    Adding a Morph Deformer Causes Pose Morph Tag to Stop Working
    6 Posts 2 Posters 1.6k Views
    • kangddanK Offline
      kangddan
      Hello all, I've noticed that my Pose Morph tag stops working after I add a Morph Deformer. It seems that I can't replicate the manual process of adding the Morph Deformer. What might I be doing wrong?bandicam 2024-05-01 20-57-06-001 00_00_00-00_00_30.gif
      The main function of the code is to copy the selected object, then add a pose morph, and set the target to the selected object. The reason for adding the Morph Deformer is that I can offset issues with priority lag. However, in the code, once I add the Morph Deformer, the Pose Morph stops working 😞
      def copyObj(obj):
          _copyObj = obj.GetClone(); doc.AddUndo(c4d.UNDOTYPE_NEW, _copyObj)
          _copyObj.SetName('{}_copy'.format(obj.GetName()))
          _copyObj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 2
          _copyObj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 2
          doc.InsertObject(_copyObj); _copyObj.InsertAfter(obj)
          for tag in _copyObj.GetTags():
              if isinstance(tag, c4d.modules.character.CAWeightTag):
                  tag.Remove()
          for child in _copyObj.GetChildren():
              if child.CheckType(c4d.Oskin):
                  child.Remove()
          return _copyObj
      def addPoseMorph(target, obj):
          pmTag = obj.MakeTag(1024237)
          priorityData = c4d.PriorityData()
          priorityData.SetPriorityValue(c4d.PRIORITYVALUE_MODE, c4d.CYCLE_INITIAL)
          pmTag[c4d.ID_CA_POSE_BASE_PRI] = priorityData
          pmTag[c4d.ID_CA_POSE_POINTS] = 1
          baseMorph = pmTag.AddMorph()   # id0
          targetMorph = pmTag.AddMorph() # id1
          pmTag.UpdateMorphs()
          targetMorph.SetName('target')
          pmTag.SetActiveMorphIndex(1)
          pmTag[c4d.ID_CA_POSE_TARGET] = target
          pmTag[c4d.ID_CA_POSE_MODE] = 1
          return pmTag
      def addMorphDeformer(obj, tag):
          morph = c4d.BaseObject(1019768)
          morph.InsertUnder(obj)
          morph[c4d.ID_CA_MORPH_DEFORMER_OBJECT_TAG] = tag
          morph[c4d.ID_CA_MORPH_DEFORMER_OBJECT_APPLY_BASEPOSE] = True
      def create():
          sel = doc.GetSelection()
          if not sel: return
          doc.StartUndo()
          for o in sel:
              doc.AddUndo(c4d.UNDOTYPE_CHANGE, o)
              o[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
              o[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
              cObj = copyObj(o)
              pmTag = addPoseMorph(o, cObj)
              addMorphDeformer(cObj, pmTag)
          doc.EndUndo()
          create()
      • kangddanK Offline
        kangddan
        test file
        test.c4d
        • kangddanK Offline
          kangddan
          Hello everyone, I seem to have found a solution. You just need to go to the Falloff option in Morph and add a default parameter
           data = c4d.FieldList()
          morph[c4d.FIELDS] = data
          This way, the PoseMorph tag becomes effective. I still don't understand why this is necessary, as I can't find any python related content about the Morph deformer:(
          • i_mazlovI Offline
            i_mazlov @kangddan
            Hi @kangddan,
            Thanks for providing such a good reference for reproducing the issue!
            Looks like you're missing the initialization and finalizing phases of creating the morph tag, hence you end up with invalid (or not updated) one. Executing the following functions in the correct order seems to fix your issue. Please have a look at InitMorphs(), UpdateMorphs() and ExitEdit().
            Please find the corrected addPoseMorph() function below.
            Regarding the falloff option, I assume it implicitly calls UpdateMorphs() function, which updates the morph tag, hence you have it in working state.
            Ilia
            PS There's no need to insert object to document first, if you later insert it after another object that's already in document, or in other words the doc.InsertObject(_copyObj) call is redundant.
            The corrected addPoseMorph function code snippet:
                pmTag.InitMorphs()
                pmTag.ExitEdit(doc, False) # switch to "Animate Mode"
                return pmTag
            kangddanK 1 Reply Last reply Reply Quote 1
            • kangddanK Offline
              kangddan @i_mazlov
              This post is deleted!
              • kangddanK Offline
                kangddan
                Thank u @i_mazlov
                I appreciate you pointing me in the right direction. I will try to understand the workings behind the posemorph tag! 😊
