    Copy Paste Point Global Position
    3 Posts 2 Posters 935 Views
    • ymoonY Offline
      ymoon
      I want copy point position(World) & paste to Other Object's Point(World).
      The coordinate manager can displays the World-Position values. but there is no copy paste function.
      You can use the Snap function of C4D, but I want to reduce even one click.
      I want to create two scripts and assign a shortcut key to each.(copy / pate)
      Python is not easy. Ask for help.
          sel_pt = op.GetPointS()
          id_sel_pt = 0
          for i in range(op.GetPointCount()):
               if sel_pt.IsSelected(i):
                   id_sel_pt = i
          objectmg = op.GetMg()
          selgmg = op.GetPoint(id_sel_pt) * objectmg
          print(selgmg)
          c4d.CopyStringToClipboard(selgmg)
      Paste Clipboard --> c4d.GetStringFromClipboard()
      Move Point --> op.SetPoint(id,c4d.Vector())
      • CairynC Offline
        Cairyn @ymoon
        @ymoon
        selgmg is a c4d.Vector, while GetStringFromClipboard expects a string, so Python uses the str function to convert, which results in an unwieldy string like
        Vector(50, 0, 0)
        If you want to put that string back into a vector, you need to parse it - I don't think there is an API function that does that.
        However, you can solve the parsing issue pretty quickly by putting a JSON string to the clipboard instead which represents the three components of the vector:
        import json
            id_sel_pt = 0
                     id_sel_pt = i
            selgmgStr = json.dumps([selgmg.x, selgmg.y, selgmg.z])
            print(selgmg, selgmgStr)
            c4d.CopyStringToClipboard(selgmgStr)
        Then the readback would be just as easy:
        import json
            selgmgStr = c4d.GetStringFromClipboard()
            selgmgList = json.loads(selgmgStr)
            selgmg = c4d.Vector(selgmgList[0], selgmgList[1], selgmgList[2])
            print(selgmg, selgmgList, selgmgStr)
            id_sel_pt = 0
                     id_sel_pt = i
            op.SetPoint(id_sel_pt, selgmg * ~objectmg)
            op.Message (c4d.MSG_UPDATE)
        Python for C4D scripting:
        https://www.patreon.com/cairyn
        ymoonY 1 Reply Last reply Reply Quote 1
        • ymoonY Offline
          ymoon @Cairyn
          @cairyn
          It Works. Thank You. Very Much.
