    Test "Lock Overrides" in Python
    4 Posts 2 Posters 874 Views 1 Watching
    • D Offline
      danielsian
      Hi there, is it possible to test "Lock Overrides" and return if it is on or off using Python?
      The same question for the "Enable all overrides" button.
        ferdinand @danielsian
        Hello @danielsian,
        thank you for reaching out to us. Yes, this is possible with c4d.IsCommandChecked(). You just need the id for the command you are interested in, the Script Log is a good way to figure them out. See the example at the end of the posting for details.
        The example:
            # When the "Lock Overrides" button is checked ...
            if c4d.IsCommandChecked(431000108):
                print ("Do something")
        • D Offline
          danielsian
          Thank you very much @ferdinand, that's exactly what I was looking for.
            Hello @danielsian,
            without any further activity before Wednesday, the 16.03.2022, we will consider this topic as solved and remove the "unsolved" state from this topic.
