    ProgressDialog and SetTitle()
    sdkc++
    3 Posts 2 Posters 1.0k Views
    • WickedPW Offline
      WickedP
      Hi folks,
      is it possible to update a ProgressDialog's title inside the Main() function? I'm wanting to make the title "x of y complete". Doing this doesn't work:
      // pseudo code
      .. Main()
      SetPercent(0.0);
      for(int i = 0; i < 100;)
      String title = String("Processing i+1 of 100");
      SetTitle(title);
      SetPercent((i + 1) / 100);
      ++i;
      SetPercent(1.0);
      I'm guessing because Main() is on another thread. Is this possible?
      WP.
      wickedp.com
      • i_mazlovI Offline
        i_mazlov
        Hi @WickedP,
        The assumption would be that the execution of the main function happens too early, when there's no GUI yet available. Please, consider executing your implementation inside the PluginMessage() function, using one of the messages: C4DPL_STARTACTIVITY or C4DPL_PROGRAM_STARTED.
        Let me know if you have any further questions.
        Ilia
        • WickedPW Offline
          WickedP
          Hi @i_mazlov
          The dialog/gui is open. It's a progress dialog that I use to run an export function.
          I did some more digging, and I believe I've solved it. I had to put the SetTitle() into the dialog's Timer() function. So, something like this:
          virtual void MyProgressDialog::Timer(const BaseContainer& msg)
              // 'title' is a class-level string variable
              SetTitle(title);
              return ProgressDialog::Timer(msg);
          Seems to work as expected.
          WP.
          wickedp.com
