    BaseFile->Open crash
    15 Posts 0 Posters 1.6k Views
      On 22/12/2003 at 03:30, xxxxxxxx wrote:
      Have you actually allocated the BaseFile? the code above doesn't.
        On 23/12/2003 at 10:36, xxxxxxxx wrote:
        Thanks, yes I forgot to allocate it 😕
          On 12/02/2005 at 09:53, xxxxxxxx wrote:
          how do i have to alloc ?
          BaseFile *bfile=NULL;
            bfile->Alloc();
            bfile->Open(name,GE_WRITE);
          crashes again ) :
            On 12/02/2005 at 10:27, xxxxxxxx wrote:
            AutoAlloc<BaseFile> bfile;
            if (!bfile) /* panic */
            bfile->Open(...);
            // do file stuff
            bfile->Close();
            // bfile is automatically Free()'d when it goes out of scope
            or
            BaseFile *bfile;
            if (!(bfile = BaseFile::Alloc()) /* panic */
            bfile->Open(...);
            // do file stuff
            bfile->Close();
            BaseFile::Free(bfile);
              On 13/02/2005 at 08:48, xxxxxxxx wrote:
              thanks, it doesnt crash now,
              but my plugin still doesnt create a file ) :
              what´s wrong, this time
              LONG SMDFilter::Save(PluginSceneSaver *node, const Filename &name, BaseDocument *doc, LONG flags)
               doc = GetActiveDocument();
                  BaseObject *obj = doc->GetActiveObject();
                  if(obj)
                //IO
                if (!bfile) MessageDialog(" - no file");
                bfile->WriteString("Claude Bonet Tags: ");
                bfile->Close();
                On 13/02/2005 at 09:20, xxxxxxxx wrote:
                Have you checked that 'name' has content and points to a valid path?
                I can't see anything obviously wrong, otherwise.
                  On 13/02/2005 at 10:17, xxxxxxxx wrote:
                  BaseFile *file;
                    file = BaseFile::Alloc();
                    file->WriteString("test");
                    BaseFile::Free(file);
                  i tried it this way, too
                  nothing happens, no file created
                  i can´t see the mistake
                  could you give me a very little example for a plugin that saves a string to a file, plz ??
                  thanks
                    On 13/02/2005 at 11:23, xxxxxxxx wrote:
                    It works fine for me here:
                    AutoAlloc<BaseFile> bf;
                         if (!bf->Open(presetdirectory,GE_WRITE,FILE_NODIALOG,GE_MOTOROLA)) return FALSE;
                      On 13/02/2005 at 12:17, xxxxxxxx wrote:
                      ok, here is my code, i hope the variable "name" in the save-method is used correctly:
                      #include <stdio.h>
                      #include <stdlib.h>
                      #include <string.h>
                      #include <c4d.h>
                      class SMDFilter : SceneSaverData
                        virtual LONG Save(PluginSceneSaver *node, const Filename &name, BaseDocument *doc, LONG filterflags);
                        static NodeData *Alloc(void) { return gNew SMDFilter; }
                      LONG SMDFilter::Save(PluginSceneSaver *node,const Filename &name, BaseDocument *doc, LONG flags)
                          if(obj)
                        //IO
                        if (!bf->Open(name,GE_WRITE,FILE_NODIALOG,GE_MOTOROLA))
                        return FALSE;
                      //Polygoncount
                        char polybuffer [33];
                        GePrint("all Vertices: ");
                        GePrint(itoa(static_cast<PolygonObject *>(obj)->GetPointCount(),polybuffer,10));
                        //Claudebonet test
                              BaseTag *tag = obj->GetFirstTag();
                        char ibuffer [33];
                        int i=0;
                              while(tag->GetType() == Tclaudebonet)
                         GePrint(".............");
                         VariableTag *gtag = (VariableTag * )tag;
                         int cnt = gtag->GetDataCount();
                         Real *value = (Real * )gtag->GetDataAddress();
                         //read relevant values
                         i=0;
                         for(int a=0; a<cnt; a++)
                          if(value[a]==1.0) i++;
                         GePrint(itoa(i,ibuffer,10));
                         //go to the next tag
                         tag = tag->GetNext();
                          else MessageDialog(" - no object");
                      Bool RegisterSMD(void)
                        if(!RegisterSceneSaverPlugin(1111111,"SMDex",0, SMDFilter::Alloc, EXECUTION_RESULT_OK, 0, NULL)) return FALSE;
                      if so, what´s wrong here ?
                      thanks a lot for your help!!!
                        On 13/02/2005 at 12:23, xxxxxxxx wrote:
                        The rest of the code shouldn´t have an effect on the save operation. The save code is correct, not sure why it doesn´t work for you. I assume it has something to do with the SceneSaver hook. (however I cannot really judge it, as I haven´t used this hook yet).
                        Mikael probably knows what´s wrong here, so I suggest to wait for his support.
                        Katachi
                          On 15/02/2005 at 10:51, xxxxxxxx wrote:
                          ok, thanks anyway,
                          i hope Mikael can help me, soon
                            On 28/02/2005 at 13:11, xxxxxxxx wrote:
                            What return values do you get when not file is created?
                              On 28/02/2005 at 17:01, xxxxxxxx wrote:
                              i dont see any values in return
                                MessageDialog(" - no -");
                              "- no -" never appears 😞
                                On 09/03/2005 at 06:06, xxxxxxxx wrote:
                                i made another solution:
                                void writetofile(FILE *fi, String st)
                                 char *buffer = bNew char[st.GetLength()+1];
                                 for(int n=0; n < st.GetLength(); n++)
                                  buffer[n] = st[n];
                                 fwrite(buffer,1,st.GetLength(),fi);
                                    if(obj)
                                  CHAR header[80];
                                  ClearMem(header,sizeof(header));
                                  String str = name.GetString(),
                                      slash = "/";
                                  //SUFFIX check
                                  if(str.SubStr(str.GetLength()-4,4) != ".smd") str += ".smd";
                                  LONG count = str.GetCString(header,78,St7bit);
                                  char *ch = bNew char[count+1];
                                  //String to Char
                                  for(int a=0; a < count; a++)
                                   if(str[a]=='\') ch[a] = slash[0];
                                   else
                                    ch[a] = str[a];
                                  FILE *datei;
                                  datei = fopen(ch,"w+");
                                  if(datei)
                                   //file stuff
                                   writetofile(datei,"version 1\n");
                                   writetofile(datei,"nodes\n");
                                  fclose(datei);
                                //... other code
