    Crash in ReadChunk()
    Scheduled Pinned Locked Moved Cineware SDK
    c++windows
    7 Posts 3 Posters 2.4k Views 1 Watching
    • T Offline
      thomasmfields
      Hi there,
      Using cineware SDK v22.008 (VS2013 libs), I'm getting a crash when trying to process the file attached. The crash stack is:
       	FwdFX_d.fx!cineware::PrivateChunk::ReadChunk(class cineware::HyperFile *,bool,bool)	Unknown
       	FwdFX_d.fx!cineware::PrivateChunk::ReadObject(class cineware::HyperFile *,bool)	Unknown
       	FwdFX_d.fx!cineware::MoGraphFractureVoronoiObject::Read(class cineware::HyperFile *,int,int)	Unknown
       	FwdFX_d.fx!cineware::BaseObject::HandleSubChunk(class cineware::HyperFile *,int,int)	Unknown
       	FwdFX_d.fx!cineware::RootObject::HandleSubChunk(class cineware::HyperFile *,int,int)	Unknown
       	FwdFX_d.fx!cineware::RootList2D::HandleSubChunk(class cineware::HyperFile *,int,int)	Unknown
       	FwdFX_d.fx!cineware::BaseDocument::HandleSubChunk(class cineware::HyperFile *,int,int)	Unknown
      and the log contains:
      First-chance exception at 0x000000001F5BDA64 (FwdFX_d.fx) in FX_d.exe: 0xC0000005: Access violation reading location 0xFFFFFFFFFFFFFFFF.
      Any clues as to what is going wrong here and how I can fix it?
      The file is here: model loop 7.c4d
      Regards,
      Tom
      • J Offline
        jana @thomasmfields
        Hello @thomasmfields,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Thanks a lot for reaching out. To support you, please provide a code snippet that we can reproduce the issue.
        What do you want to achieve?
        Thanks and Cheers
        Jana
        • T Offline
          thomasmfields
          Hi Jana,
          I'd like it not to crash, please. My code looks like this:
          fn.SetMemoryReadMode(data, size); // The contents of the file are in "data".
          cineware::AlienBaseDocument *c4dDoc = NewObj(cineware::AlienBaseDocument);
          cineware::HyperFile *c4dFile = NewObj(cineware::HyperFile);
          if (c4dDoc && c4dFile)
          	if (c4dFile->Open(DOC_IDENT, fn, cineware::FILEOPEN_READ))
          		if (c4dDoc->ReadObject(c4dFile, true))
          Are you able to reproduce the issue?
          Regards,
          Tom
          • J Offline
            j_uhlig
            Hi Tom,
            can you please try the following:
            • does it work if you load the same data from disk
            • can you try with LoadDocument(fn, SCENEFILTER::SCENEFILTER_OBJECTS | SCENEFILTER::SCENEFILTER_MATERIALS)
              And how did you load the file into memory?
            Jens
            • T Offline
              thomasmfields
              Hi Jens,
              I get the same error stack when I do the following:
              cineware::Filename myFile("model loop 7.c4d");
              cineware::BaseDocument *baseDoc = LoadDocument(myFile, cineware::SCENEFILTER::SCENEFILTER_OBJECTS | cineware::SCENEFILTER::SCENEFILTER_MATERIALS);
              I load the file into memory using my own file stream API, which is used successfully elsewhere and with other c4d files. I'm using ReadFile() and GetFileSizeEx()
              Regards,
              Tom
              • J Offline
                j_uhlig
                Hi Tom,
                I could confirm the issue!
                You can fix this in "c4d_fracturevoronoidata.h" line 52 like this:
                RootObject* _head = nullptr;
                Please let me know if this works for you.
                Jens
                • T Offline
                  thomasmfields
                  Hi Jens,
                  That fix works for us. This is excellent. Thank you very much.
                  Regards,
                  Tom
