    How to: Plugin parent folder on extensions menu
    5 Posts 3 Posters 1.4k Views
    • C Offline
      cybor09
      Hello!
      I want to ask if someone knows how to add a "parent" plugin folder into the Extensions menu like this example:
      I saw the CV-ArtSmart .pyp but I didn't understand how to put that parent and all the plugins inside of it.
      I discovered if I create one folder on the plugins folder, and them each children plugin as folders it will appears as I want but that's not the most efficient way to do it if the plugins will share data that I need to duplicate on each sub folder, what's why I'm trying to get a solution similar to this example.
      Thanks!
      • i_mazlovI Offline
        i_mazlov
        Hi @cybor09,
        Thanks for reaching out to us. You can achieve such grouping by simply registering your plugins in a regular way (please find a code snippet below). It's a default behavior that organizes all your plugins under a folder named after your plugin folder.
        Let me know if you have any further questions.
        Ilia
        *.pyp file content:
        import c4d, os
        from c4d import gui
        PLUGIN1_ID = 999121031
        PLUGIN2_ID = 999121032
        PLUGIN3_ID = 999121033
        class PC_12103_1(c4d.plugins.CommandData):
            def Execute(self, doc):
                print("Execute the 1st command")
        class PC_12103_2(c4d.plugins.CommandData):
                print("Execute the 2nd command")
        class PC_12103_3(c4d.plugins.CommandData):
                print("Execute the 3rd command")
        def loadIconBMP(iconName: str) -> c4d.bitmaps.BaseBitmap:
            directory, _ = os.path.split(__file__)
            fn = os.path.join(directory, "res", iconName)
            # Creates a BaseBitmap
            if bmp is None:
                raise MemoryError("Failed to create a BaseBitmap.")
            # Init the BaseBitmap with the icon
            if bmp.InitWith(fn)[0] != c4d.IMAGERESULT_OK:
                raise MemoryError("Failed to initialize the BaseBitmap.")
            return bmp
            c4d.plugins.RegisterCommandPlugin(PLUGIN1_ID, "1st Cmd", 0, loadIconBMP("icon1.tif"), "", PC_12103_1())
            c4d.plugins.RegisterCommandPlugin(PLUGIN2_ID, "2nd Cmd", 0, loadIconBMP("icon2.png"), "", PC_12103_2())
            c4d.plugins.RegisterCommandPlugin(PLUGIN3_ID, "3rd Cmd", 0, loadIconBMP("icon3.png"), "", PC_12103_3())
        Plugin folder structure:
        • C Offline
          cybor09
          That's great, thanks a lot for your answer @i_mazlov , may I ask if is possible to add also an Icon to the parent folder? and if is possible to add subfolders too like on the scripts?
          Thanks again.
          • i_mazlovI Offline
            i_mazlov
            Hi @cybor09,
            You can group your plugins the way you described in your thread-starting posting. Another option is to build your custom menu using c4d.C4DPL_BUILDMENU.
            Adding icon to the parent folder doesn't seem to be possible unless using custom menu approach that I mentioned above.
            Ilia
            • J Offline
              jana @i_mazlov
              Hello @cybor09 ,
              without further questions or postings, we will consider this topic as solved by Friday, the 11th of august 2023 and flag it accordingly.
              Maxon SDK Group
