    Remove node from Redshift node graph
    s26c++
    3 Posts 2 Posters 555 Views 1 Watching
    • S Offline
      spedler
      I'm following the Redshift renderer page in the SDK for R26.1 to create nodes in a Redshift node graph. This all works fine, and adding nodes and making connections is all good. But I wondered, adding a node is simple but how do you remove a node? If adding a node works like this:
      const::maxon::nodes::NodesGraphModelRef& nodeGraph = nodeMat->GetGraph(redshiftId) iferr_return;
      maxon::GraphNode textureNode = nodeGraph.AddChild(maxon::Id(), textureId) iferr_return;
      Then I'd have expected something like this to be available:
      nodeGraph.RemoveChild(textureId);    // no such function
      But there is nothing like this to use. There is a Remove() function in the GraphModelInterface class but it's protected and not available from the NodesGraphModelRef class.
      Is there a way to delete nodes from a Redshift material node graph? I wondered about using ReplaceChild() to replace the node to be deleted with nothing, but there doesn't seem to be a way to do that either.
        GraphNode is a friend class of GraphModelInterface, so you should call textureNode.Remove()
        For more information please read GraphNode Manual.
        • S Offline
          spedler
          Ah...so simple in the end! Navigating this maze of interdependent classes used in the node system is not easy, that's my excuse 🙂
          Many thanks for this, it solves a very tricky problem I was having.
          Steve
