    object change in C.O.F.F.E.E
    7 Posts 0 Posters 665 Views
      On 29/02/2004 at 23:41, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      ---------Hi,
      Can you help me writing a plugin?
      I'm workin on a Poser import plugin that works fine until Curious Labs update to service pack 4.
      Here is my problem.
      I just want to now (if it is possible) how to refresh a command in a C.O.F.F.E.E plugin.
      for example: I change the name of an object and I want to see the
      change in the object manager directly.
      Until now, the change is activated when I leave the plugin.
      I have the same problem loading an object inside a plugin.
      I cannot use the object directly, in the plugin. but when I leave the plugin, the object is well loaded. <SCRIPT language=javascript>postamble();_<_Script_>_
        On 01/03/2004 at 15:18, xxxxxxxx wrote:
        From what you say it sounds like GeEventAdd(MSG_UPDATE) is what you want.
          On 01/03/2004 at 21:56, xxxxxxxx wrote:
          No that doesn't work
          Here is part of my code:
                  filename = GeGetStartupPath();
                  filename->FileSelect("Please select a OBJ file.", FALSE);
          _<_x-tab_>_bsp;  _<_x-tab_>_ument(filename);
             _<_x-tab_>_n_<_x-tab_>_sp;
           &nbs;_<_x-tab_>_     _ventAdd(DOCUMENT_CHANGED);
          &nb;_<_x-tab_>_;     _<_x-tab_>_/X-TAB>GeEventAdd(NEW_ACTIVE_OBJECT);
          _p;      &_<_x-tab_>_X-TAB>GeEventAdd(ACTIVE_OBJECT_CHANGED);
          _<_x-tab_>_AB>        vDoc->Message(MSG_UPDATE);
                  GeEventAdd(MSG_UPDATE);
          // This is a multi-part wavefront object
          // The Object normally is loaded, I can see the progress ba_<_x-tab_>_ But It doesn't show nor exist at this stage_<_x-tab_>_BR>       &nb;_<_x-tab_>_TAB>var _<_x-tab_>_oc-&g;_<_x-tab_>_rstObject();
          // Obj is NULL&nb;_<_x-tab_>_;
          _>       &_<_x-tab_>_-T_<_x-tab_>_bj != NULL)
             &nbs;_<_x-tab_<_x-tab_>_p;  {
           &nbs;_<_x-tab_>_     _<_x-tab_>_>      _<_x-tab_<_x-tab_>_var ObjN = Obj->GetName();
          _p;    _<_x-tab_>_nbsp;    _<_x-tab_>_bsp;   println("Loaded=", ObjN);
          // And the rest of my program suppose_<_x-tab_>_rk on the loaded object does nothing...
          /_<_x-tab_>_ the end, after my "OK Message _<_x-tab_>_he Object is loaded.
          &nb;_<_x-tab_>_;     filename = GeGetStartupPat_<_x-tab_>_>      _<_x-tab_>_bsp;filename->FileSelec_<_x-tab_>_se select a Mat file.", FALSE);
          _       File->Open(filename, GE_READ);
                  .... Rest of my program
          // If I load_<_iFrame_>_art and remove the OBJ loading code, my program works fine
          _fLogFrame style="DISPLAY: none" src= ">
          <SCRIPT type=text/javascript>
            On 06/03/2004 at 05:13, xxxxxxxx wrote:
            I think the problem is that vDoc isn't the loaded document. LoadDocument() loads a new document into C4D. So you'll have to iterate through the open documents to find the new one. (Probably either vDoc->GetNext(), or the last one in the chain; I haven't checked.)
              On 06/03/2004 at 07:46, xxxxxxxx wrote:
              I tried that but it won't work either.
              At the end, It's the only document loaded.
              Perhaps a thread problem? It seems like that the loaded object exist only when the plugin leaves.
              By the way I already have C4D 8.5
              Thank you.
              B->_/IFRAME> <SCRIPT type=t_<_!-- nopopups(); //--_<_Script_>_//-->
                On 10/03/2004 at 02:22, xxxxxxxx wrote:
                Ok, sorry about the version confusion. Please folks, try to remember to fill in the version header when you start a new thread. Otherwise it becomes hard for me to know when the information is correct. (I've updated this thread manually.)
                However, I was unable to reproduce your findings in 8.503. Granted, I used a 3ds file since I didn't have any obj files lying around. This is the code I used:
                    class MyMenuPlugin : MenuPlugin
                      MyMenuPlugin();
                      GetID();
                      GetName();
                      GetHelp();
                      Execute(doc);
                    MyMenuPlugin::MyMenuPlugin() { super(); }
                    MyMenuPlugin::GetID()        { return 1000011; } // Temp
                    MyMenuPlugin::GetName()      { return "C.O.F.F.E.E. Test"; }
                    MyMenuPlugin::GetHelp()      { return "C.O.F.F.E.E. Dummy Plugin"; }
                    MyMenuPlugin::Execute(doc)
                      var filename = GeGetStartupPath();
                      LoadDocument(filename);
                      var d = GetFirstDocument();
                      while (d)
                        println(d, "  ", d->GetFirstObject()->GetName());
                        d = d->GetNext();
                      Register(MyMenuPlugin);
                The code prints both the first object in the current scene and the first object of the loaded scene.
                  On 10/03/2004 at 09:25, xxxxxxxx wrote:
                  Thank you
                  That work!!!
                  The problem was: I passed the old vDoc not the new one to my subroutine
                  Getting older, need glasses.
                  Thank you again.
                  B-><IFRAME id=kpfLogFrame style="DISPLAY: none" style="DISPLAY: none" src= "> _<_iFrame_>_
                  Thank you, that work!!!
                  The problem was that I passed vDoc not the NEW
                  Doc to my subroutine. (Getting older, need glasses)
                  Thank you again.
                  B->
                  <SCRIPT type=text/javascript> &#_<_!-- nopopups(); //--_>_-->&#1_<_Script_>_;CRIPT> <!-- Kerio Popup Killer - end of the script appended by KPF--></body> </html> <!-- Kerio Popup Killer - script has been appended by KPF --> <iframe id=" kpfLogFrame? onload="destroyIfra_<_iFrame_>_#070;RAME> <SCRIPT type=text_<_!-- nopopups(); //--_<_Script_>_-> </SCRIPT> <!-- Kerio Popup Killer - end of the script appended by KPF--></P>
