    How can I add a menu to .res file for muti-language support?
    s26pythonwindows
    14 Posts 2 Posters 2.1k Views 1 Watching
    • DunhouD Offline
      Dunhou @ferdinand
      I try to do this but it report a bug , here is a more part of codes:
      plugin.pyp
      ID_MB = 100 # button ID
          def CreateLayout(self):
              IDS_MENU: int = 20002 # MENU str ID in c4d_symbols.h
              myLocalizedString: str = c4d.plugins.GeResource.LoadString(IDS_MENU)
              # buttton in menu
              if self.GroupBeginInMenuLine():
                  self.AddButton(self.ID_MB, c4d.BFH_LEFT | c4d.BFV_TOP, name=myLocalizedString)
              self.GroupEnd()
              return self.LoadDialogResource(20001) # DIALOG ID in c4d_symbols.h
      c4d_symbols.h
      enum {
      _FIRST_ELEMENT_ = 20000,
      IDD_DIALOG,
      IDS_MENU,
      _DUMMY_ELEMENT_
      IDD_DIALOG.res in resources :
      DIALOG IDD_DIALOG
        NAME IDS_DIALOG; SCALE_V; SCALE_H;
      c4d_strings.str in strings_en-US/dialogs folder
        IDS_DIALOG    "Title";
        IDS_MENU   "button1";
      console reports
      TypeError: descriptor 'LoadString' for 'c4d.plugins.GeResource' objects doesn't apply to a 'int' object
      https://boghma.com
      https://github.com/DunHouGo
      • DunhouD Offline
        Dunhou
        sorry for my bad internet those days,It will duplicate post sometimes
        https://boghma.com
          eh, my bad I overlooked that you were using an incorrect call for loading the string. Since you you are in the pyp file, you do not have to init the ressource yourself, as the module attribute __res__ of that file already contains it (just put a print(__res__) anywhere in your code in the pyp file, and you will see that it is a GeResource instance).
          In your case you just have to use
          myLocalizedString: str = c4d.plugins.GeLoadString(IDS_MENU)
          which will then use the resource __res__ which has been build automatically by Cinema 4D for your plugin. It is only when you are outside of that pyp file, that you must build the GeResource
          When you are in such scenario or just want to generally load a custom resource, it will work something like this:
          resource: c4d.plugins.GeResource = c4d.plugins.GeResource()
          # resourcePath is the root folder of where the resource is located. E.g., you have the plugin MyPlugin
          # at the directory /MyPlugin with a directory /MyPlugin/res in it, then resourcePath would be /MyPlugin
          resource.Init(resourcePath)
          # You can then either expose this resource as the module resource and then use c4d.plugins.GeLoadString
          # as in a pyp file.
          global __res__
          __res__: c4d.plugins.GeResource = resource
          # Or use the resource instance directly.
          myLocalizedString: str = resource.GeLoadString(IDS_MENU)
          DunhouD 1 Reply Last reply Reply Quote 0
          • DunhouD Offline
            Dunhou @ferdinand
            Sorry to reply late. Little busy before.
            I am a little confused , in python document Plugin Structure , This page said plugin structure like this:
            It's different with the structure above.
            And another problem is : In my mind , string_us/dialogs/IDD_DIALOG.str , this str file define the dialogs texts string , but the string_us/c4d_strings.str file , It's a little confused , is it define the strings in the menu of the dialog? If it is , how can I set the ID of this string ?
            And in the code above, myLocalizedString: str = c4d.plugins.GeResource.LoadString(20002) , this line cann't find a string in IDD_DIALOG.str with the ID(int) in c4d_symbols.h .
            https://boghma.com
              ferdinand @Dunhou
              Hello @dunhou,
              You are right, my little diagram was not correct, the string folders must be part of the resource, I forgot to indent them one level. I have fixed the diagram.
              The string definitions in language\dialog, e.g., string_us/dialogs/myDialog.str, define the strings referenced by a dialog definition, e.g., dialogs/myDialog.res. E.g., when you have some dialog gadget which is defined to have NAME IDS_MY_GADGET in myDialog.res, the myDialog.str files for all languages must define a string IDS_MY_GADGET.
              The file c4d_strings.str on the other hand is used to store generic string, and it is not specifically made for menus, it is just one way you can use it. There is no (public) mechanism to define menus in resources, so, all you can do is to define strings in the c4d_strings.str files and then load strings for the currently active language inside Cinema 4D to build a localized menu out of them.
              You can see this multipurpose nature at the example of the strings_en-US/c4d_strings.str file of the Asset API Examples Plugin. I stored there all kinds of string information, ranging from tooltips, over the names of the examples and their short descriptions, to some URLs. c4d_strings.str does exactly what its name implies, it stores generic strings.
              I hope this clarifies things.
              • DunhouD Offline
                Dunhou @ferdinand
                A lot of appreciate!
                It works very well , I found when I have a c4d_strings.str , the myDialog.str must have SAME name as myDialog.res . If it doesn't have a c4d_strings.str file and work with only one dialog , the myDialog.str can have another name and it works well too.
                (I am not sure this qustion should be post there or in a new blog😢 )
                And a little thing I am not sure is : those ID form c4d_symbols.h contain the ID of text/bitmap/button/... , in this case main dialog ID is 20000 , but if I have mutiple dialogs or sub dialogs from the main dialog(even another plugins), what is happend if those dialog's ID contain some same numbers?
                https://boghma.com
                  ferdinand @Dunhou
                  Hey,
                  You cannot do that, all integer identifiers for dialogs within a project (i.e., stuff the is located in the same resource directory) must be unique. Except for cycle values, they only do have to be unique within the scope of the cycle/dropdown they are being defined for.
                  If you really want to have two dialogs which share ID values for gadgets, then you must define them in different projects, each with their own resource directory. Which will also mean that the two dialogs cannot access each other's implementation (in an easy manner, you could of course cook something up with messages for example).
                  • DunhouD Offline
                    Dunhou @ferdinand
                    Is that means if I have a plugin A with unique ID A , the dialog ID 100 likes A-100 inside , and plugin B with unique ID B , the dialog ID 100 likes B-100 , so that they can exist at same time ?
                    And those A-100 like IDs will dispear when close c4d , so I don't have to unreg them :eg.: bitmapbutton IDs manually? ( c4d.gui.RegisterIcon / c4d.gui.UnregisterIcon)
                    https://boghma.com
                      Yes, other than plugin IDs, resource IDs are scoped within the resource they are being used for. plugin A is simply not aware of the resources of plugin B.
                      You do not have to register or unregister anything in this context.
                      • DunhouD Offline
                        Dunhou @ferdinand
                        Thaks for all of that explains .
                        With your detailed and friendly explains , A new habbitor like me can code within Cinema 4D as well . Thanks for that !🤣
                        https://boghma.com
