    Export multiple GLB files via script
    2 Posts 2 Posters 502 Views 1 Watching
    • K Offline
      kinetikos
      Is it possible to export a sequence of .glb files via scripting? Or even one at a time would be helpful, as I have many thousands to export and the regular path to export is quite cumbersome.
      I have seen the .gltf export script featured in the forums, and my attempts to modify it have failed so far.
      Thanks in advance!
        We have an example on github to export to obj and how to define the parameters, you can find it here
        You need to retrieve the plugins with its plugin ID GLTFEXPORTER_PLUGIN_ID 1041129 There is no symbol attached for it.
        Then, you must send the message MSG_RETRIEVEPRIVATEDATA to define the option you want.
        For each parameter you will find its ID in the following file : \resource\modules\gltf\description\fgltfexporter.res
        You will find that the parameter you want to change is c4d.GLTFEXPORTER_FILEFORMAT and it should be set to c4d.GLTFEXPORTER_FILEFORMAT_GLB
        So just like in this line, you will write
         objExport[c4d.GLTFEXPORTER_FILEFORMAT] = c4d.GLTFEXPORTER_FILEFORMAT_GLB
        You should be able to clean the code from the obj example and adapt it to your needs. That will help for your thousands of exports.
