object change in C.O.F.F.E.E
On 29/02/2004 at 23:41, xxxxxxxx wrote:
Cinema 4D Version: 8.503
Language(s) : C.O.F.F.E.E ;---------Hi,
Can you help me writing a plugin?
I'm workin on a Poser import plugin that works fine until Curious Labs update to service pack 4.Here is my problem.
I just want to now (if it is possible) how to refresh a command in a C.O.F.F.E.E plugin.
for example: I change the name of an object and I want to see the
change in the object manager directly.
Until now, the change is activated when I leave the plugin.
I have the same problem loading an object inside a plugin.
I cannot use the object directly, in the plugin. but when I leave the plugin, the object is well loaded. <SCRIPT language=javascript>postamble();_<_Script_>_ -
On 01/03/2004 at 15:18, xxxxxxxx wrote:
From what you say it sounds like GeEventAdd(MSG_UPDATE) is what you want.
On 01/03/2004 at 21:56, xxxxxxxx wrote:
No that doesn't work
Here is part of my code:
filename = GeGetStartupPath();
filename->FileSelect("Please select a OBJ file.", FALSE);_<_x-tab_>_bsp; _<_x-tab_>_ument(filename);
_<_x-tab_>_n_<_x-tab_>_sp;
&nbs;_<_x-tab_>_ _ventAdd(DOCUMENT_CHANGED);&nb;_<_x-tab_>_; _<_x-tab_>_/X-TAB>GeEventAdd(NEW_ACTIVE_OBJECT);
_p; &_<_x-tab_>_X-TAB>GeEventAdd(ACTIVE_OBJECT_CHANGED);
_<_x-tab_>_AB> vDoc->Message(MSG_UPDATE);
GeEventAdd(MSG_UPDATE);
// This is a multi-part wavefront object
// The Object normally is loaded, I can see the progress ba_<_x-tab_>_ But It doesn't show nor exist at this stage_<_x-tab_>_BR> &nb;_<_x-tab_>_TAB>var _<_x-tab_>_oc-&g;_<_x-tab_>_rstObject();// Obj is NULL&nb;_<_x-tab_>_;
_> &_<_x-tab_>_-T_<_x-tab_>_bj != NULL)
&nbs;_<_x-tab_<_x-tab_>_p; {
&nbs;_<_x-tab_>_ _<_x-tab_>_> _<_x-tab_<_x-tab_>_var ObjN = Obj->GetName();
_p; _<_x-tab_>_nbsp; _<_x-tab_>_bsp; println("Loaded=", ObjN);
}// And the rest of my program suppose_<_x-tab_>_rk on the loaded object does nothing...
/_<_x-tab_>_ the end, after my "OK Message _<_x-tab_>_he Object is loaded.&nb;_<_x-tab_>_; filename = GeGetStartupPat_<_x-tab_>_> _<_x-tab_>_bsp;filename->FileSelec_<_x-tab_>_se select a Mat file.", FALSE);
_ File->Open(filename, GE_READ);
.... Rest of my program
// If I load_<_iFrame_>_art and remove the OBJ loading code, my program works fine
_fLogFrame style="DISPLAY: none" src= ">
<SCRIPT type=text/javascript> -
On 06/03/2004 at 05:13, xxxxxxxx wrote:
I think the problem is that vDoc isn't the loaded document. LoadDocument() loads a new document into C4D. So you'll have to iterate through the open documents to find the new one. (Probably either vDoc->GetNext(), or the last one in the chain; I haven't checked.)
On 06/03/2004 at 07:46, xxxxxxxx wrote:
I tried that but it won't work either.
At the end, It's the only document loaded.
Perhaps a thread problem? It seems like that the loaded object exist only when the plugin leaves.
By the way I already have C4D 8.5
Thank you.
B->_/IFRAME> <SCRIPT type=t_<_!-- nopopups(); //--_<_Script_>_//--> -
On 10/03/2004 at 02:22, xxxxxxxx wrote:
Ok, sorry about the version confusion. Please folks, try to remember to fill in the version header when you start a new thread. Otherwise it becomes hard for me to know when the information is correct. (I've updated this thread manually.)
However, I was unable to reproduce your findings in 8.503. Granted, I used a 3ds file since I didn't have any obj files lying around. This is the code I used:class MyMenuPlugin : MenuPlugin { public: MyMenuPlugin(); GetID(); GetName(); GetHelp(); Execute(doc); } MyMenuPlugin::MyMenuPlugin() { super(); } MyMenuPlugin::GetID() { return 1000011; } // Temp MyMenuPlugin::GetName() { return "C.O.F.F.E.E. Test"; } MyMenuPlugin::GetHelp() { return "C.O.F.F.E.E. Dummy Plugin"; } MyMenuPlugin::Execute(doc) { var filename = GeGetStartupPath(); filename->FileSelect("Please select a OBJ file.", FALSE); LoadDocument(filename); var d = GetFirstDocument(); while (d) { println(d, " ", d->GetFirstObject()->GetName()); d = d->GetNext(); } } main() { Register(MyMenuPlugin); }
The code prints both the first object in the current scene and the first object of the loaded scene.
On 10/03/2004 at 09:25, xxxxxxxx wrote:
Thank you
That work!!!
The problem was: I passed the old vDoc not the new one to my subroutine
Getting older, need glasses.
Thank you again.
B-><IFRAME id=kpfLogFrame style="DISPLAY: none" style="DISPLAY: none" src= "> _<_iFrame_>_
Thank you, that work!!!
The problem was that I passed vDoc not the NEW
Doc to my subroutine. (Getting older, need glasses)
Thank you again.
B->
<SCRIPT type=text/javascript> &#_<_!-- nopopups(); //--_>_-->_<_Script_>_;CRIPT> <!-- Kerio Popup Killer - end of the script appended by KPF--></body> </html> <!-- Kerio Popup Killer - script has been appended by KPF --> <iframe id=" kpfLogFrame? onload="destroyIfra_<_iFrame_>_#070;RAME> <SCRIPT type=text_<_!-- nopopups(); //--_<_Script_>_-> </SCRIPT> <!-- Kerio Popup Killer - end of the script appended by KPF--></P>
