloc, "omyplugin"_s, nullptr, 0);
        Reading or writing to the custom name is then realised via the node message MSG_GETCUSTOM_NAME_ADDITION. I am showing the write access in C++:
        Bool MyPlugin::Message(GeListNode* node, Int32 type, void* data)
          switch (type)
            // Something, for example the Object Manager, wants to know the addition to the name. The
            // message data is just an empty string. The plugin should return the addition to the name.
            case MSG_GETCUSTOM_NAME_ADDITION:
              *reinterpret_cast<String*>(data) = "Hello World"_s;
              break;
            default:
              break;
        And since nothing is safe from @m_adam πŸ˜„ , I just found out that he wrapped the reading part for Python (cannot see the writing part handled in Python). Since you cannot cast arbitrary data in Python, we must use a dictionary as the data container.
        • D Offline
          d_schmidt
          Thank you so much! I couldn't ask for a more thorough response.
          Dan
