    Iterate through all Inputs and Outputs of a Given Node?
    r25python
    5 Posts 2 Posters 675 Views 1 Watching
    • B Offline
      bentraje
      I'm trying to retrieve inputs and outputs of a selected node. But it gives me error when using the result from the GetInputs or GetOutputs method
          def RetrieveInformationOfNode(node):
              port = node.GetOutputs()
              for p in port:
                  print (p.name) # or p.GetName. Not sure. I can't receah this part of the code.
          graph.GetSelectedNodes(RetrieveInformationOfNode, maxon.frameworks.graph.NODE_KIND.ALL_MASK)
      The error:
      TypeError: 'GraphNode' object is not iterable
      But the documentation says Output port list of this node.
      Isn't a list iterable?
        GetInputs/GetOuputs return a GraphNode. This Graphnode contains all the Inputs or the Outputs port that the Node contains but they are a child of this GraphNode. As this is still a GraphNode, you need to use one of those function. GetChildren, GetInnerNodes.
        import maxon
        # Display the outputs ports of the selected nodes in the active NodeMaterial of the Active Nodespace.
            # Retrieve the selected BaseMaterial
            mat = doc.GetActiveMaterial()
            if mat is None:
                raise ValueError("There is no selected BaseMaterial")
            # Retrieve the reference of the material as a node material.
            nodeMaterial = mat.GetNodeMaterialReference()
            if nodeMaterial is None:
                raise ValueError("Cannot retrieve node material reference")
            # Retrieve the current node space Id
            nodespaceId = c4d.GetActiveNodeSpaceId()
            # Retrieve the graph corresponding to that node space.
            graph = nodeMaterial.GetGraph(nodespaceId)
            if graph is None:
                raise ValueError("Cannot retrieve the graph of this nimbus ref")
            def DisplayOutputs(node):
                # Will display node information
                def PrintNodeInformation(port):
                    # Print here the needed information
                    print (port)
                def DisplayChildren(node):
                    # Check if the node is valid and recursively display children.
                    if not node.IsValid():
                    PrintNodeInformation(node)
                    node.GetChildren(DisplayChildren)
                # Retrieve the outputs port and the first level of children with GetChildren.
                node.GetOutputs().GetChildren(DisplayChildren)
            # Retrieve the nodes that are selected and passed them to the function DisplayOutputs.
            maxon.GraphModelHelper.GetSelectedNodes(graph,  maxon.NODE_KIND.NODE, DisplayOutputs)
            print('---------------- using Inner')
            # using GetInnerNodes
            def DisplayInner(node):
                def PrintNode(port):
                    print(port)
                node.GetInnerNodes(maxon.NODE_KIND.OUT_MASK, False, PrintNode)
            maxon.GraphModelHelper.GetSelectedNodes(graph,  maxon.NODE_KIND.NODE, DisplayInner)
        • B Offline
          bentraje
          Ah so I guess there's really no port object. Everything is graph node object.
          How would I know the object is an actual node or a port of an node?
          Wouldn't it have been better if there is an actual port object and have just the port object a subclass of a the graph node so it inherits the methods?
          P.S. The script works as expected, athough I have to modify it to work for R25.
            you can have a look at this page you can see that GraphNode elements can be represented by a hierarchy. As written in that page, to know the node kind, use GetKind. That will return you its NODE_KIND.
            There is no "ports" class, only GraphNode. The implementation does not always reflect what the user sees.
            B 1 Reply Last reply Reply Quote 0
            • B Offline
              bentraje @Manuel
              @manuel
              ah gotcha. the node kinda. thanks.
              will close this thread for now.
