    MoGraph color tag access
    c++
    4 Posts 2 Posters 1.1k Views 1 Watching
    • A Offline
      Aaron
      Hello colleagues,
      Ho can we access the color of MoGraph data for each object where Motion Graphics Color Tag [with tag->GetType() = 1018768] is assigned?
      For example there is Text object or Voronoi Fracture object which have these tags for generated child objects.
      Thanks in advance!
        Hi you tagged as C++ but we do have this example in python, demonstrating two ways and the first one is by reading the modata stored in the mograph object.
        • A Offline
          Aaron @m_adam
          Hi @m_adam Maxime,
          I don't understand yet, how to use the Python example within a C++ environment. Can't find C++ functions such as this:
          md = c4d.modules.mograph.GeGetMoData(op)
          offset = op[c4d.MG_LINEAR_OFFSET]
          I have noticed that for example the Text object type has MoData->GetCount() with N elements corresponding to the number of letters. And then the cache object of Text has N children each with Motion Graphics Color Tag [tag->GetType() = 1018768].
          I thought there could be a way to read this color tag somehow.
          But if no then during scene traversal there is a way to inherit the array of the Text object with MoData->GetCount() > 0 and then count each descendant object with Motion Graphics Color Tag with increasing id to reference to the correct element of MoData->GetArray()
          Same extraction can be done for Voronoi Fracture and other MoGraph objects with some checks.
            Hi @Aaron sorry I have to admit I totally overlooked your case.
            So Fracture Object is a bit special in how color is handled, and this is not as an usual mograph object, where there is Modata and an array of color. Instead each part is a different PolygonObject and the color is simply the color of the object (the one from the basic tab when you select a polygon object in the attribute manager). So with that said find bellow a code to read color.
            // Get the fracture object
            BaseObject* obj = doc->GetFirstObject();
            if (!obj && obj->GetType() == 1036557)
            	return false;
            // Retrieve the cache. The Cache of a fracture object consist of a null and a bunch of PolygonObject where
            // each PolygonObject represents a part of the fracture.
            BaseObject* rootObjCache = obj->GetCache();
            if (!rootObjCache)
            	return false;
            BaseObject* child = rootObjCache->GetDown();
            Random randomGenerator = Random();
            while (child)
            	// Read Color
            	GeData data;
            	child->GetParameter(DescID(ID_BASEOBJECT_COLOR), data, DESCFLAGS_GET::NONE);
            	Vector color = data.GetVector();
            	ApplicationOutput("@"_s, color);
            	// Write Color with new random value, note that we write the cache, meaning each new re-evaluation of the Fracture object will reset these changes
            	Vector randomColor = Vector(randomGenerator.Get01(), randomGenerator.Get01(), randomGenerator.Get01());
            	child->SetParameter(DescLevel(ID_BASEOBJECT_COLOR), randomColor, DESCFLAGS_SET::NONE);
            	// Get Next Polygon Object aka the next part from the fracture
            	child = child->GetNext();
