    How to set the active documents preview image
    windowspython
    2 Posts 2 Posters 650 Views 1 Watching
      MMayrh
      Hey,
      I am trying to code a python script that automatically renders the active document and sets the preview for the document to that rendered image.
      The set parameter that I use wants a BaseList2D object instead of a bitmap and I have no idea how I could convert that info. (Or maybe im dead lost already šŸ˜“ ) Maybe you can help?
      Thanks in advance
      from c4d import documents
      import os
          rd = doc.GetActiveRenderData()
          # Set resolution
          rd[c4d.RDATA_XRES] = 640
          rd[c4d.RDATA_YRES] = 480
          # Render document
          bmp.Init(640, 480)
          if c4d.documents.RenderDocument(doc, rd.GetDataInstance(), bmp, c4d.RENDERFLAGS_EXTERNAL) != c4d.RENDERRESULT_OK:
              raise Exception("Rendering failed")
          # Save bitmap to disk for manual setting of preview later
          temp_filepath = os.path.join(os.path.expanduser("~"), "temp_preview.png")
          if bmp.Save(temp_filepath, c4d.FILTER_PNG, c4d.BaseContainer()) != c4d.IMAGERESULT_OK:
              raise Exception("Failed to save bitmap")
          # Display the bitmap for verification
          c4d.bitmaps.ShowBitmap(bmp)
          # Set the rendered Bitmap bmp as the preview of the document
          doc.SetParameter(c4d.DOCUMENT_PREVIEW_IMAGE, bmp, c4d.DESCFLAGS_SET_0) #<--- cant figure out how to get this working
      Version: Cinema4D 2025.0.2
      OS: Windows 11
      Python
        ferdinand @MMayrh
        Hey @MMayrh,
        Thank you for reaching out to us. This is not how this parameter works. The parameter DOCUMENT_PREVIEW_IMAGE is of data type BitmapButtonStruct, not of BaseBitmap.
        The documentation is a bit misleading here. This is not the document preview bitmap, but sort of the preview bitmap delegate. I.e., an entity that is used to retrieve a preview bitmap (for a document in this case). A BitmapButtonStruct wraps a node, an ID, and a dirty flag.
        This parameter does not make too much sense in the Python API, here is what the C++ API does when the parameter is access for a document:
        I.e., it returns itself (the doc), the ID of the parameter (DOCUMENT_PREVIEW_IMAGE) and the dirty state of its internal current preview bitmap as the BitmapButtonStruct bbs. What you could technically try, is implement a node, e.g., an object, and then set that object as the preview provider for a document. Your node would for that have to implement MSG_DESCRIPTION_GETBITMAP, because that is what effectively will be called. But that is all very theoretical, DOCUMENT_PREVIEW_IMAGE is largely unused in our code base, and I do not see any implemnation for the SetParameter part. So, the document will likely just ignore you trying to overwrite its preview provider. There could be some base implemenation kicking in, but I doubt it.
        But what you definitely cannot do, is just set there a bitmap to overwrite the preview image of the document (assuming that was what you wanted to do). That would also not make too much sense since a document is constantly recalculating its preview image. So, on the next update that image would be gone (if it would work like that).
