    AdditionalCompileOptions in xcode
    3 Posts 2 Posters 858 Views 1 Watching
    • U Offline
      user168462
      Hi guys,
      I am currently looking at adding some compilation option into projectdefinition.txt in macos.
      When I look into https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_projecttool.html I can find the AdditionalCompileOptions which is for windows but not the equivalent for macos.
      Do you know how I can pass option to xcode through the project definition ?
      Thank you in advance
      Best
        I'm restoring that thread because that could be relevant for others. What kind of options you want to add?
        If you find the solution, you can share your story so it will help everybody
        • U Offline
          user168462
          Hi Manuel,
          Actually I couldn't find a clean answer..
          The only way I found was to set some files into ../frameworks/settings/...
          Best,
