    How to modify python tags as generators first?
    programming
    2 Posts 2 Posters 1.1k Views 1 Watching
    • treezwT Offline
      treezw
          cloner = c4d.BaseObject(c4d.Omgcloner)
          python = c4d.BaseTag(c4d.Tpython)
          cloner.InsertTag(python)
          doc.InsertObject(cloner)
        Hello @treezw,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Please have a look at our forum guidelines. You must accompany your postings by a reasonable description of what you want. We cannot start deciphering screenshots. I understand that language can be a barrier but your title does not offer much meaning either.
        I can read here between the lines but we expect you to provide a meaningful problem description in future postings. I assumed that your question is 'how to set the priority value of a Python programming tag?' You must use the parameter access syntax myNode[ID_SOME_PARAM] = value. To discover parameter values, you can use parameter drag and drop in the console. A little hurdle is here the data type of the parameter you want to write, c4d.PriorityData, which is a bit of an oddball.
        PS: You also posted in the wrong forum, this must go into Cinema 4D SDK since this is a question about this SDK. I have moved your topic.
        from mxutils import CheckType
        doc: c4d.documents.BaseDocument # The active document.
        op: c4d.BaseObject | None # The active object, can be `None`.
            # Allocate a cloner. Object allocation can fail in the C++ backend when you run out of memory.
            # The constructor will return `None` in that case. One way to handle this is to ensure with
            # a `CheckType` call that the object is not `None`.
            cloner: c4d.BaseObject = CheckType(c4d.BaseObject(c4d.Omgcloner))
            # Create a Python tag, insert it into the cloner and check for success in one line.
            tag: c4d.BaseTag = CheckType(cloner.MakeTag(c4d.Tpython))
            # Get the priority data of the Python tag, change its value and write it back. Priority data
            # bundle up three values, the mode, the priority and the camera dependency which are all written
            # with the method `SetPriorityValue`.
            priority: c4d.PriorityData = tag[c4d.EXPRESSION_PRIORITY]
            priority.SetPriorityValue(c4d.PRIORITYVALUE_MODE, c4d.CYCLE_GENERATORS)
            priority.SetPriorityValue(c4d.PRIORITYVALUE_PRIORITY, -100)
            tag[c4d.EXPRESSION_PRIORITY] = priority
            # Insert the cloner into the document and invoke an update.
        • ferdinandF ferdinand moved this topic from General Talk on
