    DrawView update ISSUE
    7 Posts 2 Posters 1.6k Views
      mdk7b2
      I am developing a kind of, simple, "tweak tech" as follows:
      The second selected "tweak point" coordinates are used to place the first selected "tweak point" so
      both points result at the same coordinate, then the modeling command c4d.MCOMMAND_OPTIMIZE is called,
      sometimes "artifacts" lines appears, I noted such lines always point to "wolrd axis".
      when zoomming (finger mouse wheel) such lines desappear as shown in the .gif file,
      I have tried the following with little effect:
      c4d.DrawViews(c4d.DRAWFLAGS_FORCEFULLREDRAW, bd)
      c4d.EventAdd(c4d.EVENT_FORCEREDRAW)
      Is the an effective way for updating the view?
      thanks in advance.
      # The call secuence as follows:
      def MouseInput(self, doc, data, bd, win, msg):
      	def ExecuteTweak(self, bd):
      		self.DataDict[TP_Object].SetPoint(...) # setting the point at the second point coordinate
      		self.DataDict[TP_Object].Message(c4d.MSG_UPDATE)
      		self.Optimize() # OptimizeSettings[c4d.MDATA_OPTIMIZE_UNUSEDPOINTS] = False
      image at sdk_support(at)maxon(dot)net
      • i_mazlovI Offline
        i_mazlov
        Hello @mdk7b2,
        Thanks for reaching out to us. Your question is not forgotten and will be answered as soon as possible. Please, excuse the delay, it's a little busy time now.
        Ilia
          mdk7b2
          More evidence at sdk support email
          Thanks and take all the time you need i move on πŸ™‚
          • i_mazlovI Offline
            i_mazlov
            Hi @mdk7b2,
            Thanks for your patience and sorry for the delayed answer.
            I can clearly see the issue you're struggling with, however, I cannot reproduce it without a sample code. Without the code that demonstrates the issue I can only speculate on possible reasons, for example you might want to check c4d.MSG_POINTS_CHANGED and c4d.MSG_POLYGONS_CHANGED messages to explicitly declare the change of the object's geometry.
            To ease any further investigation, please, share a miminal code snippet that shows the issue.
            Ilia
              mdk7b2
              I have testesd both option you mention with out solving the issue, I even tried c4d.MSG_CHANGE, soon I submit a sample code.
              Also I'll try a different approach with WELD command, i will search the forum on how to use it since the help doc on this command is not clear.
              Again: soon I submit a sample code.
                mdk7b2
                ISSUE SOLVED
                Issue caused by a mess in the normals, yes my little knowledge in 3D makes me forget
                objects are not only vertex and polygons also normals.
                Check sdk_support(at)maxon(dot)net
                Thanks Maxon πŸ™‚
                • i_mazlovI Offline
                  i_mazlov
                  Hi @mdk7b2,
                  Glad to hear and thank you for sharing your solution! πŸ‘
                  Good luck and let me know if you have any further questions.
                  Ilia
