    3D Mouse Slider Focus
    pythonwindowsr19maxon api
    13 Posts 5 Posters 4.4k Views 2 Watching
    • CairynC Offline
      Cairyn @AndreAnjos
      @andreanjos Well, I am around. CollieMouse is still active (as I am using it myself daily) but I have not got around porting it to R20 yet. I am bound to step into R20 development soon though.
      CollieMouse is an alternative controller however. It does not work through the abovementioned dialog but comes with its own dialogs. It does support the navigation cross and the newest 3Dconnexion functionalities.
      I have not officially offered CollieMouse again since only very few C4D users seem to utilize a SpaceMouse at all (personally, I find it indispensable) and there is an unsolved issue in the screen refresh, but I can still provide the plugin when there is interest.
      • A Offline
        AndreAnjos @Cairyn
        @cairyn Hi, Thanks for replying! The person that I'm helping uses R19, not sure if that would make a difference to you.
        Is it ok if he PM's you through CGTalk?
        Thank you for your help! ☺
        Andre
        • CairynC Offline
          Cairyn @AndreAnjos
          @andreanjos Sure, they can do that. I'm not sure whether CollieMouse can help directly, but I will listen to their issue.
          • A Offline
            AndreAnjos @Cairyn
            @cairyn Awesome! Appreciate your time! šŸ‘
            Andre
            • mocolocoM Offline
              mocoloco
              Hello @Cairyn, do you have now a working version of CollieMouse working for R23 and higher? If yes, could we have a short talk about it?
              Thanks a lot,
              Christophe
              • CairynC Offline
                Cairyn @mocoloco
                @mocoloco Yes, CollieMouse works under R23 (it's the first thing I update since it's a primary tool for me, except that I kinda skipped R20).
                Hey, this is a super old thread...
                • mocolocoM Offline
                  mocoloco
                  Thanks a lot @cairyn for your answer. Yes, that's a super old thread, but it's the one talking about CollieMouse šŸ˜‰
                  Do you have a link to get / buy it? The only link I found is about a v1.2 free, which is not working under R23.
                  Thanks a lot!
                  Christophe
                  • CairynC Offline
                    Cairyn @mocoloco
                    @mocoloco said in 3D Mouse Slider Focus:
                    I do have a R23 version. You may want to contact me under
                    cairyn at tigress dot com
                    to continue the talk; I guess this is not appropriate for this forum. Thanks!
                    • C Offline
                      charly
                      hello @Cairyn ! I would like to rotate around the point where the cursor is. Is there a way to do it with your plugin?
                      Is there a way to talk privately about it? thank you
                      • CairynC Offline
                        Cairyn @charly
                        @charly CollieMouse rotates around the current selection or the explicit rotation center (the one you set with the INS shortcut). It will not rotate around the mouse pointer (I think... I implemented so many modes over time that I tend to forget the options...). The mouse pointer only exists in 2D space anyway so the actual rotation would happen around a projection of the mouse position into the scene, and if you move the mouse, the rotational center would change... not sure whether that is even a usable mode.
                        The mode I'd recommend would be around the explicit center: Position the mouse, press INS (or whatever shortcut you use), and then use the 3D mouse to rotate around that. C4D shows the explicit center as green cross so you always know where it is.
                        At the moment there is no R2023 version of CollieMouse anyway, so the point is moot. But you can reach me under cairyn (at) tigress (dot) com if you require specialty development.
