    GeDialog Failing To Open
    c++s26sdk
    6 Posts 2 Posters 1.1k Views 1 Watching
    • J Offline
      JohnTerenece
      Hello.
      I am encountering a problem when I insert my object plugin into a scene in R26, save the document and then reopen the file. When I click the button to open the GeDialog Cinema immediately crashes on me.
      I stripped down the code for my GeDialog to the bare minimum that was still similar to the examples in the sdk and the problem is still occurring.
      #include "c4d_general.h"
      #include "c4d.h"
      #include "c4d_symbols.h"
      #include "main.h"
      #define ID_RUNDIALOG 1059364
      enum Controls
      	idSendMessageLinkObject = 1000,
      	idLinkedObject,
      	idGatherChildren,
      	idOverallScrollGroup = 2000,
      	idGroupToFlush,
      	idControls,
      	idLaunchDialogWindow = 1500,
      	idBasicControlGroup,
      class ObjDialog : public GeDialog
      	ObjDialog() {}
      	virtual ~ObjDialog() {}
      	virtual Bool CreateLayout();
      	virtual Bool InitValues();
      	virtual void DestroyWindow();
      	virtual Bool Command(Int32 id, const BaseContainer& msg);
      	virtual Int32 Message(const BaseContainer& msg, BaseContainer& result);
      Bool ObjDialog::CreateLayout()
      	Bool res = GeDialog::CreateLayout();
      	SetTitle("Dialog Window"_s);
      	ScrollGroupBegin(idOverallScrollGroup, BFH_SCALEFIT | BFV_SCALEFIT, SCROLLGROUP_VERT | SCROLLGROUP_HORIZ);
      		GroupBegin(idGroupToFlush, BFH_SCALEFIT | BFV_SCALEFIT, 1, 0, String(), 0);
      			GroupBegin(idControls, BFH_SCALEFIT | BFV_SCALEFIT, 5, 0, String(), 0);
      			GroupEnd();
      		GroupEnd();
      	GroupEnd();
      	return res;
      Bool ObjDialog::InitValues()
      	if (!GeDialog::InitValues())
      		return false;
      	return true;
      void ObjDialog::DestroyWindow() {}
      Bool ObjDialog::Command(Int32 id, const BaseContainer& msg)
      	return true;
      Int32 ObjDialog::Message(const BaseContainer& msg, BaseContainer& result)
      	return GeDialog::Message(msg, result);
      class RunDialog : public ObjectData
      	virtual Bool Init(GeListNode* node);
      	virtual BaseObject* GetVirtualObjects(BaseObject* op, HierarchyHelp* hh);
      	virtual Bool Message(GeListNode* node, Int32 type, void* t_data);
      	virtual Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags);
      	static NodeData* Alloc() { return NewObjClear(RunDialog); }
      	maxon::BaseArray<BaseObject*> objArrayToCheckForMatch;
      private:
      	ObjDialog dlg;
      Bool RunDialog::GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &flags)
      	BaseContainer *dataInstance;
      	const DescID *singleid;
      	if (!description->LoadDescription(node->GetType()))
      	dataInstance = ((BaseList2D*)node)->GetDataInstance(); // Get the container for the tag
      	if (!dataInstance)
      		return FALSE;
      	singleid = description->GetSingleDescID();
      	DescID cid;
      	DescID DescHelperControlGroup = DescLevel(idBasicControlGroup, DTYPE_GROUP, 0);
      	if (!singleid || DescHelperControlGroup.IsPartOf(*singleid, NULL))
      		BaseContainer bc;
      		bc = GetCustomDataTypeDefault(DTYPE_GROUP);
      		bc.SetString(DESC_NAME, "Run Dialog"_s);
      		bc.SetInt32(DESC_COLUMNS, 1);
      		bc.SetInt32(DESC_DEFAULT, 1);
      		bc.SetBool(DESC_SCALEH, TRUE);
      		if (!description->SetParameter(DescHelperControlGroup, bc, DescLevel(ID_RUNDIALOG)))
      	cid = DescLevel(idLaunchDialogWindow, DTYPE_BUTTON, 0);
      	if (!singleid || cid.IsPartOf(*singleid, NULL))  //  important to check for speedup c4d!
      		BaseContainer bc;
      		bc = GetCustomDataTypeDefault(DTYPE_BUTTON);
      		bc.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_BUTTON);
      		bc.SetString(DESC_NAME, "Open Dialog"_s);
      		if (!description->SetParameter(cid, bc, DescHelperControlGroup))
      	flags |= DESCFLAGS_DESC::LOADED;
      Bool RunDialog::Init(GeListNode* node)
      	return true;
      Bool RunDialog::Message(GeListNode* node, Int32 type, void* t_data)
      	if (type == MSG_DESCRIPTION_COMMAND)
      		DescriptionCommand *dc = (DescriptionCommand*)t_data;
      		if (!dc)
      		Int32 ID = Int32(dc->_descId[0].id);
      		BaseDocument* doc = node->GetDocument();
      		if (!doc)
      		switch (ID)
      			// Problem occurs here
      			case idLaunchDialogWindow:
      				if (dlg.IsOpen() == false)
      					dlg.Open(DLG_TYPE::ASYNC, ID_RUNDIALOG, -1, -1, 300, 200, 0, OPENDIALOGFLAGS::IGNORELAYOUT);
      				break;
      	return true;
      BaseObject* RunDialog::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh)
      	BaseObject *nullReturn = BaseObject::Alloc(Onull);
      	return nullReturn;
      Bool RegisterRunDialog()
      	return RegisterObjectPlugin(ID_RUNDIALOG, "Run Dialog"_s, OBJECT_GENERATOR | OBJECT_INPUT, RunDialog::Alloc, "ORunDialog"_s, AutoBitmap("atom.tif"_s), 0);
      I've used this same code in R20 and R25 and haven't had a single issue with opening the GeDialog, I only started encountering the problem in R26.
      Looking at the examples in the sdk that deal with GeDialogs they are all opened via a CommandData plugin and the GeDialog manual specifically mentions that GeDialog based windows are typically owned by a CommandData plugin.
      Is it now a requirement to use a CommandData plugin to open a GeDialog?
      Any help would be greatly appreciated.
      John Terenece
        I am not able to reproduce the issue. Are you compiling in debug or release mode?
        • J Offline
          JohnTerenece
          Release mode.
            hi, sorry i missed the fact it is mandatory to save the file and reopen it.
            I was able to reproduce the issue. I need to ask ours devs the best way to fix this.
              The issue is happening because no dialog operation should be done from a thread. Loading the scene is now done asynchronously and the object creation is done in a thread. The GeDialog constructor will be called from a thread and fail.
              My suggestion is to replace the GeDialog variable by a pointer and be sure that the allocation and the deletion is done in the mainthread.
              Because the GeDialog was not initialised correctly, the CDIalog was not defined so the function dlg.IsOpen() was crashing.
              For extra check, you can check CDialog against nullptr like so
              CDialog* intern = dlg->Get();
              I also change the TRUE to true. TRUE should be avoided.
              #include "c4d.h"
              #include "maxon/thread.h"
              enum Controls
              	idLinkedObject,
              	idGatherChildren,
              	idGroupToFlush,
              	idControls,
              			GroupEnd();
              		GroupEnd();
              	GroupEnd();
              	return res;
              		return false;
              	return true;
              	return true;
              	void Free(GeListNode* node) override;
              private:
              	ObjDialog *dlg = nullptr;
              	if (dlg == nullptr)
              		maxon::ExecuteOnMainThread([this]()
              				dlg = NewObjClear(ObjDialog);
              	return true;
              void RunDialog::Free(GeListNode* node)
              	if (dlg)
              				DeleteObj(dlg);
              				dlg = nullptr;
              Bool RunDialog::GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags)
              	BaseContainer* dataInstance;
              	const DescID* singleid;
              	if (!dataInstance)
              		return FALSE;
              	DescID cid;
              		BaseContainer bc;
              		bc.SetBool(DESC_SCALEH, true);
              			return true;
              		BaseContainer bc;
              			return true;
              	return true;
              		DescriptionCommand* dc = (DescriptionCommand*)t_data;
              		if (!dc)
              			return true;
              		if (!doc)
              			return true;
              		switch (ID)
              				if (dlg)
              					if (intern)
              						if (dlg->IsOpen() == false)
              							dlg->Open(DLG_TYPE::ASYNC, ID_RUNDIALOG, -1, -1, 300, 200, 0, OPENDIALOGFLAGS::IGNORELAYOUT);
              				break;
              	return true;
              	BaseObject* nullReturn = BaseObject::Alloc(Onull);
              	return nullReturn;
              Bool RegisterRunDialog();
              	return RegisterObjectPlugin(ID_RUNDIALOG, "Run Dialog"_s, OBJECT_GENERATOR | OBJECT_INPUT, RunDialog::Alloc, ""_s, AutoBitmap("atom.tif"_s), 0);
              • J Offline
                JohnTerenece
                Thanks for the response. This seems to have solved the problem.
                John Terenece
