    How can I set a selection after I create a selection tag?
    3 Posts 2 Posters 848 Views 1 Watching
    • L Offline
      LingZA
      edited by [ @ferdinand ]:
      How can I set the selection state the underlying c4d.BaseSelectof a c4d.SelectionTag?
      @LingZA said:
      For an exmaple like op.MakeTag(c4d.Tedgeselection).
      BaseSelect1.CopyTo(BaseSelect2)
      BaseSelect2 is of selection tag.
        ferdinand @LingZA
        Hello @lingza,
        Thank you for reaching out to us. Please read our forum guidelines.
        • Please provide a meaningful description of your problem in the body of a topic. Even a very descriptive topic title as yours is not enough alone.
        • Do not create multiple postings in a topic until someone has answered.
        • If you solve a problem yourself, or gather information that describes your problem better, please edit that information into your original question.
        • Please also refrain from deleting postings in cases where your posting did not contain incorrect information. When you delete your question and only leave your own answer, a topic will become hard to read for other users who might have the same question.
        I did restore and consolidate your postings for you in this case. I also provided a small example snippet which provides an answer, even though you have a solution of your own.
        """Provides an example for writing the selection state of a point selection tag.
        The script will get an existing or create a new point selection tag for the selected object and
        write a random point selection into that tag.
        from typing import Optional
        import random
        op: Optional[c4d.BaseObject]  # The active object, None if unselected
            # Ensure the active object can carry a point selection tag in a meaningful way; is a point
            # object that has at least one vertex.
            if not isinstance(op, c4d.PointObject) and op.GetPointCount() > 0:
                raise RuntimeError("Please select a polygon or spline object that does contain vertcies.")
            # Get the first existing point selection tag on the object or create a new one.
            tag = op.GetTag(c4d.Tpointselection)
            if not isinstance(tag, c4d.SelectionTag):
                tag = op.MakeTag(c4d.Tpointselection)
            # Get the number of vertices in the object, the selection from the tag, and build a generator
            # for a random set of vertex indices.
            pointCount = op.GetPointCount()
            selection = tag.GetBaseSelect()
            selectionCount = max(1, int(pointCount / 4))
            indeciesToSelect = random.choices(range(pointCount), k=selectionCount)
            # Deselect all items in the selection first and then select all new indices which should be
            # selected.
            selection.DeselectAll()
            for index in indeciesToSelect:
                selection.Select(index)
            # Push an update event to Cinema 4D. The selection tag will now contain the new selection which has
            # been defined for #selection.
          Hello @LingZA,
          without any further questions or other postings, we will consider this topic as solved and flag it as such by Friday, 17/06/2022.
