    is it possible for me to have a plugin that modifies some function of cinema 4d?
    11 Posts 4 Posters 2.3k Views 2 Watching
    • C4DSC Offline
      C4DS
      As far as I know there is no possibility to just "hook into" existing commands of Cinema4D.
      You will have to provide your own command where you perform the "preliminaries" and then call the existing command.
      In other words, for your example, you will want to create a 'My Render View' command which perform the tasks you want to see executed before 'Render View' and which after that just calls 'Render View'.
      • pyxelriggerP Offline
        pyxelrigger
        yeah! I am aware of this but I would like to know if it is possible to change the command
        • a_blockA Offline
          a_block
          No, it is not possible to change existing commands. Sorry.
            Hey @everyone,
            we will answer this tomorrow more thoroughly, but before @pyxelrigger gives up here, I wanted to point out that while @C4DS and @a_block answers (thanks for jumping in) are in principle correct, there is MSG_MULTI_RENDERNOTIFICATION with which one can react to upcoming renderings, including some form of detection in which context the rendering happens via RENDERFLAGS.
            I am also pretty sure that we will ask for more details tomorrow, e.g., what that script is and into which plugin type you plan to convert it. There are restrictions for where you can receive MSG_MULTI_RENDERNOTIFICATION and what you can do in the context of the message. So, when you see this before tomorrow, @pyxelrigger, you should add this information.
              pyxelrigger
              I made a plugin to show you
              would be something like this:
              Coquito.pyp
                ferdinand @pyxelrigger
                Hello @pyxelrigger,
                thank for reaching out to us, and, big surprise, you topic has been assigned to me 🙂 .
                Thank you for providing more information, I assume from the context that your plugin interface is going to be a CommandData plugin. MSG_MULTI_RENDERNOTIFICATION cannot be received in a CommandData plugin, it is only being broadcasted to NodeData plugins. You did not mention what your script is supposed to do, but the bottom line is that when you choose the MSG_MULTI_RENDERNOTIFICATION approach, then you will not be able to modify the outcome of the rendering, as the render document has already been established at that point. All modifications to the active document will not be reflected in the render.
                The easiest path for your task seems to be the approach proposed by @C4DS. Just execute your script in the CommandData and call c4d.CallCommand(12163) # Render View after that. You will then have two buttons for rendering, the actual Render View button provided by Cinema 4D, and the button of your plugin. To make it more convenient, you could put your plugin on a shortcut similar to the default command or simply replace the original button shortcut with the command provided by your plugin.
                  pyxelrigger
                  hi @ferdinand ,
                  I also forgot to mention that there will be a button to save the checkbox configuration.
                  before Render To Picture Viewer runs, a dialog with two buttons will run "go to render" and "stop"
                  or a simple c4d.gui.QuestionDialog() I'm still deciding
                  by chance, now taking advantage of it, I already had several other doubts that I had to resort here to the forum and the solution was always something related to MSG, I don't understand anything about this subject, where can I read more about this material?
                  ferdinandF a_blockA 3 Replies Last reply Reply Quote 0
                    Hello @pyxelrigger,
                    ... MSG, I don't understand anything about this subject, where can I read more about this material?
                    You can read more about messages in the Python API in the Message Manual.
                    • a_blockA Offline
                      a_block @pyxelrigger
                      For what it's worth, besides this forum and SDK Team's great work, you may also want to check Cairyn's "Python Spoonfed" series on Patreon. And if these sources are not enough, you can also book me for 1:1 training.
                        Hello @pyxelrigger,
                        without any further activity before Wednesday, the 16.03.2022, we will consider this topic as solved and remove the "unsolved" state from this topic.
