    Wrong Polygon indices
    c++
    3 Posts 2 Posters 567 Views 1 Watching
    • F Offline
      fraukman2
      Hi everyone, I'm writing a small ray tracer, and I'm having problems with the mesh indices, the order is wrong.
      for(int i = 0;i < meshes.size();i++)
      				for (int k = 0; k < meshes[i].PolyCount;k++)
      					Int32 indexPointA = meshes[i].indices[k].a;
      					Int32 indexPointB = meshes[i].indices[k].b;
      					Int32 indexPointC = meshes[i].indices[k].c;
      					Tri triangle;
      					triangle.vertex0 = (meshes[i].vertices[indexPointA]) / 100.0f;
      					triangle.vertex1 = (meshes[i].vertices[indexPointB]) / 100.0f;
      					triangle.vertex2 = (meshes[i].vertices[indexPointC]) / 100.0f;
      					IntersectTri(ray, triangle);
      					if (ray.t < 1e30f)
      						_film->setImagePixel(x, y, 255, 255, 255);
      I'm using a plane (previously triangulated) to test and get this result:
      i debuged the indices and they are wrong.
      indices:
      {1,3,0} - triangle 1
      {1,2,3} - triangle 2
      this is how i get the polygons:
      void Scene::_recurseHierarchy(BaseObject* op)
      		while (op)
      			Bool isPolygon = op->IsInstanceOf(Opolygon) && !op->IsInstanceOf(Ojoint);
      			if (isPolygon)
      				Frog::Mesh mesh = {};
      				GePrint(op->GetName());
      				PolygonObject* poly = (PolygonObject*)op;
      				if (poly)
      					Int32 numOfVertices = poly->GetPointCount();
      					const CPolygon* cpoly = poly->GetPolygonR();
      					CPolygon* trianguled = nullptr;
      					const Vector* vetices = poly->GetPointR();
      					Int32 trianguledPolyCount;
      					Bool triRes = Triangulate(vetices, numOfVertices, &trianguled, &trianguledPolyCount);
      					if (triRes)
      						mesh.vertices = vetices;
      						mesh.indices = trianguled;
      						mesh.PolyCount = trianguledPolyCount;
      						objects.push_back(mesh);
      			_recurseHierarchy(op->GetDown());
      			op = op->GetNext();
      Can anyone point me what I'm doing wrong ?
        Hi @fraukman2 thanks for posting, for me it's looks like a bug, since if you use a polygon primitive instead of a plane, it work as expected. I think there is a remapping needed for the point indices and polygon indices but I don't get it.
        As it is the Christmas season, some members of the development team are away and the answer to this question may take longer than usual.
        But I will keep you posted as soon as I have more information.
        In the meantime, the easiest way would be to use MCOMMAND_TRIAGULATE that will triangulate the passed object.
        BaseObject* op = doc->GetActiveObject();
        if (!op)
        	return true;
        // This will triangle op, if you dont want to affect the object in the scene call GetClone first.
        PolygonObject* poly = static_cast<PolygonObject*>(op);
        ModelingCommandData mcd;
        mcd.op = op;
        if (!SendModelingCommand(MCOMMAND_TRIANGULATE, mcd))
        	return false;
        EventAdd();
        return true;
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          fraukman2 @m_adam
          Hi @m_adam, I just tested your suggestion and worked flawless, thank you very much.
          Cheers and happy holidays
