    How do I get the status of redshift AOV mode?
    2 Posts 2 Posters 496 Views 1 Watching
      honear
      working on something in python, and i'm trying to create some if statements depending on whether AOV's are Enabled or Disabled. The Command Line tells me to use "Redshift[c4d.REDSHIFT_RENDERER_AOV_GLOBAL_MODE]" but this only returns "None" regardless of whether it's enabled or disabled. How do I access this data?
      Thank you
        Please mark your thread as a question using the forum tools.
        Redshift is a VideoPostData plugin. You cannot access the parameter directly in the renderdata. This is just a guess of what you are trying to do.
        Instead, you must find the VideoPostData that contain all Redshift parameters.
        from typing import Optional
        import redshift
        op: Optional[c4d.BaseObject]  # The active object, None if unselected
            renderdata = doc.GetActiveRenderData()
            vprs = redshift.FindAddVideoPost(renderdata, redshift.VPrsrenderer)
            if vprs is None:
                raise ValueError("Cannot find the redshift VideoPostData")
            print (vprs[c4d.REDSHIFT_RENDERER_AOV_GLOBAL_MODE])
        There is this thread where you will find a script to print all the AOVs
