    How to get octane aov manager in python
    General Talk
    python sdk
    1.5k
    • R
      render_exe
      hello there!
      I want to get every attribute in octane aov manager in python, but I don't know the way, can you help me? Thank you๏ผ
      DunhouD ferdinandF 2 Replies Last reply Reply Quote 0
      • DunhouD
        Dunhou @render_exe
        Hei @render_exe !
        First of all , I think Octane is out of supports in cafe , you should connect to otoy ( but I think that is a not a good conversation experience and you mostly get no feedback) Octane refuse to provide any sdk as I know , I don't know why that happened ๐Ÿ˜•
        But as this question , I have an octane api helper, here is a little example to read aov data of octane, hope it helps
        Note: I delete some subdata conditions for read. but it is all like Z-Depth aov.
        Cheers~
        from typing import Optional
        from dataclasses import dataclass
        from pprint import pprint
        # Octane render
        ID_OCTANE_VIDEO_POST = 1029525
        SET_RENDERAOV_IN_CNT=3700
        SET_RENDERAOV_INPUT_0=3740
        VP_COLOR_SPACE      = 1028
        # RenderPassAOV_h
        RNDAOV_NAME=900
        RNDAOV_ENABLED=994
        RNDAOV_TYPE=995
        RNDAOV_TYPE_NAME=1101
        RNDAOV_ZDEPTH=255
        RNDAOV_ZDEPTH_MAX=3392
        RNDAOV_ZDEPTH_ENVDEPTH=3397
        @dataclass
        class OctaneAOVData:
            aov_shader: c4d.BaseShader
            aov_enabled: bool
            aov_name: str
            aov_type: int
            aov_subdata: list
        class OctaneVideoPostHelper:
            def __init__(self):
                self.vp: c4d.documents.BaseVideoPost = self.get_videopost(doc)
            def get_videopost(self, doc: c4d.documents.BaseDocument) -> c4d.documents.BaseVideoPost:
                """Get the Octane video post"""
                rdata: c4d.documents.RenderData = doc.GetActiveRenderData()
                vpost: c4d.documents.BaseVideoPost = rdata.GetFirstVideoPost()
                octVp: c4d.documents.BaseVideoPost = None
                # ่Žทๅ–Octane VP
                while vpost:
                    print(vpost.GetType())
                    if vpost.GetType() == ID_OCTANE_VIDEO_POST:
                        octVp = vpost
                    vpost = vpost.GetNext()
                return octVp
            def list_vpdata(self):
                if self.vp is None:
                    raise RuntimeError("Can't get the Octane VideoPost")
                bc: c4d.BaseContainer = self.vp.GetDataInstance()
                for key in range(len(bc)):
                    key = bc.GetIndexId(key)
                    try:
                        print(f"Key: {key}, Value: {bc[key]}, DataType{bc.GetType(key)}")
                    except AttributeError:
                        print("Entry:{0} is DataType {1} and can't be printed in Python".format(key, bc.GetType(key)))
            def read_aov(self) -> list[OctaneAOVData]:
                if self.vp is None:
                aovCnt = self.vp[SET_RENDERAOV_IN_CNT]
                print ("--- OCTANERENDER ---")
                print ("Name:", self.vp.GetName())
                print ("Color space:", self.vp[VP_COLOR_SPACE])
                print ("AOV count:", aovCnt)
                aovs: list[OctaneAOVData] = []
                for i in range(0, aovCnt):
                    aov = self.vp[SET_RENDERAOV_INPUT_0+i]
                    aov_enabled = aov[RNDAOV_ENABLED]
                    aov_name = aov[RNDAOV_NAME]
                    aov_type = aov[RNDAOV_TYPE]
                    aov_subdata = None
                    # Z-Depth
                    if aov_type == RNDAOV_ZDEPTH:
                        aov_subdata = [
                            aov[RNDAOV_ZDEPTH_MAX],
                            aov[RNDAOV_ZDEPTH_ENVDEPTH]
                        print ("Subdata: Z-depth max:",aov[RNDAOV_ZDEPTH_MAX]," Env.depth:",aov[RNDAOV_ZDEPTH_ENVDEPTH])
                    aovs.append(OctaneAOVData(aov_shader=aov,
                                              aov_enabled=aov_enabled,
                                              aov_name=aov_name,
                                              aov_type=aov_type,
                                              aov_subdata=aov_subdata))
                return aovs
        # Execute
            oc = OctaneVideoPostHelper()
            pprint(oc.read_aov())
        https://boghma.com
        https://github.com/DunHouGo
        T R 2 Replies Last reply Reply Quote 0
        • T
          Tng @Dunhou
          @Dunhou said in How to get octane aov manager in python:
          I've managed to get help from Aoktar in the forum, but you have to be persistent and kinda spam the post every two weeks haha.
          One question, since i'm trying to do the same; build some automation with C4D/Octane/Redshift, is your Octane api helper available anywhere ? I'm stuck on a few topics like AOV and the BaseContainer options
          DunhouD 1 Reply Last reply Reply Quote 0
          • DunhouD
            Dunhou @Tng
            @Tng Yeah, you are right, you must send more than 3 and get one feedback , and wait for a loooooooong time.
            And yes , I would make it open source once it is done ( at least a basic structure ), but it is a habit thing to me so not enough times always. I have a redshift api on github. but with octane , it has so many problems , octane don't use xppresso or node editor but a custom userarea and refuse to provide any sdk , you can't even get a selected node. but anyway , I have a bare-bone one now , it worked with light material aov and somethings else . but I don't know how long it will takes me( consider I have some artworks to do and some plugins development plan before it ).
            Cheers~
            https://boghma.com
            T 1 Reply Last reply Reply Quote 0
            • R
              render_exe @Dunhou
              @Dunhou Thank you, I will read and test the code, thank you.
              Cheers~
              • T
                Tng @Dunhou
                @Dunhou I know about your redshift api that's why i asked about octane since i didn't find it on your github ๐Ÿ™‚ Would you be open to collaboration on the Octane API ? Here is my discord if you wanna talk about it : ShivaMist#8262
                • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
                • ferdinandF
                  ferdinand @render_exe
                  Hello @render_exe,
                  Thank you for reaching out to us. Unfortunately, as already pointed out by @Dunhou, questions about third party APIs are out of scope of support:
                  Forum Guidelines: Scope of Support
                  We cannot provide support on learning either C++, Python or one of its popular third party libraries.
                  Thank you @Dunhou for providing such a nice community answer. Since this topic is not about the Cinema 4D SDK, I have moved it to General Talk.
