    Treeview Column adjust
    pythonr20r25
    8 Posts 2 Posters 2.2k Views 2 Watching
      mogh
      Dear developers,
      is there a solution for displaying the columns in the right width when the treeview is populated with data?
      I can get the width of each cell with geUserArea.DrawGetTextWidth("somestring"), but I do not know how to "readjust" the columns to the right width ...
      class listview():
          def GetColumnWidth(self, root, userdata, obj, col, area):
              return 40
      def DrawCell():
      current status see the overlapping on the date
      desired output
      regarding code, it builds on the treeview list floating around here in the forums. I do not know of a SDK Example?
      thanks in advance
        ferdinand @mogh
        Hello @mogh,
        Thank you for reaching out to us. I really must stress here again that we require executable code to be posted, as lined out in our Forum Guidelines. While there are sometimes questions which can be answered abstractly, both the users and we ourselves usually prefer concrete answers, i.e., something executable. When users do not provide code, doing this will be much harder for us, as we have then not only to write that code, but also do a lot of guessing.
        About your question:
        You must measure the objects that are passed to GetColumnWidth. The method also passes a GeUserArea which is conveniently setup to measure string widths. I have used an older tree view example written by Maxime (see end of the posting for the full listing of the modified code) to demonstrate the approach. The core of the example is its method GetColumnWidth:
            """Measures the width of cells.
            Although this function is called #GetColumnWidth and has a #col, it is
            not only executed by column but by cell. So, when there is a column
            with items requiring the width 5, 10, and 15, then there is no need
            for evaluating all items. Each item can return its ideal width and
            Cinema 4D will then pick the largest value.
            Args:
                root (any): The root node of the tree view.
                userdata (any): The user data of the tree view.
                obj (any): The content of the current cell.
                col (int): The index of the column #obj is contained in.
                area (GeUserArea): An already initialized GeUserArea to measure
                 the width of strings.
            Returns:
                TYPE: Description
            # The default width of a column is 80 units.
            width = 80
            # For all calls for cells which contain a string item ...
            if isinstance(obj, str):
                # Replace the width with the text width. area is a prepopulated
                # user area which has already setup all the font stuff, we can
                # measure right away.
                width = area.DrawGetTextWidth(obj)
            return width
        If this does not help in your case, we must ask for a concrete code example. As a side note - in our C++ API GUIs like yours are a much less labor-intensive task, since list views and their accompanying helper class SimpleListView can be used there.
        """Example for setting the column width of a tree view by the width of its
        items.
        The only changes which have been made in comparison to the original code can
        be found in TextureObject.__init__(), TextureObject.RandomString() and
        ListView.GetColumnWidth(). The tree view items #TextureObject now generate
        random #texturePath and #otherData strings and the treeview scales its columns
        to the length of these strings.
        Adapted from:
            https://developers.maxon.net/forum/topic/10654/14102_using-customgui-listview/2
        import random
        # Be sure to use a unique ID obtained from [URL-REMOVED]
        PLUGIN_ID = 1000010 # TEST ID ONLY
        # TreeView Column IDs.
        ID_CHECKBOX = 1
        ID_NAME = 2
        ID_OTHER = 3
        # A tuple of characters to select from (a-z).
        CHARACTERS = tuple(chr (n) for n in range(97, 122))
        class TextureObject(object):
            Class which represent a texture, aka an Item in our list
            def __init__(self):
                self.texturePath = TextureObject.RandomString(5, 10)
                self.otherData = TextureObject.RandomString(10, 20)
                self._selected = False
            @staticmethod
            def RandomString(minLength: int, maxLength: int) -> str:
                """Returns a string of random characters with a length between
                #minLength and #maxLength.
                The characters are taken from the 97 (a) to 122 (z) ASCII range.
                return "".join(
                    (random.choice(CHARACTERS) for _ in range(minLength, maxLength)))
            @property
            def IsSelected(self):
                return self._selected
            def Select(self):
                self._selected = True
            def Deselect(self):
            def __repr__(self):
                return str(self)
            def __str__(self):
                return self.texturePath
        class ListView(c4d.gui.TreeViewFunctions):
            def __init__(self):
                # Add ten mock data texture objects.
                self.listOfTexture = [TextureObject() for _ in range(10)]
            def IsResizeColAllowed(self, root, userdata, lColID):
            def IsTristate(self, root, userdata):
                return False
                Args:
                Returns:
                    TYPE: Description
                width = 80
                return width
            def IsMoveColAllowed(self, root, userdata, lColID):
                # The user is allowed to move all columns.
                # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
            def GetFirst(self, root, userdata):
                Return the first element in the hierarchy, or None if there is no element.
                rValue = None if not self.listOfTexture else self.listOfTexture[0]
                return rValue
            def GetDown(self, root, userdata, obj):
                Return a child of a node, since we only want a list, we return None everytime
                return None
            def GetNext(self, root, userdata, obj):
                Returns the next Object to display after arg:'obj'
                rValue = None
                currentObjIndex = self.listOfTexture.index(obj)
                nextIndex = currentObjIndex + 1
                if nextIndex < len(self.listOfTexture):
                    rValue = self.listOfTexture[nextIndex]
                return rValue
            def GetPred(self, root, userdata, obj):
                Returns the previous Object to display before arg:'obj'
                rValue = None
                predIndex = currentObjIndex - 1
                if 0 <= predIndex < len(self.listOfTexture):
                    rValue = self.listOfTexture[predIndex]
                return rValue
            def GetId(self, root, userdata, obj):
                Return a unique ID for the element in the TreeView.
                return hash(obj)
            def Select(self, root, userdata, obj, mode):
                Called when the user selects an element.
                if mode == c4d.SELECTION_NEW:
                    for tex in self.listOfTexture:
                        tex.Deselect()
                    obj.Select()
                elif mode == c4d.SELECTION_ADD:
                    obj.Select()
                elif mode == c4d.SELECTION_SUB:
                    obj.Deselect()
            def IsSelected(self, root, userdata, obj):
                Returns: True if *obj* is selected, False if not.
                return obj.IsSelected
            def SetCheck(self, root, userdata, obj, column, checked, msg):
                Called when the user clicks on a checkbox for an object in a
                `c4d.LV_CHECKBOX` column.
                if checked:
                    obj.Select()
                    obj.Deselect()
            def IsChecked(self, root, userdata, obj, column):
                Returns: (int): Status of the checkbox in the specified *column* for *obj*.
                if obj.IsSelected:
                    return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                    return c4d.LV_CHECKBOX_ENABLED
            def GetName(self, root, userdata, obj):
                Returns the name to display for arg:'obj', only called for column of type LV_TREE
                return str(obj) # Or obj.texturePath
            def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor):
                Draw into a Cell, only called for column of type LV_USER
                if col == ID_OTHER:
                    name = obj.otherData
                    geUserArea = drawinfo["frame"]
                    w = geUserArea.DrawGetTextWidth(name)
                    h = geUserArea.DrawGetFontHeight()
                    xpos = drawinfo["xpos"]
                    ypos = drawinfo["ypos"] + drawinfo["height"]
                    drawinfo["frame"].DrawText(name, xpos, ypos - h * 1.1)
            def DoubleClick(self, root, userdata, obj, col, mouseinfo):
                Called when the user double-clicks on an entry in the TreeView.
                Returns:
                  (bool): True if the double-click was handled, False if the
                    default action should kick in. The default action will invoke
                    the rename procedure for the object, causing `SetName()` to be
                    called.
                c4d.gui.MessageDialog("You clicked on " + str(obj))
            def DeletePressed(self, root, userdata):
                "Called when a delete event is received."
                for tex in reversed(self.listOfTexture):
                    if tex.IsSelected:
                        self.listOfTexture.remove(tex)
        class TestDialog(c4d.gui.GeDialog):
            _treegui = None # Our CustomGui TreeView
            _listView = ListView() # Our Instance of c4d.gui.TreeViewFunctions
            def CreateLayout(self):
                # Create the TreeView GUI.
                customgui = c4d.BaseContainer()
                customgui.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
                customgui.SetBool(c4d.TREEVIEW_HAS_HEADER, True) # True if the tree view may have a header line.
                customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, False) # True if no lines should be drawn.
                customgui.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True) # True if the user can move the columns.
                customgui.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True) # True if the column width can be changed by the user.
                customgui.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True) # True if all lines have the same height.
                customgui.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True) # Alternate background per line.
                customgui.SetBool(c4d.TREEVIEW_CURSORKEYS, True) # True if cursor keys should be processed.
                customgui.SetBool(c4d.TREEVIEW_NOENTERRENAME, False) # Suppresses the rename popup when the user presses enter.
                self._treegui = self.AddCustomGui(1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 300, 300, customgui)
                if not self._treegui:
                    print ("[ERROR]: Could not create TreeView")
                    return False
                self.AddButton(1001, c4d.BFH_CENTER, name="Add")
            def InitValues(self):
                # Initialize the column layout for the TreeView.
                layout = c4d.BaseContainer()
                layout.SetLong(ID_CHECKBOX, c4d.LV_CHECKBOX)
                layout.SetLong(ID_NAME, c4d.LV_TREE)
                layout.SetLong(ID_OTHER, c4d.LV_USER)
                self._treegui.SetLayout(3, layout)
                # Set the header titles.
                self._treegui.SetHeaderText(ID_CHECKBOX, "Check")
                self._treegui.SetHeaderText(ID_NAME, "Name")
                self._treegui.SetHeaderText(ID_OTHER, "Other")
                self._treegui.Refresh()
                # Set TreeViewFunctions instance used by our CUSTOMGUI_TREEVIEW
                self._treegui.SetRoot(self._treegui, self._listView, None)
            def Command(self, id, msg):
                # Click on button
                if id == 1001:
                    # Add data to our DataStructure (ListView)
                    newID = len(self._listView.listOfTexture) + 1
                    tex = TextureObject("T{}".format(newID))
                    self._listView.listOfTexture.append(tex)
                    # Refresh the TreeView
        class MenuCommand(c4d.plugins.CommandData):
            dialog = None
            def Execute(self, doc):
                if self.dialog is None:
                    self.dialog = TestDialog()
                return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, defaulth=600, defaultw=600)
            def RestoreLayout(self, sec_ref):
                return self.dialog.Restore(PLUGIN_ID, secret=sec_ref)
            c4d.plugins.RegisterCommandPlugin(
                PLUGIN_ID, "Python TreeView Example", 0, None, "Python TreeView Example", MenuCommand())
          mogh
          I'am having Forum troubles posting ... is there a max char limit ?
          Replying here with a long answer with code gives me "Error: error"
          kind regrads
          mogh
            ferdinand @mogh
            Hey @mogh,
            Sorry for the inconvenience caused, but I probably know the issue. Try posting your content without the code snippet. I have encountered the problem twice myself, here and in another thread. My code above is formatted in a very specific way as otherwise this problem will occur.
            The line:
            Is very much intentional in this form, as removing the whitespace between chr and ( will raise the problem of the super descriptive error "error" ;). This also applies to normal text, you cannot have the characters chr dircetly followed by (.
            If the problem is caused by another section, please just use something like pastebin for now and I will have a look what causes the problem.
              mogh
              @ferdinand Thank you again, and I am sorry, for not following the guidelines, need to print them out I guess. Also forgot to "Ask a Question"
              I understand the concept (or perhaps not at all) but even in your example it only takes the string of the "first" column (because obj always returns its "name" not its other variables) and after putting a print inside the isinstance() I figured its never trigered ?
              I modified the code so the button inserts a long string after the treeview was established to illustrate it.
              Regarding Cloumn -> I guess I have to evaluate the column and then get the coresponding variable from the object to measure the right width?
                      print(obj, col, area.DrawGetTextWidth(obj))
                                  print(width)
                              return width
              Full code with working Button:
              items.
              Adapted from:
              import random
              ID_CHECKBOX = 1
              ID_NAME = 2
              ID_OTHER = 3
              ID_LONGFILENAME = 4
              CHARACTERS = tuple( chr ( n) for n in range(97, 122))
                  def __init__(self):
                      self.otherData = TextureObject.RandomString(5, 20)
                      self.longfilename = "-"
                  @staticmethod
                      return "".join(
                  @property
                  def Select(self):
                  def Deselect(self):
                  def __repr__(self):
                      return str(self)
                  def __str__(self):
                  def __init__(self):
                      return False
                      Args:
                      Returns:
                          TYPE: Description
                      width = 80
                          print(width)
                      return width
                      return rValue
                      return None
                      rValue = None
                      return rValue
                      rValue = None
                      return rValue
                      return hash(obj)
                              tex.Deselect()
                          obj.Select()
                          obj.Select()
                          obj.Deselect()
                      if checked:
                          obj.Select()
                          obj.Deselect()
                      if obj.IsSelected:
                      if col == ID_OTHER:
                          drawinfo["frame"].DrawText(name, xpos, ypos - int(h * 1.1))
                      if col == ID_LONGFILENAME:
                          name = obj.longfilename
                      Returns:
                          called.
                          if tex.IsSelected:
                      customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, True)  # True if no lines should be drawn.
                          print("[ERROR]: Could not create TreeView")
                          return False
                      layout.SetLong(ID_LONGFILENAME, c4d.LV_USER)
                      self._treegui.SetLayout(4, layout)
                      self._treegui.SetHeaderText(ID_LONGFILENAME, "Long Filename")
                      # Click on button
                      if id == 1001:
                          newID = int(len(self._listView.listOfTexture) + 1)
                          # print(newID)
                          # newID = "T{}".format(newID)
                          # print(newID)
                          # tex = TextureObject(newID)
                          tex = TextureObject()
                          tex.texturePath = "Some new data"
                          tex.longfilename = TextureObject.RandomString(20, 80)
                  dialog = None
              thank you
              mogh
                ferdinand @mogh
                Hey @mogh,
                I made a little mistake in my method, you do not get passed in the cell item but the list view item for the cell as obj, i.e., the TextureObject in this case. So, you must pick the right attribute to evaluate which will fix the problem. The correct code is (based on your listing):
                        Args:
                            obj (any): The item for the current cell.
                        Returns:
                            TYPE: Description
                        width = 80
                        if col == ID_NAME:
                            return area.DrawGetTextWidth(obj.texturePath) + 5
                        if col == ID_OTHER:
                            return area.DrawGetTextWidth(obj.otherData) + 5
                            return area.DrawGetTextWidth(obj.longfilename) + 5
                        return width
                I first went into the wrong direction and started poking around in the cell drawing in DrawCell, where I added the ...- thing when something is too short for the content. It is not required, but I left it in. Find the full code below.
                The result (I intentionally scaled down the column "Other" to show the "..." thing):
                The code:
                items.
                Adapted from:
                import random
                ID_CHECKBOX = 1
                ID_NAME = 2
                ID_OTHER = 3
                ID_LONGFILENAME = 4
                    def __init__(self):
                    @staticmethod
                        return "".join(
                    @property
                    def Select(self):
                    def Deselect(self):
                    def __repr__(self):
                        return str(self)
                    def __str__(self):
                    def __init__(self):
                        return False
                        Args:
                        Returns:
                            TYPE: Description
                        width = 80
                        if col == ID_NAME:
                        if col == ID_OTHER:
                        return width
                        return rValue
                        return None
                        rValue = None
                        return rValue
                        rValue = None
                        return rValue
                        return hash(obj)
                                tex.Deselect()
                            obj.Select()
                            obj.Select()
                            obj.Deselect()
                        if checked:
                            obj.Select()
                            obj.Deselect()
                        if obj.IsSelected:
                        if col in (ID_OTHER, ID_LONGFILENAME):
                            text = obj.otherData if col == ID_OTHER else obj.longfilename
                            canvas = drawinfo["frame"]
                            textWidth = canvas.DrawGetTextWidth(text)
                            textHeight = canvas.DrawGetFontHeight()
                            if (drawinfo["width"] < textWidth):
                                while (drawinfo["width"] < textWidth):
                                    if len(text) <= 4:
                                        text = "..."
                                        break
                                    text = text[:-4] + "..."
                            drawinfo["frame"].DrawText(text, xpos, ypos - int(textHeight * 1.1))
                        Returns:
                            called.
                            if tex.IsSelected:
                            return False
                        self._layout = layout
                        # Click on button
                        if id == 1001:
                            # print(newID)
                            # print(newID)
                            tex.longfilename = TextureObject.RandomString(20, 40)
                    dialog = None
                  mogh
                  Thanks ferdinand as allways you are the best.
                  I call this solved, the problems I encounter in my project are my own ... after cleaning my code - solving sorting ascending / descening will be next ... 😉
                    ferdinand @mogh
                    Hey @mogh,
                    Thank you for the kind words and I am happy that this solved your problem.
                    While I sometimes channel here my inner librarian and press for a formal order for new topics, so that the SDK Team can answer them effectively, I want to make clear that all Cinema 4D programming questions are welcome on Plugin Café.
                    Just remember to open a new topic for new questions and to place them in the General Talk forum when they are general programming questions not directly related to our APIs. We will treat them then with a lower priority and rigor, but we usually also answer there.
