    Editing RS Nodes with Python
    5 Posts 2 Posters 1.2k Views 1 Watching
    • C Offline
      cgweasel
      i have been wrapping my head around it, but I cannot find anything. Or maybe I am thinking the wrong way.
      What i want it to get selected Nodes out of my RS Material to edit the Parameters. But I cannot find anything in the SDK. Could not get anything out of the GvNode.
      What I would like the script to do:
      I want to select texture Nodes in my Materials and the script will change the color space to file-IO -> RAW
      Thanks and happy holidays 🦌
        Hi @cgweasel, to retrieve the selected node, like all BaseList2D (BaseOject,BaseTag,BaseMaterial, etc...) you can know there selection state with the method node.GetBit(c4d.BIT_ACTIVE).
        So find bellow the complete code to do what you want:
            # Checks if selected material is valid
            mat = doc.GetActiveMaterial()
            if not mat or not mat.CheckType(1036224) :
                raise ValueError("There is no xpresso redshift material selected")
            # Retrieve the output nodes, which is also the first node in the node hierarchy.
            # Therefor we can iterate them as usual BaseList2D
            node = mat[c4d.REDSHIFT_GRAPH_NODES]
            while node:
                # Check if this is a texture node and its selected
                if node[c4d.GV_REDSHIFT_SHADER_META_CLASSNAME] == 'TextureSampler' and node.GetBit(c4d.BIT_ACTIVE):
                    # Set to Raw, to know the Id and the value I left click on the Filename parameter, User Interface -> Show SubChannel
                    # Then I dragged the ColorSpace parameter to the python console
                    node[c4d.REDSHIFT_SHADER_TEXTURESAMPLER_TEX0,c4d.REDSHIFT_FILE_COLORSPACE] = "RS_INPUT_COLORSPACE_RAW"
                node = node.GetNext()
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          cgweasel @m_adam
          Hi Maxime,
          thank you very much. On a Xpresso Material, this works just fine. Unfortunately, I only use Node Materials. I know the type of those Materials is 5703, but it seems that everything else is not responding to nodes.
          Thanks for the tipp with the sub-channels. Awesome. But this also does not work with nodes 😞
            Hi @cgweasel hope you had a nice Christmas time πŸ™‚
            Regarding your question, this has been answered in this post Change the ColorSpace of Redshift Texture Node?
            Then you can find example about nodes graph in our GitHub repository, And I would advice you to look at modify_port_value.
            I think with that you have all the information needed to make it work, if you struggle please let me know and I will be happy to help you. For the future please specify which node system you are using, since you mentioned GvNode I guessed that you used xpresso.
              Hello @cgweasel,
              without further questions or postings, we will consider this topic as solved by Friday 02/06/2023 and flag it accordingly.
