    Assign materials to Objects using Python Un-subscribe from this thread
    pythonr25
    3 Posts 3 Posters 883 Views 2 Watching
    • T Offline
      Tomoya
      Hello!
      I would like to automate the replacement of materials loaded in Alembic.
      How can I change the attached python code to replace the material with a material with the same name as the one applied in Alembic?
      I would appreciate your advice.
      I am new to the forum, so please forgive my unfamiliarity.
      import re
        oplist = doc.GetObjects()
        if not oplist: return
        matlist = doc.GetMaterials()
        if not matlist: return
        if oplist:
            for op in oplist:
              opname = op.GetName()
              mat = doc.SearchMaterial(opname)
              if not mat:
                for mat in matlist:
                    mname = mat.GetName()
              match = re.match(opname, mname)
              if match:
                textag = c4d.TextureTag()
                textag.SetMaterial(mat)
                textag[c4d.TEXTURETAG_PROJECTION]=c4d.TEXTURETAG_PROJECTION_UVW
                op.InsertTag(textag)
      if __name__==‘__main__’:
        welcome to the forum.
        I would change the fact that if no material is found with the right name, we can just continue the loop with the next object.
        This will add a new material tag to the alembic object and link the tag to the material. That is exactly what you want to do?
        import re
          if not oplist:
          # Check if there is at leat one material in the document otherwise return
          mat = doc.GetFirstMaterial()
          if not mat:
          # we already checked if oplist is not empty we do not need it twice
          for op in oplist:
            # If there is no material with the same name, we can continue the loop to the next object
            if not mat:
              continue
            if match:
        if __name__== '__main__':
          Hello @Tomoya,
          without any further questions or postings, we will consider this thread as solved by Friday the 4th, February 2022.
