    Limit On the Number Of Takes
    c++r20sdk
    4 Posts 2 Posters 1.5k Views 1 Watching
    • J Offline
      JohnTerenece
      Hi.
      I am running into an issue when creating a large number of takes where Cinema is crashing on me, and this problem seems unrelated to the actual creation of the takes.
      Using my code I try to create a large number of takes, around 1400, with parameters overridden for objects in the scene, at some point during the creation process Cinema will crash. I recreated the case inside of CInema without my code by creating a take with one overridden object and then copy and pasting it, when I get to around 1400 takes in the document Cinema crashes on me.
      Is this just a limitation of Cinema when it comes to takes and that it can't handle that many inside of one document? Having multiple documents with a thousand takes in them open at the same time does not cause Cinema to crash.
      Any help would be greatly appreciated.
      John Terenece
      • J Offline
        JohnTerenece
        Just to clarify, I know that adding more objects and such to a document in Cinema will make it use up more memory and cause it to lag when it gets bad enough. My issue is that Cinema is running fine with a certain number of takes and then I add one more and it immediately crashes.
          I could reproduce the issue on R20 for 1380 takes.With the release S26, the number is a bit higher, but it still crashes. I've opened a bug report for that.
          One workaround would be to create takes that will act as group, i was able to go over that ceiling. The time get higher and higher for creating those takes. I stopped at 10 groups of 1000 takes.
          from typing import Optional
              # create a sphere and insert it in the document.
              sphere = c4d.BaseObject(c4d.Osphere)
              doc.InsertObject(sphere, None, None)
              if not sphere.CheckType(c4d.Osphere):
                  raise TypeError("The objects is not a sphere.")
              # Stores a copy of this object to use later in the autotake as initial state comparison
              undoObject = sphere.GetClone(c4d.COPYFLAGS_0)
              # Changes the radius of the sphere in scene
              originalSize = 100
              sphere[c4d.PRIM_SPHERE_RAD] = originalSize - 1
              takeData = doc.GetTakeData()
              if takeData is None:
                  raise RuntimeError("Failed to retrieve the take data.")
              # Checks if there is some TakeData and the current mode is set to auto Take
              if takeData and takeData.GetTakeMode() == c4d.TAKE_MODE_AUTO:
                  # Add a new group take
                  for i in range(0, 4):
                      # Adds a new Take that will group other takes
                      groupTake = takeData.AddTake("this is a new take {}".format(i), None, None)
                      for j in range(0, 1000):
                          newTake = takeData.AddTake("this is a new take {}".format(j), groupTake, None)
                          sphere[c4d.PRIM_SPHERE_RAD] = originalSize + j
                          if newTake is None:
                              raise RuntimeError("Failed to add a new take.")
                          newTake.AutoTake(takeData, sphere, undoObject)
              # Pushes an update event to Cinema 4D
          • J Offline
            JohnTerenece @Manuel
            @m_magalhaes
            Thanks for the response.
            Might be able to use your idea as potential solution.
            John Terenece
