    Set UVWs for Ngons?
    s26python
    4 Posts 2 Posters 889 Views 1 Watching
    • E Offline
      ELJeffery
      For updating the changed UVWs I am using:
      # Update UV data in Cinema 4D using updated data from RizomUV
      def update_uvs_in_cinema4d(doc, obj, poly_sizes, poly_uvw_ids, updated_uvws):
          # Retrieve the active document and object once
          doc, obj = get_active_object()
          if not obj or not isinstance(obj, c4d.PolygonObject):
              gui.MessageDialog("No Polygon Object selected.")
          # Get the Polygon Translation Map
          poly_trans_map = obj.GetPolygonTranslationMap()
          polygon_count, ngon_map = poly_trans_map
          # Detect if there are ngons by checking if the ngonMap contains repeated values
          all_polygons = obj.GetAllPolygons()
          has_ngons = len(set(ngon_map)) != len(ngon_map)
          ngon_count = obj.GetNgonCount()
          print("Number of polygons including polygons inside any ngons: ", len(all_polygons))
          print("Number of polygons including ngons: ",polygon_count)
          print("Number of ngons: ",ngon_count)
          print("Number of internal ngon edges: ",len(ngon_map) - len(set(ngon_map)))
          uvw_tag = obj.GetTag(c4d.Tuvw)
          if not uvw_tag:
              print("No UVW Tag found.")
          doc.SetMode(c4d.Mpolygons)
          handle = c4d.modules.bodypaint.GetActiveUVSet(doc, c4d.GETACTIVEUVSET_ALL)
          if handle is None:
              c4d.CallCommand(170103)  # Open UV editor
              if c4d.API_VERSION >= 22000:
                  c4d.modules.bodypaint.UpdateMeshUV(False)
              if handle is None:
                  raise RuntimeError("No Active UVSet")
          uv_index = 0
          assembled_uvws = []
          adjusted_uvws = adjust_uvs(updated_uvws)  # Ensure UVs are normalized correctly
          for poly_idx, poly_size in enumerate(poly_sizes):
              uv_dict = {}
              uv_indices = poly_uvw_ids[uv_index:uv_index + poly_size]
              uv_index += poly_size
              # Handle triangles
              if poly_size == 3:
                  uv_dict = {
                      'c': c4d.Vector(adjusted_uvws[uv_indices[0] * 3], adjusted_uvws[uv_indices[0] * 3 + 1], adjusted_uvws[uv_indices[0] * 3 + 2]),
                      'b': c4d.Vector(adjusted_uvws[uv_indices[1] * 3], adjusted_uvws[uv_indices[1] * 3 + 1], adjusted_uvws[uv_indices[1] * 3 + 2]),
                      'a': c4d.Vector(adjusted_uvws[uv_indices[2] * 3], adjusted_uvws[uv_indices[2] * 3 + 1], adjusted_uvws[uv_indices[2] * 3 + 2])
              # Handle quads
              elif poly_size == 4:
                  uv_dict = {
                      'd': c4d.Vector(adjusted_uvws[uv_indices[0] * 3], adjusted_uvws[uv_indices[0] * 3 + 1], adjusted_uvws[uv_indices[0] * 3 + 2]),
                      'c': c4d.Vector(adjusted_uvws[uv_indices[1] * 3], adjusted_uvws[uv_indices[1] * 3 + 1], adjusted_uvws[uv_indices[1] * 3 + 2]),
                      'b': c4d.Vector(adjusted_uvws[uv_indices[2] * 3], adjusted_uvws[uv_indices[2] * 3 + 1], adjusted_uvws[uv_indices[2] * 3 + 2]),
                      'a': c4d.Vector(adjusted_uvws[uv_indices[3] * 3], adjusted_uvws[uv_indices[3] * 3 + 1], adjusted_uvws[uv_indices[3] * 3 + 2])
              # Handle ngons (polygons with more than 4 vertices)
              elif has_ngons:
                  # Sort the vertices properly and create the UV dict dynamically
                  alphabet = 'abcdefghijklmnopqrstuvwxyz'
                  for i in range(poly_size):
                      # Make sure to use the correct UV order
                      key = alphabet[i] if i < len(alphabet) else f'v{i}'  # Handle large ngons
                      uv_dict[key] = c4d.Vector(
                          adjusted_uvws[uv_indices[i] * 3],
                          adjusted_uvws[uv_indices[i] * 3 + 1],
                          adjusted_uvws[uv_indices[i] * 3 + 2]
              assembled_uvws.append(uv_dict)
          handle.SetUVWFromTextureView(assembled_uvws, True, True, True)
          bodypaint.FreeActiveUVSet(handle)
      My problem is, it works with a mesh that is only quads and tris or any combination thereof, but if the mesh contains any ngons then I get this result:
      E 1 Reply Last reply Reply Quote 0
      • E Offline
        ELJeffery @ELJeffery
        @ELJeffery
        The image:
          ferdinand @ELJeffery
          Hello @ELJeffery,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          Please have a look at Support Procedures: How to Ask Questions, specifically in the context of repeatability. We cannot run your code as it is not executable as it is lacking things like imports and also some logic, e.g. adjust_uvs. Otherwise answering your question is pure guess work for us. Please also explain in one to two sentences what you want to achieve. "Updating" uv data is a very broad term. Until there some clarity and executable code, that is unfortunately all I can say.
          • E Offline
            ELJeffery @ferdinand
            @ferdinand I figured this issue out so you can mark this as solved/closed. Thank you.
