    Reset Scale With Compensate Points?
    r25python
    3 Posts 2 Posters 961 Views 1 Watching
    • B Offline
      bentraje
      Is there a python equivalent of Reset Scale With Compensate Points command?
      Illustration of what it does:
      1. Supposing you have a point in 200cm (in xyz) with the polygon object at 100 (in xyz)
      2. If you reset scale with no compensate, the point will be at 2cm and polygon at 1 scale.
      3. But if you scale with compensate, the point will still be at 200cm and polygon at 1 scale, which is what I'm after.
      P.S. There is an existing thread regarding the topic but its not resolved. Also its referring to a rig, which has complicated hierarchy. I'm only referring to ,
        Hi @bentraje you cna use the SendModelingCommang with the MDATA_RESETSYSTEM_COMPENSATE flag. All settings are explained in Python MCOMAND page. So do to what you are aiming for, you should do:
            settings = c4d.BaseContainer()
            settings[c4d.MDATA_RESETSYSTEM_COMPENSATE] = True
            settings[c4d.MDATA_RESETSYSTEM_RECURSIVE] = True
            res = c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_RESETSYSTEM,
                                            list=[op],
                                            mode=c4d.MODELINGCOMMANDMODE_ALL,
                                            bc=settings,
                                            doc=doc)
        • B Offline
          bentraje
          @m_adam
          Gotcha. Thanks for the response.
          It works but I was kinda looking for the thought process on how to implement it.
          Mainly because the command is only limited to scale. I was hoping I can modify it to include also rotation.
