    Un-commenting Message function of python tag results in RuntimeError
    s26pythonwindows
    3 Posts 2 Posters 593 Views 1 Watching
      HerrMay
      Hi guys,
      I don't know if this any news but I think I found a bug in def message(id: int, data: object) -> bool: of the python tag. Un-commenting this method results in the following error.
      Traceback (most recent call last):
        File "Python", line 20, in message
      RuntimeError: super(): __class__ cell not found
      I observed this in S26 if that helps.
      from typing import Optional
      doc: c4d.documents.BaseDocument # The document evaluating this tag
      op: c4d.BaseTag # The Python scripting tag
      flags: int # c4d.EXECUTIONFLAGS
      priority: int # c4d.EXECUTIONPRIORITY
      tp: Optional[c4d.modules.thinkingparticles.TP_MasterSystem] # Particle system
      thread: Optional[c4d.threading.BaseThread] # The thread executing this tag
          # Called when the tag is executed. It can be called multiple time per frame. Similar to TagData.Execute.
          # Write your code here
          pass
          # Called when the tag receives messages. Similar to TagData.Message.
          return super().Message(id, data)
      def draw(bd: c4d.BaseDraw) -> bool:
          # Called to display some visual element in the viewport. Similar to TagData.Draw.
        Hi the issue is that normally when you implement a tag you are within a class and more especially a TagData which inherit from a NodeData therefor you can call the method "super" without issue because there is indeed a class. But in this case there is no TagData instance, so for the moment there is no good way to propagate the message and you should return True.
        And I know this is the default code, this will be looked at and fixed within a future version.
          HerrMay
          Hi @m_adam,
          alrighty, good to know that this will be looked into and eventually get fixed.
          Yes, I remember I returned True in the past. In the python tag as well as in the TagData equivalent. As returning super didn't work.
          Thanks for the information anyway. πŸ™‚
