    ProjectTool & visual studio: Treat Specific Warnings As Errors
    windowsc++
    3 Posts 2 Posters 976 Views 1 Watching
    • B Offline
      BruceC
      Is there a way to specify the Visual Studio option below in projectdefinition.txt? Thanks!
      Configuration Properties-> C/C++->Advanced->Treat Specific Warnings As Errors
        ferdinand @BruceC
        Hey @BruceC,
        Thank you for reaching out to us. No, that is not possible, at least not in a directly intended way. What you can do, is go into /frameworks/settings/MSVCBase.props and change your error and warning handling there. But you would have to apply that to every project tool / Extended SDK you use.
        The content of the file is used to generate the projects:
        <?xml version="1.0" encoding="utf-8"?>
        <Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
          <ImportGroup Label="PropertySheets">
            <Import Project="Base.props" />
          </ImportGroup>
          <PropertyGroup Label="UserMacros" />
          <PropertyGroup />
          <ItemDefinitionGroup>
            <ClCompile>
              <WarningLevel>EnableAllWarnings</WarningLevel>
              <DisableSpecificWarnings>4003;4061;4062;4100;4127;4131;4191;4200;4244;4265;4266;4296;4307;
              4324;4350;4351;4355;4365;4371;4458;4463;4464;4987;4503;4514;4519;4530;4548;4571;4574;4577;
              4592;4611;4623;4625;4626;4628;4640;4647;4668;4710;4711;4714;4738;4768;4774;4820;4826;4868;
              4883;4917;4928;4946;5026;5027;5039;5045;5204;5220;5262;5256%(DisableSpecificWarnings)
              </DisableSpecificWarnings>
              <TreatSpecificWarningsAsErrors>4456;4715;4834;4996</TreatSpecificWarningsAsErrors>
            </ClCompile>
          </ItemDefinitionGroup>
          <ItemGroup />
        </Project>
        • B Offline
          BruceC
          Thanks for the reply, @ferdinand
