    incorrect specular channel property ids
    3 Posts 2 Posters 869 Views 1 Watching
    • indexofrefractionI Offline
      indexofrefraction
      just FYI, some of the specular channel properties give (sometimes completely) wrong ids when dragged to the console...
      eg.
      c4d.REFLECTION_LAYER_MAIN_VALUE_ROUGHNESSLINK
      should be
      c4d.REFLECTION_LAYER_MAIN_SHADER_ROUGHNESS
      c4d.REFLECTION_LAYER_FRESNEL_VALUE_STRENGTHREAL
      should be
      etc
      best, index
        Hi @indexofrefraction you should useREFLECTION_LAYER_MAIN_SHADER_ROUGHNESS for REFLECTION_LAYER_MAIN_VALUE_ROUGHNESSLINK and you are right for the second this is REFLECTION_LAYER_FRESNEL_VALUE_STRENGTH
        The bug you mention was already reported in How to set a Shader for Roughness ???? and so far have not been fixed. If you want to know the real Id you can take a look at c4d_reflection.h
          indexofrefraction
          tx, i just wanted to report it...
          • maxonM maxon moved this topic from Cinema 4D SDK on
