    Geometry Axis asset node and LoadAssets
    pythons26
    7 Posts 4 Posters 1.6k Views 4 Watching
    • iplaiI Offline
      iplai
      My script works and I got what I want, but there are two problems.
      • maxon.AssetManagerInterface.LoadAssets always return False event the asset loaded successfully.
      • I set the parameters of Geometry Axis by find the param's name. Is there a better way to change the parameters?
      import maxon, c4d
      def loadGeometryAxis(x=0, y=0, z=0, parent: c4d.BaseList2D = None):
          repository = maxon.AssetInterface.GetUserPrefsRepository()
          if not repository:
              raise RuntimeError("Could not access the user preferences repository.")
          # Geometry Axis asset id
          assetid = maxon.Id("net.maxon.neutron.asset.geo.geometryaxis")
          assetsToLoad = [(assetid, ""), ]
          sceneNodesHook = doc.FindSceneHook(c4d.SCENENODES_IDS_SCENEHOOK_ID)
          if not sceneNodesHook:
              raise RuntimeError("Could not retrieve Scene Nodes scene hook.")
          sceneNodesHook.Message(maxon.neutron.MSG_CREATE_IF_REQUIRED)
          sceneNodes = sceneNodesHook.GetNimbusRef(maxon.neutron.NODESPACE)
          if not sceneNodes:
              raise RuntimeError("Could not retrieve Scene Nodes graph model.")
          graph = sceneNodes.GetGraph()
          didLoad = maxon.AssetManagerInterface.LoadAssets(repository, assetsToLoad, graphModelRef=graph)
          if not didLoad:
              # `didLoad` is always False, event the asset loaded successfully.
              # What's wrong?
              # raise RuntimeError(f"Could not load assets for the ids: {assetsToLoad}")
          obj = doc.GetFirstObject()
          # Is there is a better way to change the parameters?
          for bc, descid, _ in obj.GetDescription(c4d.DESCFLAGS_DESC_0):
              name = bc[c4d.DESC_NAME]
              if name == "Axis X":
                  obj[descid] = x
              if name == "Axis Y":
                  obj[descid] = y
              if name == "Axis Z":
                  obj[descid] = z
          if parent is not None:
              obj.InsertUnderLast(parent)
          cube = c4d.BaseObject(c4d.Ocube)
          loadGeometryAxis(y=1, parent=cube)
          doc.InsertObject(cube)
      C4DJSON -- a useful module to load an dump c4d objects in python dict format (similar to standard python json module).
      Examples on Notion.
        In this case, the asset loaded is a capsule. For capsule, the return value can be false. This looks like a bug in our API. One remark about your code, as you want to load a capsule, you do not need to pass a graphModelRef to the LoadAssets function.
        How to access or change the parameter value, is a good question. To access the data, you must use the descID as you understood but the descID of capsules are exceptionally long. It seems those descID are based on either the path of the port or the ID of the port.
        I asked the devs but for now, it seems that the best attribut to identify the parameter is its name. Of course, this is bad as the name will change from languages to languages.
        iplaiI 1 Reply Last reply Reply Quote 0
        • iplaiI Offline
          iplai @Manuel
          @manuel
          Thank you very much to answer my confusion. If I do not need to pass a graphModelRef to the LoadAssets function, my code can be simplified a lot. Can it be okay to identify the parameter by the index of iterating the capsule's description. Since the capsule is newly created, and there're no extra parameters, so it seems the index is fixed.
          First, get the index by following code.
          for i, (bc, descid, _) in enumerate(capsule.GetDescription(c4d.DESCFLAGS_DESC_0)):
                  print(i) # 59
                  print(i) # 60
                  print(i) # 61
          Then, the total function def:
          def loadGeometryAxis(x=0, y=0, z=0, parent: c4d.BaseObject = None):
              if not repository:
              maxon.AssetManagerInterface.LoadAssets(repository, assetsToLoad)
              capsule = doc.GetFirstObject()
                  if i == 59:
                      capsule[descid] = x
                  if i == 60:
                      capsule[descid] = y
                  if i == 61:
                      capsule[descid] = z
                  capsule.InsertUnderLast(parent)
              return capsule
          Examples on Notion.
          • DunhouD Offline
            Dunhou
            Hi there,
            In C4D 2024, the Geometry Axis can not accessible in python anymore, how can I fix that?
            from typing import Optional
            op: Optional[c4d.BaseObject]  # The active object, None if unselected
                for i, (bc, descid, _) in enumerate(op.GetDescription(c4d.DESCFLAGS_DESC_0)):
                        print(i,descid)
                        print(op[descid])
            2023
            Cheers~
            DunHou
            https://boghma.com
            https://github.com/DunHouGo
              Thanks a lot for the report !
              I will need to debug it properly but it appear that there is a bug in the conversion layer when subscription is used in conjunction of nested data like the one produced by Graph.
              In the meantime please use the next code:
                  for i, (bc, descid, _) in enumerate(op.GetDescription(c4d.DESCFLAGS_DESC_NONE)):
                          print(op.GetParameter(descid, c4d.DESCFLAGS_GET_NONE))
                          op.SetParameter(descid, 0.25, c4d.DESCFLAGS_SET_NONE)
                This is indeed a regression and it will be fixed in the next Cinema 4D release.
                The issue is that Python was generating wrong DescId since forever in case of multiple sub level entry. Previously the system was able to return a value but due to some optimization on parameter access this was not working anymore.
                  m_adam @Dunhou
                  @Dunhou said in Geometry Axis asset node and LoadAssets:
                  Hi there,
                              print(i,descid)
                              print(op[descid])
                  2023
                  Cheers~
                  DunHou
                  Hi, this issue have been fixed in 2024.2 and your code is working as it was previously.
