    Redshift Standard Material base Properties
    3 Posts 3 Posters 2.0k Views 2 Watching
    • S Offline
      simonator420
      I am trying to insert the full_path into "Load texture..." into Redshift Standard Material base color but all I got so far is this code. Could you help me solve this?
      full_path = os.path.join(folder_path, file)
      rsNodeSpaceID: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.class.nodespace")
      textureNodeID: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler")
      textureNodePortID: maxon.String = "com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0"
      textureNodePathPortID: maxon.String = "path"textureColorOutPortID: maxon.String = "com.redshift3d.redshift4c4d.nodes.core.texturesampler.outcolor"
      mat: c4d.BaseMaterial = c4d.BaseMaterial(c4d.Mmaterial)
      nodeMaterial: c4d.NodeMaterial = mat.GetNodeMaterialReference()
      graph: maxon.GraphModelRef = nodeMaterial.CreateDefaultGraph(rsNodeSpaceID)
      doc.InsertMaterial(mat)
      result: list[maxon.GraphNode] = []
      maxon.GraphModelHelper.FindNodesByAssetId(graph, outputNodeID, True, result)
      outputNode: maxon.GraphNode = result[0]
      with graph.BeginTransaction() as transaction:
      	textureNode: maxon.GraphNode = graph.AddChild(maxon.Id(), textureNodeID)
      	pathPort: maxon.GraphNode = textureNode.GetInputs().FindChild(textureNodePortID).FindChild(textureNodePathPortID)
      	pathPort.SetDefaultValue(maxon.Url(full_path))
      	textureColorOutPort: maxon.GraphNode = textureNode.GetOutputs().FindChild(textureColorOutPortID)
      	colorInputPortInOutputNode : maxon.GraphNode = outputNode.GetInputs().FindChild(colorInputPortInOutputNodeId)
      	textureColorOutPort.Connect(colorInputPortInOutputNode)
      	transaction.Commit()
      DunhouD ferdinandF 2 Replies Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @simonator420
        Hi @simonator420 ,
        You should get the base color port( a maxon.GraphNode ), and connect with a Texture node ( also a maxon.GraphNode ), the texture path is also a port in Texture node, just set it's value is what you need,
        I have a little example here which used my api helper renderEngine, I think it is easy to use and less code for general task. but it should be pointed out that use Maxon python sdk is more customized.
        Cheers~
        DunHou
        import c4d,maxon
        from importlib import reload
        from renderEngine.redshift import redshift_helper as rs
        reload(rs)
        try:
            from redshift_id import *
        except:
            from renderEngine.redshift.redshift_id import *
        from renderEngine import node_helper
        reload(node_helper)
        def AddandModify(name):
            redshiftMaterial =  rs.MaterialHelper.CreateStandardSurface(name)
            # modification has to be done within a transaction
            with rs.RSMaterialTransaction(redshiftMaterial) as transaction:
                # Find brdf node (in this case : standard surface)
                standard_surface = redshiftMaterial.helper.GetRootBRDF()
                # Change a shader name
                redshiftMaterial.helper.SetName(standard_surface,'My BRDF Shader')
                # TexPath
                tex_helper = node_helper.TextureHelper()
                url: maxon.Url = tex_helper.GetAssetStr(maxon.Id("file_5b6a5fe03176444c"))
                tar = redshiftMaterial.helper.GetPort(standard_surface,'com.redshift3d.redshift4c4d.nodes.core.standardmaterial.base_color')
                # Add a texture to base color
                redshiftMaterial.AddTexture(shadername = 'My texture', filepath = url, raw = True, target_port = tar)
            redshiftMaterial.InsertMaterial()
            redshiftMaterial.SetActive()
            return redshiftMaterial.material
            AddandModify("Example")
        https://boghma.com
        https://github.com/DunHouGo
          ferdinand @simonator420
          Hey @simonator420,
          Thank you for reaching out to us. And thank you @Dunhou for providing a solution. You should however be aware that Dunhou's solution requires his proprietary library as he states below. I think you should give it a spin because it is quite useful.
          When you must remain within the bounds of the Cinema 4D standard library, find an example for how to do that below.
          PS: I have added the example below to the code examples of the upcoming release alongside the standard renderer example.
          Result:
          Code:
          #coding: utf-8
          """Demonstrates setting up a Redshift node material composed out of multiple nodes.
          Creates a new node material with a graph in the Redshift material space, containing two texture
          nodes and a mix node, in addition to the default core material and material node of the material.
          Topics:
              * Creating a node material and adding a graph
              * Adding nodes to a graph
              * Setting the value of ports without wires
              * Connecting ports with a wires
              * (Asset API): Using texture assets in a node graph
          __author__ = "Ferdinand Hoppe"
          __copyright__ = "Copyright (C) 2023 MAXON Computer GmbH"
          __date__ = "01/09/2023"
          __license__ = "Apache-2.0 License"
          __version__ = "2023.2.0"
          import maxon
          doc: c4d.documents.BaseDocument # The active document.
              """Runs the example.
              # The asset URLs for the "RustPaint0291_M.jpg" and "Sketch (HR basic026).jpg" texture assets in
              # "tex/Surfaces/Dirt Scratches & Smudges/". These could also be replaced with local texture URLs,
              # e.g., "file:///c:/textures/stone.jpg". These IDs can be discovered with the #-button in the info
              # area of the Asset Browser.
              urlTexRust: maxon.Url = maxon.Url(r"asset:///file_edb3eb584c0d905c")
              urlTexSketch: maxon.Url = maxon.Url(r"asset:///file_3b194acc5a745a2c")
              # The node asset IDs for the two node types to be added in the example; the texture node and the
              # mix node. These and all other node IDs can be discovered in the node info overlay in the
              # bottom left corner of the Node Editor. Open the Cinema 4D preferences by pressing CTRL/CMD + E
              # and enable Node Editor -> Ids in order to see node and port IDs in the Node Editor.
              idTextureNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler")
              idMixNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.rscolormix")
              idCoreMaterialNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.material")
              # Instantiate a material, get its node material and the graph for the RS material space.
              material: c4d.BaseMaterial = c4d.BaseMaterial(c4d.Mmaterial)
              if not material:
                  raise MemoryError(f"{material = }")
              nodeMaterial: c4d.NodeMaterial = material.GetNodeMaterialReference()
              graph: maxon.GraphModelRef = nodeMaterial.AddGraph(
                  maxon.Id("com.redshift3d.redshift4c4d.class.nodespace"))
              if graph.IsNullValue():
                  raise RuntimeError("Could not add RS graph to material.")
              doc.InsertMaterial(material)
              # Attempt to find the core material node contained in the default graph setup.
              maxon.GraphModelHelper.FindNodesByAssetId(graph, idCoreMaterialNode, True, result)
              if len(result) < 1:
                  raise RuntimeError("Could not find standard node in material.")
              standardNode: maxon.GraphNode = result[0]
              # Start modifying the graph by opening a transaction. Node graphs follow a database like
              # transaction model where all changes are only finally applied once a transaction is committed.
                  # Add two texture nodes and a blend node to the graph.
                  rustTexNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idTextureNode)
                  sketchTexNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idTextureNode)
                  mixNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idMixNode)
                  # Set the default value of the 'Mix Amount' port, i.e., the value the port has when no
                  # wire is connected to it. This is equivalent to the user setting the value to "0.5" in
                  # the Attribute Manager.
                  mixAmount: maxon.GraphNode = mixNode.GetInputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.rscolormix.mixamount")
                  mixAmount.SetDefaultValue(0.5)
                  # Set the path sub ports of the 'File' ports of the two image nodes to the texture URLs
                  # established above. Other than for the standard node space image node, the texture is
                  # expressed as a port bundle, i.e., a port which holds other ports. The texture of a texture
                  # node is expressed as the "File" port, of which "Path", the URL, is only one of the possible
                  # sub-ports to set.
                  pathRustPort: maxon.GraphNode = rustTexNode.GetInputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0").FindChild("path")
                  pathSketchPort: maxon.GraphNode = sketchTexNode.GetInputs().FindChild(
                  pathRustPort.SetDefaultValue(urlTexRust)
                  pathSketchPort.SetDefaultValue(urlTexSketch)
                  # Get the color output ports of the two texture nodes and the color blend node.
                  rustTexColorOutPort: maxon.GraphNode = rustTexNode.GetOutputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.texturesampler.outcolor")
                  sketchTexColorOutPort: maxon.GraphNode = sketchTexNode.GetOutputs().FindChild(
                  mixColorOutPort: maxon.GraphNode = mixNode.GetOutputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.rscolormix.outcolor")
                  # Get the fore- and background port of the blend node and the color port of the BSDF node.
                  mixInput1Port: maxon.GraphNode = mixNode.GetInputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.rscolormix.input1")
                  mixInput2Port: maxon.GraphNode = mixNode.GetInputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.rscolormix.input2")
                  coreDiffusePort: maxon.GraphNode = standardNode.GetInputs().FindChild(
                      "com.redshift3d.redshift4c4d.nodes.core.material.diffuse_color")
                  # Wire up the two texture nodes to the blend node and the blend node to the BSDF node.
                  rustTexColorOutPort.Connect(mixInput1Port, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
                  sketchTexColorOutPort.Connect(mixInput2Port, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
                  mixColorOutPort.Connect(coreDiffusePort, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
                  # Finish the transaction to apply the changes to the graph.
              # Insert the material into the document and push an update event.
          • maxonM maxon moved this topic from Cinema 4D SDK on
