    Get the Name of the Node?
    r25python
    7 Posts 3 Posters 2.0k Views 2 Watching
    • B Offline
      bentraje
      I understand its simple but a hard time using this once again.
      I tried using
      node.GetName() but it doesn't work. Errors out. Does not have that method.
      I tried also using the "port" method.
      port = node.GetInputs().FindChild("net.maxon.node.base.name")
      It does not work. Returns a null.
      Is there a way around this?
      • B Offline
        bentraje
        Also tried the following but to now avail.
        node.GetValue("net.maxon.node.base.name", expectedType=None)
        node.GetInputs().GetValue.GetValue("net.maxon.node.base.name", expectedType=None)
        DunhouD 1 Reply Last reply Reply Quote 0
        • DunhouD Offline
          Dunhou @bentraje
          @bentraje
          I think name atttribute is not easy as old c4d SDK to use . It cann't print in console .
          I use this to get Name , and Set Name .
          some codes in python sdk didn't work and return None .Maxon SDK has a example to get info form node retrieve_information_r26.py
              # 获取名称 :
              def GetNodeName(self, node, display=False):
                  Retrieve the displayed name of a node.
                  Parameters
                  Args:
                      node: (maxon.GraphNode): The node to retrieve the name from.
                      display: print info when display is True
                  Returns:
                      Optional[str]: The node name, or None if the Node name can't be retrieved.
                  if node is None:
                      return None
                  nodeName = node.GetValue(maxon.NODE.BASE.NAME)
                  if nodeName is None:
                      nodeName = node.GetValue(maxon.EffectiveName)
                      nodeName = str(node)
                  if display ==True :
                      print(nodeName)
                  return nodeName
          https://boghma.com
          https://github.com/DunHouGo
          B 1 Reply Last reply Reply Quote 2
          • B Offline
            bentraje @Dunhou
            @dunhou
            Thanks for response. Unfortunately, I'm at R25.
            So I can't use the maxon.NODE.BASE.NAME syntax.
            It errors out 😞
              Hi @bentraje you can download R25 scripts example at SDK - Cinema 4D R25 SP1 Release[URL-REMOVED]. Within examples\scripts\05_modules\node\retrieve_information_r24.py so previously you had to hardcode the ID like so:
                  def GetName(node):
                      if node is None:
                          return None
                      nodeName = None
                      # Retrieve the user-defined name (user renamed the node name)
                      nodeName = node.GetValue("net.maxon.node.base.name")
                          # Retrieve the default name
                          nodeName = node.GetValue("effectivename")
                      return nodeName
              @Dunhou here it work correctly, can you point us which code is not working and if you could provide us a scene this would be welcome.
              • B Offline
                bentraje
                @m_adam
                Thanks for the response.
                GetValue("effectivename") works as expected.
                Interesting. You have separate API for the original name vs the user renamed node.
                Might come in handy for me later on using the original name as the "type" of the node.
                Thanks again!
                  You have to be careful since the value returned by effectivename will change according of the Cinema 4D language. The best way is really to work with IDs.
                  Maxime
